    690 Posts 77 Posters 3.3m Views 70 Watching
    • cowboysdudeC
      cowboysdude Module Developer @tbbear
      @tbbear NO I appreciate the feedback…I’m using Google translate and I’m sure they are wrong at times :)
      I’ll get that corrected! :)
      1. we would not say “Anzahl der Tageslicht” we say “Stunden mit Tageslicht” ~ FIXED
      2. Not “11 Std. 48 Protokoll” we say “11 Std. 48 min” ~ FIXED
        we dont measure airpressure in “psi” like 29.99 here i also think this is same in a lot of countries our value is “hPa” which means “HectoPascal” ~ Best I can do is to use mb
        in your last post u said that my change is not necessary any more but when i remove it i still get only english actual weather so i keep it ~ Not sure what you mean here…
      Updated Readme ;)
      tbbearT 1 Reply Last reply
      • tbbearT
        tbbear Module Developer @cowboysdude
        @cowboysdude
        So there’s no need in adding to the translation files :) AND for this:
        curCon.classList.add("xsmall", "bright");
        curCon.innerHTML = this.translate("Currently: ") + current.weather;
        wrapper.appendChild(curCon);
        Is correct because the variable current.weather will show in the chosen language all by itself :)
        this i ment
        Robert the Bear
        • cowboysdudeC
          @tbbear Not sure this looks right to me…
          I change this line in my config.js file and get what you’re seeing below
          " language: ‘en’," to “language: ‘de’,”
          • tbbearT
            this looks good see what i get:
            ![alt text](0_1506885050188_a72f6954-fecb-4f7c-876f-a92c1817c86a-grafik.png image url)
            Robert the Bear
            • tbbearT
              oooo by the way i just see ur change in airpressure wow this is great
              Robert the Bear
              • cowboysdudeC
                @tbbear That I don’t understand… so what I would do … delete the MMM-NOAA directory and do another install like it was new… something is getting crossed up there… you’re missing files. The image I posted is the one that is new on github …
                • tbbearT
                  ok, i will do and report soon thanks
                  Robert the Bear
                  • cowboysdudeC
                    @tbbear Thank you! Glad to help in anyway I can!
                    • tbbearT
                      absolutely perfect, readme changed and all other stuff i only see one little topic after i loaded your module it said MMM-NOAA_master so i had to remove the _master all other things are TOP!!! by the way i think u should be the new default weather app im MM
                      Robert the Bear
                      cowboysdudeC Mykle1M 3 Replies Last reply
                      Reply Quote 2
                      • tbbearT
                        i know i am the thorn in ur side but i think it would look better if the topic “Stunden mit Tageslicht” would use the same font size as the other lines.
                        Robert the Bear
                        • cowboysdudeC
                          @tbbear said in MMM-NOAA - Another Weather Module:
                          Yeah that’s what happens when you do a manual install it’s how github sends the file… can’t control that… if you do a git clone that doesn’t happen ;)
                          • cowboysdudeC
                            Perhaps later…right now dinner is calling my name… just got done watching the Cowboys game so food is priority LOL
                            • tbbearT
                              of course. enjoy ur meal
                              Robert the Bear
                              • cowboysdudeC
                                Where do you see that? I’m looking at it and don’t see it… NOW I’m curious LOL
                                • cowboysdudeC
                                  Why Thank you… however I don’t think the MM admin feel the same LOL
                                  • tbbearT
                                    u should have dinner not write to me… but is see it on my MM and also on you screenshot that their is a different font size for this
                                    Robert the Bear
                                    • tbbearT
                                      dont worry he will learn whos module is the best !“!”!"!
                                      Robert the Bear
                                      • cowboysdudeC
                                        I’m good :) That’s odd… what do you have in your custom.css file?
                                        • cowboysdudeC
                                          UPDATE
                                          1. No longer need to add lat or lon to the config.js
                                          2. put bottom forecast into table format
                                            3 weather comes in default language flavors now …it’s automatic!
                                            4 config option - showForecast: true or false to show or hide bottom forecast
                                          [Thanks to @Mykle1 for fixing my css!! and @tbbear for fixing my German]
                                          Tested and Runs on MM 2.1.3!
                                          See the README on Github
                                          Download:
                                          [card:cowboysdude/MMM-NOAA]
                                          Mykle1M 1 Reply Last reply
                                          Reply Quote 2
                                          • Mykle1M
                                            @cowboysdude said in MMM-NOAA - Another Weather Module:
                                            You’re most welcome bro! :^)
                                            • 34
                                            • 35
                                            • 6 / 35
