    690 Posts 77 Posters 3.3m Views 70 Watching
    • cowboysdudeC
      cowboysdude Module Developer @Nystro0m
      @Nystro0m Well if you have the winning lottery numbers that would be a big help LOL
      No if you want feel free to look at it and if you have suggestions or changes let me know! :)
      I started building this just for me…but after some requests I posted it… right now I"m working on turning the bottom forecast into a table so it looks better…
      Mykle1M 1 Reply Last reply
      • Nystro0mN
        Nystro0m @Mykle1
        @Mykle1 Well… You cant understand how everything works right away!
        I though i needed to copy all CSS from main to custom. So i made a local backup of the Main.css instead.
        I now know better! lol
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Nystro0m
          @Nystro0m
          He’s not even kidding. @cowboysdude is one of the hardest working people I know.
          And then he does this for fun?
          Sheeeesh!
          • cowboysdudeC
            There in is MOST of my problem… I am HORRIBLE at CSS… just can’t seem to get it …
            • Mykle1M
              @cowboysdude said in MMM-NOAA - Another Weather Module:
              I do have a Lottery module that might help you with that! ;^)
              • cowboysdudeC
                @Mykle1 Yeah I remember that… LOL
                • cowboysdudeC
                  I apologize for this… I’m tired and memory is failing but… in the new version we only need a very minimal translation file… the weather will adjust automatically to the language you have selected in your config.js file ;) Here’s an example:
                  So there’s no need in adding to the translation files :) AND for this:
                  	curCon.classList.add("xsmall", "bright");
                  	curCon.innerHTML = this.translate("Currently: ") + current.weather;
                  	wrapper.appendChild(curCon);
                  Is correct because the variable current.weather will show in the chosen language all by itself :)
                  Hang in there I"m trying to finalize what I’m working on now.
                  • tbbearT
                    tbbear Module Developer
                    Thanks for the new translations, now only a few topics do not fit for german users.
                    1. we would not say “Anzahl der Tageslicht” we say “Stunden mit Tageslicht”
                    2. Not “11 Std. 48 Protokoll” we say “11 Std. 48 min”
                    3. we dont measure airpressure in “psi” like 29.99 here i also think this is same in a lot of countries our value is “hPa” which means “HectoPascal”
                    4. in your last post u said that my change is not necessary any more but when i remove it i still get only english actual weather so i keep it
                    U did and do a great Job and i hope u are not angry about my comments, but i only try to help.
                    So one last topic:
                    i saw an issue at github that people have problems installing the module and i think i know why.
                    If u look at your readme file it lookes like that the apiKey and the airKey are the same keys and thats wrong they are differen keys from different websites. U grab the useAir from “http://api.airvisual.com” so a user has to sign in there and get the airKey from this side but their is no hint in your readme about this.
                    Hope i could help.
                    Robert the Bear
                    • cowboysdudeC
                      cowboysdude Module Developer @tbbear
                      @tbbear NO I appreciate the feedback…I’m using Google translate and I’m sure they are wrong at times :)
                      I’ll get that corrected! :)
                      1. we would not say “Anzahl der Tageslicht” we say “Stunden mit Tageslicht” ~ FIXED
                      2. Not “11 Std. 48 Protokoll” we say “11 Std. 48 min” ~ FIXED
                        we dont measure airpressure in “psi” like 29.99 here i also think this is same in a lot of countries our value is “hPa” which means “HectoPascal” ~ Best I can do is to use mb
                        in your last post u said that my change is not necessary any more but when i remove it i still get only english actual weather so i keep it ~ Not sure what you mean here…
                      Updated Readme ;)
                      tbbearT 1 Reply Last reply
                      • tbbearT
                        tbbear Module Developer @cowboysdude
                        @cowboysdude
                        this i ment
                        Robert the Bear
                        • cowboysdudeC
                          @tbbear Not sure this looks right to me…
                          I change this line in my config.js file and get what you’re seeing below
                          " language: ‘en’," to “language: ‘de’,”
                          • tbbearT
                            this looks good see what i get:
                            ![alt text](0_1506885050188_a72f6954-fecb-4f7c-876f-a92c1817c86a-grafik.png image url)
                            Robert the Bear
                            • tbbearT
                              oooo by the way i just see ur change in airpressure wow this is great
                              Robert the Bear
                              • cowboysdudeC
                                @tbbear That I don’t understand… so what I would do … delete the MMM-NOAA directory and do another install like it was new… something is getting crossed up there… you’re missing files. The image I posted is the one that is new on github …
                                • tbbearT
                                  ok, i will do and report soon thanks
                                  Robert the Bear
                                  • cowboysdudeC
                                    @tbbear Thank you! Glad to help in anyway I can!
                                    • tbbearT
                                      absolutely perfect, readme changed and all other stuff i only see one little topic after i loaded your module it said MMM-NOAA_master so i had to remove the _master all other things are TOP!!! by the way i think u should be the new default weather app im MM
                                      Robert the Bear
                                      cowboysdudeC Mykle1M 3 Replies Last reply
                                      Reply Quote 2
                                      • tbbearT
                                        i know i am the thorn in ur side but i think it would look better if the topic “Stunden mit Tageslicht” would use the same font size as the other lines.
                                        Robert the Bear
                                        • cowboysdudeC
                                          @tbbear said in MMM-NOAA - Another Weather Module:
                                          Yeah that’s what happens when you do a manual install it’s how github sends the file… can’t control that… if you do a git clone that doesn’t happen ;)
                                          • cowboysdudeC
                                            Perhaps later…right now dinner is calling my name… just got done watching the Cowboys game so food is priority LOL
                                            • 34
                                            • 35
                                            • 5 / 35
