    Cheap as chips.....
    17 Posts 4 Posters 15.1k Views 5 Watching
      ptbw2000 @Damian
      @Damian ( edit - The question wasn’t for me was it. Anyway this might help someone. )
      Hi, not sure what you mean hopefully the attached picture will help. ( That’s a Pi B+ with a very fat HDMI cable. I intend to change it to a slimmer one and add a PIR sensor using @cowboysdude code. )
      I was going to use a Pi Zero W then realised I had an old B+ and Wifi dongle so I switched to that instead.
      If you have any specific questions please ask.
      D 1 Reply Last reply
      Reply Quote 2
        Damian @ptbw2000
        @ptbw2000 said in Cheap as chips.....:
        @Damian ( edit - The question wasn’t for me was it )
        hello no it was second time asking how to get this on mini itx pc as said but still get no answer so not sure why no answer
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Damian
          @Damian said in Cheap as chips.....:
          There can be a million reasons why you didn’t get an answer. Who can say why?
          With that said, MM can be installed on Pi’s, PC’s, Mac’s. My first mirror is using a Pi3 with the standard Raspbian Jessie out of the box. I have MM installed on a Compaq laptop running uBuntu, a Dell laptop running Windows 7 and my dev machine, also running Windows 7.
          You have to manually install things but it does work, and it works better than on a Pi. The mini itx that @cowboysdude mentioned is a brilliant idea, really. It’s small form factor allows it to be placed behind a mirror as you would a Pi, and its raw computing power, speed and graphics far exceeds that of any Pi.
          • cowboysdudeC
            cowboysdude Module Developer @Damian
            @cowboysdude
            I’m going bigger with a mini itx… I like the power and it runs VERY fast with strawberry’s voice module ;)
            hello will you publish how you ggot this with your pc? thank you
            I"m not making a traditional mirror per say… I"m using an Intel cpu and mini itx board with 8 gig ram and SSD on a 32" TV.
            I installed Ubuntu and MM … that’s pretty much it :)
            Is there anything specifically you needed to know?
              Damian @cowboysdude
              @cowboysdude
              @Mykle1
              Sorry but I never noticed these replies or would have replied earlier, I managed by following @Mykle1 guide. and it worked as expected. Been so busy with setyting up full Alexa home automation in my home that I manage on here for quick visits only, but now automation is complete, I can come back to MM and continue with it, and hopefully incorporate MM in some way, although I already have alexa power up/down the monitor.
              Reply Quote 2
              • Mykle1M
                No worries, mate. :^)
                Ahh, excellent! :^)
                Sounds like you’re having fun and getting things done. I don’t have Alexa. Sounds damn cool though! :^)
                • cowboysdudeC
                  Nice job!
                    Damian @Mykle1
                    @Mykle1 said in Cheap as chips.....:
                    Cool, but quite a lot of work coding and making macros, using Broadlink RM Pro (IR and RF), with BlackBean in another room to automate there by IR, using a Droid box as a hub, and now controlling every light, every power point switch, lamps,TV’s, all functions of my AV equipment, LED striplights, spot lights, power on/off my PC’s, access any app/file on PC’s, use and control my Plex server to watch movies, listen to music, view pictures, open close my blinds, Volume up/down on TV’s, change source, change channels, full control of droid box, ect, ect, all by voice control only.
                    Now I’m back fully with MM and hope to do more with that.
                    • Mykle1M
                      After all that, I’m thinking, you will NOT have a problem with MM. :^)
                        Damian @Mykle1
                        :-D If only linux/JS were that easy for me, it is worlds apart from what I am used to ;-)
                        • cowboysdudeC
                          @Damian try it… once you do you’ll love it! :)
                            Damian @cowboysdude
                            @cowboysdude
                            I’m getting there in baby steps, but it’s like trying to learn russian by reading a chinese book :-)
                            Reply Quote 2
                            • cowboysdudeC
                              @Damian That’s how you do it… you’re doing it right… a little at a time :) You’ll get it!
