    Electron CPU usage
    247 Posts 46 Posters 628.1k Views 42 Watching
      Mykle1 Project Sponsor Module Developer @wtidwell
      @wtidwell said in Electron CPU usage:
      Quite infuriating honestly. I don’t know what I’ll try next.
      Oh man, that sucks. I’m sorry to hear that. I’m at a lost here. Really, there is no logical reason for that to happen
      • W Offline
        wtidwell @Mykle1
        @Mykle1
        My last ditch effort is to try a new SD card. The card it came with is a SanDisk 32gb card and it’s just a plain black card and I have this otherone which is a SanDisk ultra 32gb card so maybe that does something.
        Mykle1M cowboysdudeC 3 Replies Last reply Reply Quote 0
          @wtidwell
          I am certainly rooting for you! I think there was/is a walk-through on preparing the SD card, formatting and such, although I don’t remember where. It’s been a long time.
          The best of luck to you. Please keep me posted
          • W Offline
            wtidwell @Mykle1
            @Mykle1
            Just to rule out one more variable: the pi 3 should be fine running at 1080p yes?
              Here is my res on an old HP monitor. That’s using the DVI interface. It does not have HDMI.
              • cowboysdudeC Offline
                cowboysdude Module Developer @wtidwell
                @wtidwell Yeah I don’t use those plain black sd cards I buy the more expensive ones because of the issues.
                  I looked to see what SD card is in my Pi but all I could come up with is the wrapper it came in. I bought one of those CanaKit’s with everything included. I don’t want to take my mirror down if I don’t have to, sorry.
                  • W Offline
                    wtidwell @cowboysdude
                    @cowboysdude
                    @Mykle1
                    I’m beginning to think it’s the SD card. I did a clean install of Raspian on the SanDisk ultra which is the same class (u1) as the other card which was plain black and it seemed like it was a twinge better but not fantastic. Thanks for your input cowboysdude.
                    I ordered a SanDisk extreme u3 which will get here tomorrow and try that and report back in. Don’t take your mirror down haha
                      I hope that’s it. Then we can all laugh about it. Keep me posted.
                      Just in case:
                      https://www.raspberrypi.org/documentation/installation/installing-images/
                      And:
                      HOW TO FORMAT AN SD CARD AS FAT
                      Note: If you're formatting an SD (or micro SD) card that has a capacity over 32GB (i.e. 64GB and above), then see the separate SDXC formatting instructions.
                      WINDOWS
                      For Windows users we recommend formatting your SD card using the SD Association's Formatting Tool, which can be downloaded from sdcard.org. You will need to set "FORMAT SIZE ADJUSTMENT" option to "ON" in the "Options" menu to ensure that the entire SD card volume is formatted, and not just a single partition. The updated size will be shown after the format is complete.
                      MAC OS
                      The SD Association's Formatting Tool is also available for Mac users, although the default OS X Disk Utility is also capable of formatting the entire disk. To do this, select the SD card volume and choose Erase with MS-DOS format.
                      LINUX
                      For Linux users we recommend gparted (or the command line version  parted). Norman Dunbar has written up instructions for Linux users.
                        @wtidwell
                        Ok, this is the kit I bought back in January. I checked my amazon.com history.
                        “You purchased this item on January 16, 2017”
                        https://www.amazon.com/CanaKit-Raspberry-Complete-Starter-Kit/dp/B01C6Q2GSY/ref=sr_1_1?s=electronics&ie=UTF8&qid=1503626951&sr=1-1&keywords=32+GB+Micro+SD+Card+(Class+10)+pre-loaded+with+NOOBS
                        So this is the SD card I have in my Pi3-B mirror. Recommended Micro SD Card pre-loaded with NOOBS
                        That is also where I installed my Raspbian Jessie from. You can install it from NOOBS
                        • W Offline
                          wtidwell @Mykle1
                          @Mykle1
                          Well I just installed everything on a brand new SanDisk extreme u3 MicroSD. And it’s still using all my dang cpu and the transitions are still so laggy.
                          I think I’ve tried everything at this point.
                            Damn! :-(
                            • W Offline
                              wtidwell @Mykle1
                              @Mykle1
                              Is there anything to do after using the install script? Am I missing some next step?
                                You could try this, but I don’t think it’s anything you’re doing or not doing. MM is running, it’s just not running well. I left you another suggestion in the other topic you posted in.
                                Updating your MagicMirror²
                                If you want to update your MagicMirror² to the latest version, use your terminal to go to your Magic Mirror folder and type the following command:
                                git pull && npm install
                                If you changed nothing more than the config or the modules, this should work without any problems. Type git status to see your changes, if there are any, you can reset them with git reset --hard. After that, git pull should be possible.
                                • T Offline
                                  TiemenMoesker
                                  I am having the exact same problem. It is so frustrating.
                                  • W Offline
                                    wtidwell @TiemenMoesker
                                    @TiemenMoesker
                                    I’m really sorry =/ I don’t have any better information for you, maybe you can fix yours. Mine is still busted…
                                    • T Offline
                                      TiemenMoesker
                                      In details: My mm time is running fine until an animation happens, the time freezes and the choppy animation accurs. When the animation is done the time starts again and it speeds up to the point it should be. Also I noticed that every time the animation happens the CPU jumps to 90+% usage. The pi itself also goes extremely hot.
                                      I bought my raspberry from coolblue.nl 4 days ago.
                                        bhepler Module Developer
                                        Have you guys tried allocating more memory to the GPU? I think the default is like 64MB or something. I bumped mine to 128MB a while ago.
                                        One other dumb suggestion: Did you remove the nonessential stuff from your Raspian installs? The Minecraft, Wolfram Alpha, etc. as per the complete setup tutorial?
                                        • T Offline
                                          TiemenMoesker
                                          Actually the only thing I did was. Run the auto install command of magic mirror 2 and pm2. That’s it.
                                          • W Offline
                                            wtidwell @bhepler
                                            @bhepler
                                            I’ve done that, both ways giving the gpu more ram and less ram and that doesn’t seem to solve it for me.
                                            I did remove all the excess on other installs I did but there’s no other processes running anyway to take away cpu time.
                                            • 12
                                            • 13
                                            • 3 / 13
