    • tbbearT
      tbbear Module Developer @cowboysdude
      @cowboysdude
      So there’s no need in adding to the translation files :) AND for this:
      curCon.classList.add("xsmall", "bright");
      curCon.innerHTML = this.translate("Currently: ") + current.weather;
      wrapper.appendChild(curCon);
      Is correct because the variable current.weather will show in the chosen language all by itself :)
      this i ment
      Robert the Bear
      • cowboysdudeC
        cowboysdude Module Developer @tbbear
        @tbbear Not sure this looks right to me…
        I change this line in my config.js file and get what you’re seeing below
        " language: ‘en’," to “language: ‘de’,”
        • tbbearT
          this looks good see what i get:
          ![alt text](0_1506885050188_a72f6954-fecb-4f7c-876f-a92c1817c86a-grafik.png image url)
          Robert the Bear
          • tbbearT
            oooo by the way i just see ur change in airpressure wow this is great
            Robert the Bear
            • cowboysdudeC
              @tbbear That I don’t understand… so what I would do … delete the MMM-NOAA directory and do another install like it was new… something is getting crossed up there… you’re missing files. The image I posted is the one that is new on github …
              • tbbearT
                ok, i will do and report soon thanks
                Robert the Bear
                • cowboysdudeC
                  @tbbear Thank you! Glad to help in anyway I can!
                  • tbbearT
                    absolutely perfect, readme changed and all other stuff i only see one little topic after i loaded your module it said MMM-NOAA_master so i had to remove the _master all other things are TOP!!! by the way i think u should be the new default weather app im MM
                    Robert the Bear
                    cowboysdudeC Mykle1M 3 Replies Last reply Reply Quote 2
                    • tbbearT
                      i know i am the thorn in ur side but i think it would look better if the topic “Stunden mit Tageslicht” would use the same font size as the other lines.
                      Robert the Bear
                      • cowboysdudeC
                        @tbbear said in MMM-NOAA - Another Weather Module:
                        Yeah that’s what happens when you do a manual install it’s how github sends the file… can’t control that… if you do a git clone that doesn’t happen ;)
                        • cowboysdudeC
                          Perhaps later…right now dinner is calling my name… just got done watching the Cowboys game so food is priority LOL
                          • tbbearT
                            of course. enjoy ur meal
                            Robert the Bear
                            • cowboysdudeC
                              Where do you see that? I’m looking at it and don’t see it… NOW I’m curious LOL
                              • cowboysdudeC
                                Why Thank you… however I don’t think the MM admin feel the same LOL
                                • tbbearT
                                  u should have dinner not write to me… but is see it on my MM and also on you screenshot that their is a different font size for this
                                  Robert the Bear
                                  • tbbearT
                                    dont worry he will learn whos module is the best !“!”!"!
                                    Robert the Bear
                                    • cowboysdudeC
                                      I’m good :) That’s odd… what do you have in your custom.css file?
                                      • cowboysdudeC
                                        UPDATE
                                        1. No longer need to add lat or lon to the config.js
                                        2. put bottom forecast into table format
                                          3 weather comes in default language flavors now …it’s automatic!
                                          4 config option - showForecast: true or false to show or hide bottom forecast
                                        [Thanks to @Mykle1 for fixing my css!! and @tbbear for fixing my German]
                                        Tested and Runs on MM 2.1.3!
                                        See the README on Github
                                        Download:
                                        [card:cowboysdude/MMM-NOAA]
                                        • Mykle1M
                                          @cowboysdude said in MMM-NOAA - Another Weather Module:
                                          You’re most welcome bro! :^)
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @tbbear
                                            Oh snap! Drinks all around! :^)
                                            • 34
                                            • 35
                                            • 6 / 35
