    690 Posts 77 Posters 3.3m Views 70 Watching
    • tbbearT
      tbbear Module Developer
      this looks good see what i get:
      ![alt text](0_1506885050188_a72f6954-fecb-4f7c-876f-a92c1817c86a-grafik.png image url)
      Robert the Bear
      • tbbearT
        oooo by the way i just see ur change in airpressure wow this is great
        Robert the Bear
        • cowboysdudeC
          cowboysdude Module Developer @tbbear
          @tbbear That I don’t understand… so what I would do … delete the MMM-NOAA directory and do another install like it was new… something is getting crossed up there… you’re missing files. The image I posted is the one that is new on github …
          • tbbearT
            ok, i will do and report soon thanks
            Robert the Bear
            • cowboysdudeC
              @tbbear Thank you! Glad to help in anyway I can!
              • tbbearT
                absolutely perfect, readme changed and all other stuff i only see one little topic after i loaded your module it said MMM-NOAA_master so i had to remove the _master all other things are TOP!!! by the way i think u should be the new default weather app im MM
                Robert the Bear
                cowboysdudeC Mykle1M 3 Replies Last reply
                Reply Quote 2
                • tbbearT
                  i know i am the thorn in ur side but i think it would look better if the topic “Stunden mit Tageslicht” would use the same font size as the other lines.
                  Robert the Bear
                  • cowboysdudeC
                    @tbbear said in MMM-NOAA - Another Weather Module:
                    Yeah that’s what happens when you do a manual install it’s how github sends the file… can’t control that… if you do a git clone that doesn’t happen ;)
                    • cowboysdudeC
                      Perhaps later…right now dinner is calling my name… just got done watching the Cowboys game so food is priority LOL
                      • tbbearT
                        of course. enjoy ur meal
                        Robert the Bear
                        • cowboysdudeC
                          Where do you see that? I’m looking at it and don’t see it… NOW I’m curious LOL
                          • cowboysdudeC
                            Why Thank you… however I don’t think the MM admin feel the same LOL
                            • tbbearT
                              u should have dinner not write to me… but is see it on my MM and also on you screenshot that their is a different font size for this
                              Robert the Bear
                              • tbbearT
                                dont worry he will learn whos module is the best !“!”!"!
                                Robert the Bear
                                • cowboysdudeC
                                  I’m good :) That’s odd… what do you have in your custom.css file?
                                  • cowboysdudeC
                                    UPDATE
                                    1. No longer need to add lat or lon to the config.js
                                    2. put bottom forecast into table format
                                      3 weather comes in default language flavors now …it’s automatic!
                                      4 config option - showForecast: true or false to show or hide bottom forecast
                                    [Thanks to @Mykle1 for fixing my css!! and @tbbear for fixing my German]
                                    Tested and Runs on MM 2.1.3!
                                    See the README on Github
                                    Download:
                                    [card:cowboysdude/MMM-NOAA]
                                    Mykle1M 1 Reply Last reply
                                    Reply Quote 2
                                    • Mykle1M
                                      @cowboysdude said in MMM-NOAA - Another Weather Module:
                                      You’re most welcome bro! :^)
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @tbbear
                                        Oh snap! Drinks all around! :^)
                                          barnosch
                                          another fantastic update!
                                          Love the forecast!
                                            barnosch
                                            Just a little issue:
                                            Someone else facing this problem with the missing today highest temperature?
                                            Was in the old version the same.
                                            Makes no sense for me, since this runs in a loop, and the other stuff is showed correctly.
                                            Any ideas?
                                            B cowboysdudeC 2 Replies Last reply
                                            • 34
                                            • 35
                                            • 6 / 35
