    • tbbearT
      tbbear Module Developer
      oooo by the way i just see ur change in airpressure wow this is great
      Robert the Bear
      • cowboysdudeC
        cowboysdude Module Developer @tbbear
        @tbbear That I don’t understand… so what I would do … delete the MMM-NOAA directory and do another install like it was new… something is getting crossed up there… you’re missing files. The image I posted is the one that is new on github …
        • tbbearT
          ok, i will do and report soon thanks
          Robert the Bear
          • cowboysdudeC
            @tbbear Thank you! Glad to help in anyway I can!
            • tbbearT
              absolutely perfect, readme changed and all other stuff i only see one little topic after i loaded your module it said MMM-NOAA_master so i had to remove the _master all other things are TOP!!! by the way i think u should be the new default weather app im MM
              Robert the Bear
              cowboysdudeC Mykle1M 3 Replies Last reply Reply Quote 2
              • tbbearT
                i know i am the thorn in ur side but i think it would look better if the topic “Stunden mit Tageslicht” would use the same font size as the other lines.
                Robert the Bear
                • cowboysdudeC
                  @tbbear said in MMM-NOAA - Another Weather Module:
                  Yeah that’s what happens when you do a manual install it’s how github sends the file… can’t control that… if you do a git clone that doesn’t happen ;)
                  • cowboysdudeC
                    Perhaps later…right now dinner is calling my name… just got done watching the Cowboys game so food is priority LOL
                    • tbbearT
                      of course. enjoy ur meal
                      Robert the Bear
                      • cowboysdudeC
                        Where do you see that? I’m looking at it and don’t see it… NOW I’m curious LOL
                        • cowboysdudeC
                          Why Thank you… however I don’t think the MM admin feel the same LOL
                          • tbbearT
                            u should have dinner not write to me… but is see it on my MM and also on you screenshot that their is a different font size for this
                            Robert the Bear
                            • tbbearT
                              dont worry he will learn whos module is the best !“!”!"!
                              Robert the Bear
                              • cowboysdudeC
                                I’m good :) That’s odd… what do you have in your custom.css file?
                                • cowboysdudeC
                                  UPDATE
                                  1. No longer need to add lat or lon to the config.js
                                  2. put bottom forecast into table format
                                    3 weather comes in default language flavors now …it’s automatic!
                                    4 config option - showForecast: true or false to show or hide bottom forecast
                                  [Thanks to @Mykle1 for fixing my css!! and @tbbear for fixing my German]
                                  Tested and Runs on MM 2.1.3!
                                  See the README on Github
                                  Download:
                                  [card:cowboysdude/MMM-NOAA]
                                  • Mykle1M
                                    @cowboysdude said in MMM-NOAA - Another Weather Module:
                                    You’re most welcome bro! :^)
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @tbbear
                                      Oh snap! Drinks all around! :^)
                                        barnosch
                                        another fantastic update!
                                        Love the forecast!
                                          barnosch
                                          Just a little issue:
                                          Someone else facing this problem with the missing today highest temperature?
                                          Was in the old version the same.
                                          Makes no sense for me, since this runs in a loop, and the other stuff is showed correctly.
                                          Any ideas?
                                          B cowboysdudeC 2 Replies Last reply Reply Quote 0
                                          • tbbearT
                                            looks good now only the wind is missing
                                            Robert the Bear
                                            • 34
                                            • 35
                                            • 6 / 35
