    Electron CPU usage
    247 Posts 46 Posters 662.1k Views 42 Watching
    • W
      wtidwell @Mykle1
      @Mykle1
      @Snille
      My hardware is also BCM2835 revision a02082 , just like Snille. I have another micro SD I think floating around somewhere in my house, I’ll try and do a clean install of rapsian stretch lite on it tomorrow and use the auto install script on that and see how that goes. Fingers crossed I just got a crappy SD card or something.
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @wtidwell
        @wtidwell said in Electron CPU usage:
        How did you make out? I’ve been thinking about this issue since you started the topic. I did quite a bit of googling and there are a number of instances where people had trouble (not with MM) with performance, and heat. In many cases, those people determined that their Pi’s were faulty, after much time, frustration and troubleshooting. In those cases, they had their Pi’s replaced and the problem was solved.
        I hope the new SD solves your problem but I have my doubts about that. Please keep me informed and good luck.
        W 1 Reply Last reply
        • W
          wtidwell @Mykle1
          @Mykle1
          Well I ordered a new pi 3 on Amazon and did a fresh install it’s the same thing all over again. Every time the text changes on magic mirror it maxes out my cpu. And it’s starting to overheat as well and I didn’t even change any overclock settings.
          Quite infuriating honestly. I don’t know what I’ll try next.
          • Mykle1M
            Oh man, that sucks. I’m sorry to hear that. I’m at a lost here. Really, there is no logical reason for that to happen
            • W
              wtidwell @Mykle1
              @Mykle1
              My last ditch effort is to try a new SD card. The card it came with is a SanDisk 32gb card and it’s just a plain black card and I have this otherone which is a SanDisk ultra 32gb card so maybe that does something.
              Mykle1M cowboysdudeC 3 Replies Last reply
              • Mykle1M
                @wtidwell
                I am certainly rooting for you! I think there was/is a walk-through on preparing the SD card, formatting and such, although I don’t remember where. It’s been a long time.
                The best of luck to you. Please keep me posted
                • W
                  wtidwell @Mykle1
                  @Mykle1
                  Just to rule out one more variable: the pi 3 should be fine running at 1080p yes?
                  Mykle1M 2 Replies Last reply
                  • Mykle1M
                    Here is my res on an old HP monitor. That’s using the DVI interface. It does not have HDMI.
                    • cowboysdudeC
                      cowboysdude Module Developer @wtidwell
                      @wtidwell Yeah I don’t use those plain black sd cards I buy the more expensive ones because of the issues.
                      • Mykle1M
                        I looked to see what SD card is in my Pi but all I could come up with is the wrapper it came in. I bought one of those CanaKit’s with everything included. I don’t want to take my mirror down if I don’t have to, sorry.
                        • W
                          wtidwell @cowboysdude
                          @cowboysdude
                          @Mykle1
                          I’m beginning to think it’s the SD card. I did a clean install of Raspian on the SanDisk ultra which is the same class (u1) as the other card which was plain black and it seemed like it was a twinge better but not fantastic. Thanks for your input cowboysdude.
                          I ordered a SanDisk extreme u3 which will get here tomorrow and try that and report back in. Don’t take your mirror down haha
                          • Mykle1M
                            I hope that’s it. Then we can all laugh about it. Keep me posted.
                            Just in case:
                            https://www.raspberrypi.org/documentation/installation/installing-images/
                            And:
                            HOW TO FORMAT AN SD CARD AS FAT
                            Note: If you're formatting an SD (or micro SD) card that has a capacity over 32GB (i.e. 64GB and above), then see the separate SDXC formatting instructions.
                            WINDOWS
                            For Windows users we recommend formatting your SD card using the SD Association's Formatting Tool, which can be downloaded from sdcard.org. You will need to set "FORMAT SIZE ADJUSTMENT" option to "ON" in the "Options" menu to ensure that the entire SD card volume is formatted, and not just a single partition. The updated size will be shown after the format is complete.
                            MAC OS
                            The SD Association's Formatting Tool is also available for Mac users, although the default OS X Disk Utility is also capable of formatting the entire disk. To do this, select the SD card volume and choose Erase with MS-DOS format.
                            LINUX
                            For Linux users we recommend gparted (or the command line version  parted). Norman Dunbar has written up instructions for Linux users.
                            • Mykle1M
                              @wtidwell
                              Ok, this is the kit I bought back in January. I checked my amazon.com history.
                              “You purchased this item on January 16, 2017”
                              https://www.amazon.com/CanaKit-Raspberry-Complete-Starter-Kit/dp/B01C6Q2GSY/ref=sr_1_1?s=electronics&ie=UTF8&qid=1503626951&sr=1-1&keywords=32+GB+Micro+SD+Card+(Class+10)+pre-loaded+with+NOOBS
                              So this is the SD card I have in my Pi3-B mirror. Recommended Micro SD Card pre-loaded with NOOBS
                              That is also where I installed my Raspbian Jessie from. You can install it from NOOBS
                              • W
                                wtidwell @Mykle1
                                @Mykle1
                                Well I just installed everything on a brand new SanDisk extreme u3 MicroSD. And it’s still using all my dang cpu and the transitions are still so laggy.
                                I think I’ve tried everything at this point.
                                • Mykle1M
                                  Damn! :-(
                                  • W
                                    wtidwell @Mykle1
                                    @Mykle1
                                    Is there anything to do after using the install script? Am I missing some next step?
                                    • Mykle1M
                                      You could try this, but I don’t think it’s anything you’re doing or not doing. MM is running, it’s just not running well. I left you another suggestion in the other topic you posted in.
                                      Updating your MagicMirror²
                                      If you want to update your MagicMirror² to the latest version, use your terminal to go to your Magic Mirror folder and type the following command:
                                      git pull && npm install
                                      If you changed nothing more than the config or the modules, this should work without any problems. Type git status to see your changes, if there are any, you can reset them with git reset --hard. After that, git pull should be possible.
                                      • T
                                        TiemenMoesker
                                        I am having the exact same problem. It is so frustrating.
                                        • W
                                          wtidwell @TiemenMoesker
                                          @TiemenMoesker
                                          I’m really sorry =/ I don’t have any better information for you, maybe you can fix yours. Mine is still busted…
                                          • T
                                            TiemenMoesker
                                            In details: My mm time is running fine until an animation happens, the time freezes and the choppy animation accurs. When the animation is done the time starts again and it speeds up to the point it should be. Also I noticed that every time the animation happens the CPU jumps to 90+% usage. The pi itself also goes extremely hot.
                                            I bought my raspberry from coolblue.nl 4 days ago.
                                            • 12
                                            • 13
                                            • 3 / 13
