    I only have a white command line after following the tutorial
    12 Posts 3 Posters 6.2k Views 3 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @jgrossrieder
      @jgrossrieder There is an installer script you can use
      bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
      J 3 Replies Last reply Reply Quote 0
        jgrossrieder @cowboysdude
        @cowboysdude said in I only have a white command line after following the tutorial:
        I executed this one, now I’ve some display! But there is a lot of things that the other did that this one didnt, like rotating the screen, or hiding the cursor, any idea how to do this?
          also, I rebooted the Pi, and the mirror didn’t restart :(
          cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 0
            And disable the screesaver?
              @jgrossrieder Do a forum search for ‘automatically starting mirror’ or something similar :)
                Mykle1 Project Sponsor Module Developer @jgrossrieder
                @jgrossrieder said in I only have a white command line after following the tutorial:
                Easiest way:
                https://forum.magicmirror.builders/topic/1503/how-to-disable-screensaver/8
                  Here it is:
                  https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
