    I only have a white command line after following the tutorial
    12 Posts 3 Posters 6.2k Views 3 Watching
      jgrossrieder @cowboysdude
      @cowboysdude said in I only have a white command line after following the tutorial:
      Is this regular Pi or a piZero?
      There are a ton of steps in that tutorial. I found that when I started out doing this I would ‘think’ I’d followed all the steps but missed a ‘few’ LOL That was ME, not saying that’s what you’re doing but it does happen.
      Now if you are using a regular PI why not just install noobs and follow this tutorial here:
      https://github.com/MichMich/MagicMirror
      Much easier :)
      The regular Pi 3 ;).
      Why? Because it was the officials steps, but I will try with your tutorial
      • cowboysdudeC Offline
        cowboysdude Module Developer @jgrossrieder
        @jgrossrieder There is an installer script you can use
        bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
        J 3 Replies Last reply Reply Quote 0
          I executed this one, now I’ve some display! But there is a lot of things that the other did that this one didnt, like rotating the screen, or hiding the cursor, any idea how to do this?
            also, I rebooted the Pi, and the mirror didn’t restart :(
            cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 0
              And disable the screesaver?
                @jgrossrieder Do a forum search for ‘automatically starting mirror’ or something similar :)
                  Mykle1 Project Sponsor Module Developer @jgrossrieder
                  @jgrossrieder said in I only have a white command line after following the tutorial:
                  Easiest way:
                  https://forum.magicmirror.builders/topic/1503/how-to-disable-screensaver/8
                    Here it is:
                    https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
