    • Nystro0mN Offline
      Nystro0m @Mykle1
      @Mykle1 Well… You cant understand how everything works right away!
      I though i needed to copy all CSS from main to custom. So i made a local backup of the Main.css instead.
      I now know better! lol
        Mykle1 Project Sponsor Module Developer @Nystro0m
        @Nystro0m
        He’s not even kidding. @cowboysdude is one of the hardest working people I know.
        And then he does this for fun?
        Sheeeesh!
        • cowboysdudeC Offline
          There in is MOST of my problem… I am HORRIBLE at CSS… just can’t seem to get it …
            @cowboysdude said in MMM-NOAA - Another Weather Module:
            Well if you have the winning lottery numbers that would be a big help LOL
            I do have a Lottery module that might help you with that! ;^)
              @Mykle1 Yeah I remember that… LOL
                I apologize for this… I’m tired and memory is failing but… in the new version we only need a very minimal translation file… the weather will adjust automatically to the language you have selected in your config.js file ;) Here’s an example:
                So there’s no need in adding to the translation files :) AND for this:
                	curCon.classList.add("xsmall", "bright");
                	curCon.innerHTML = this.translate("Currently: ") + current.weather;
                	wrapper.appendChild(curCon);
                Is correct because the variable current.weather will show in the chosen language all by itself :)
                Hang in there I"m trying to finalize what I’m working on now.
                • tbbearT Offline
                  tbbear Module Developer
                  Thanks for the new translations, now only a few topics do not fit for german users.
                  1. we would not say “Anzahl der Tageslicht” we say “Stunden mit Tageslicht”
                  2. Not “11 Std. 48 Protokoll” we say “11 Std. 48 min”
                  3. we dont measure airpressure in “psi” like 29.99 here i also think this is same in a lot of countries our value is “hPa” which means “HectoPascal”
                  4. in your last post u said that my change is not necessary any more but when i remove it i still get only english actual weather so i keep it
                  U did and do a great Job and i hope u are not angry about my comments, but i only try to help.
                  So one last topic:
                  i saw an issue at github that people have problems installing the module and i think i know why.
                  If u look at your readme file it lookes like that the apiKey and the airKey are the same keys and thats wrong they are differen keys from different websites. U grab the useAir from “http://api.airvisual.com” so a user has to sign in there and get the airKey from this side but their is no hint in your readme about this.
                  Hope i could help.
                  Robert the Bear
                    cowboysdude Module Developer @tbbear
                    @tbbear NO I appreciate the feedback…I’m using Google translate and I’m sure they are wrong at times :)
                    I’ll get that corrected! :)
                    1. we would not say “Anzahl der Tageslicht” we say “Stunden mit Tageslicht” ~ FIXED
                    2. Not “11 Std. 48 Protokoll” we say “11 Std. 48 min” ~ FIXED
                      we dont measure airpressure in “psi” like 29.99 here i also think this is same in a lot of countries our value is “hPa” which means “HectoPascal” ~ Best I can do is to use mb
                      in your last post u said that my change is not necessary any more but when i remove it i still get only english actual weather so i keep it ~ Not sure what you mean here…
                    Updated Readme ;)
                    tbbearT 1 Reply Last reply Reply Quote 0
                    • tbbearT Offline
                      tbbear Module Developer @cowboysdude
                      @cowboysdude
                      this i ment
                      Robert the Bear
                        @tbbear Not sure this looks right to me…
                        I change this line in my config.js file and get what you’re seeing below
                        " language: ‘en’," to “language: ‘de’,”
                        • tbbearT Offline
                          this looks good see what i get:
                          ![alt text](0_1506885050188_a72f6954-fecb-4f7c-876f-a92c1817c86a-grafik.png image url)
                          Robert the Bear
                          • tbbearT Offline
                            oooo by the way i just see ur change in airpressure wow this is great
                            Robert the Bear
                              @tbbear That I don’t understand… so what I would do … delete the MMM-NOAA directory and do another install like it was new… something is getting crossed up there… you’re missing files. The image I posted is the one that is new on github …
                              • tbbearT Offline
                                ok, i will do and report soon thanks
                                Robert the Bear
                                  @tbbear Thank you! Glad to help in anyway I can!
                                  • tbbearT Offline
                                    absolutely perfect, readme changed and all other stuff i only see one little topic after i loaded your module it said MMM-NOAA_master so i had to remove the _master all other things are TOP!!! by the way i think u should be the new default weather app im MM
                                    Robert the Bear
                                    cowboysdudeC Mykle1M 3 Replies Last reply Reply Quote 2
                                    • tbbearT Offline
                                      i know i am the thorn in ur side but i think it would look better if the topic “Stunden mit Tageslicht” would use the same font size as the other lines.
                                      Robert the Bear
                                        @tbbear said in MMM-NOAA - Another Weather Module:
                                        Yeah that’s what happens when you do a manual install it’s how github sends the file… can’t control that… if you do a git clone that doesn’t happen ;)
                                          Perhaps later…right now dinner is calling my name… just got done watching the Cowboys game so food is priority LOL
                                          • tbbearT Offline
                                            of course. enjoy ur meal
                                            Robert the Bear
                                            • 34
                                            • 35
                                            • 5 / 35
