    pm2 doesn't start after mm update
    18 Posts 4 Posters 11.5k Views 3 Watching
    • K Offline
      kurt
      Hi forum members
      this is what I get after updating the mirror, also after rebooting and restarting.
      Before I upgraded and updated the rpi sucessfully.
      Thank you for your help in advance
      kurt
      pi@raspberrypi:~ $ pm2 start mm
      [PM2] Applying action restartProcessId on app [mm](ids: 0)
      [PM2] [mm](0) ✓
      [PM2] Process successfully started
      │ Name │ mode │ status │ ↺  │ cpu │ memory   │
      │ mm   │ fork │ online │ 29 │ 0%  │ 2.3 MB   │
       Use `pm2 show ` to get more details about an app
      pi@raspberrypi:~ $
      ? K 2 Replies Last reply Reply Quote 0
        A Former User @kurt
        @kurt
        try pm2 log mm
        and
        npm start dev
        What can you see in terminal and browser (and additional dev console window)?
        K 1 Reply Last reply Reply Quote 1
        • K Offline
          kurt @Guest
          @Sean
          hi Sean thank you for your quick response
          this is what I get
          0|mm       |  Please include the following file with any support request:
          0|mm       | npm ERR!     /home/pi/MagicMirror/npm-debug.log
          npm ERR! Linux 4.9.53-v7+
          npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
          npm ERR! node v6.11.4
          npm ERR! npm  v3.10.10
          npm ERR! code ELIFECYCLE
          npm ERR! magicmirror@2.1.3 start: `sh run-start.sh "dev"`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh "dev"'.
          npm ERR! If you do, this is most likely a problem with the magicmirror package,
          npm ERR! not with npm itself.
          npm ERR!     sh run-start.sh "dev"
          npm ERR!     npm bugs magicmirror
          npm ERR! Or if that isn't available, you can get their info via:
          npm ERR!     npm owner ls magicmirror
          pi@raspberrypi:~/MagicMirror $
            A Former User
            https://forum.magicmirror.builders/topic/636/npm-start-dev?page=1
            I think this could be help.
            • K Offline
              kurt @Guest
              @Sean
              well thank you for the link, but I could’t find a simple solution for my problem. The mirror doesn’t start also if I do the
              DISPLAY=:0 npm start
              by VNC
                A Former User @kurt
                • K Offline
                  kurt @kurt
                  @kurt
                  Hi memebers
                  anyone else has an idea to get my mirror back on the screen again?
                  It’s frustrating for me, because the mirror with all the modules was running like a charm, but after that update …
                  Thank you
                    Mykle1 Project Sponsor Module Developer @kurt
                    @kurt said in pm2 doesn’t start after mm update:
                    Until you can fix your updated installation, you can rename your MagicMirror folder and manually install the version of MM that was working for you. At least you’ll have your mirror back
                    • K Offline
                      kurt @Mykle1
                      @Mykle1
                      thank you Mykle1, sounds for me as it is a weekend job.
                      To get things right: first thing is to rename the MagicMirror folder.
                      Second step is to go thru the install routine https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                      Is it than possible to copy/paste the modul-folders from the renamed (old)MMfolder into the new one and and the old config.file?
                      I read your help in https://forum.magicmirror.builders/topic/5081/mm-wont-start-after-install/2
                      but I guess this is a different problem.
                      Thank you
                      • lavolp3L Offline
                        lavolp3 Module Developer
                        Hi Kurt,
                        if I understand correctly your mirror doesn’t show up despite your pm2 “starting” it successfully!?
                        the run-start.sh shell script seems to be the problem.
                        This is the content:
                        if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                        	export DISPLAY=:0 # Set by defaul display
                        fi
                        electron js/electron.js $1
                        I would assume electron has some problem starting…
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
                        • K Offline
                          kurt @lavolp3
                          @lavolp3
                          Hi lavolp3
                          Bevor the update, pm2 startet the mirror, by now nothing happens at all, even no black screen etc.
                          do you know a way to heal the mirror?
                            Yes, but then I suggest you do a manual installation. If you run the automatic installer script you may run into trouble again.
                            Rename your MagicMirror folder. Go to https://github.com/MichMich/MagicMirror and click on the green Clone or download button on the right
                            side of the window, then click on Download ZIP. Now you have a MagicMirror-master.zip file. Double Click the file. Inside is the MagicMirror-master folder. Move that file to your /home/pi folder. Rename that folder to MagicMirror. Then in your terminal, cd into the MagicMirror directory and run npm install. When that finishes, run npm start, also in the MagicMirror directory.
                            At this point the mirror should run but you’ll likely get a “Create a config” message displayed. At which point you should do this.
                            https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                            Then back to your terminal, in the MagicMirror directory, run npm start. That should get your mirror running.
                            Then you can copy your modules, 1 by 1 into the new MagicMirror/modules folder and the entries into your new config.js file.
                            That should do it.
                            • K Offline
                              kurt @Mykle1
                              @Mykle1
                              Hi Mykle1 and Thank you for your help so much!
                              After I followed your help step by step the mirror appeared again, but I was suprised when I put all my modul folder into the “new mm”, that together with the old config. file everything worked out fine. Could’t believe that it was that easy.
                              But still I have two more things where I could’t get a for me clear solution in the forum:
                              DeprecationWarning: sys is deprecated. Use util instead.
                              and the second thing is, that I can`t find the Remote control funktion on my mobile phone, as I found it bevor. Here is the part of my config.
                              Is there the “0.0.0.0” in ipWhitelist missing, and if yes, where to put it?
                              Kurt
                              var config =
                              	electronOptions: {
                              	  ipWhitelist: [
                              		"::fff:0.0.0.0/1",
                              		"::fff:128.0.0.0/2",
                              		"::fff:192.0.0.0/3",
                              		"::fff:224.0.0.0/4",
                              		"127.0.0.1",
                              		"::ffff:127.0.0.1",
                              		"::1"
                                You got lucky. The step by step says one at a time. I’m just saying. :^)
                                Probably, one of the modules you are using has a dependency that is outdated or no longer supported. It has nothing to do with the MM software. You can ignore that warning.
                                This has been discussed lately on the forum. Do a search by clicking the little magnifying glass, top right of the forum window. If you can’t find an answer, come back here and tell me.
                                • K Offline
                                  kurt @Mykle1
                                  @Mykle1
                                  I tried several changes to my ipWhitelist after I read the posts in https://forum.magicmirror.builders/topic/5015/after-update-to-mirror-to-2-1-3-no-working-whitlist
                                  but I couldn’t get it right. So I hope you can.
                                  Thank you in advance
                                  Kurt
                                    That’s a lot of pressure. :^)
                                    Try this at the very beginning of your config.js file, so it looks like this:
                                    var config = {
                                    	port: 8080,
                                            address: "0.0.0.0",
                                    	ipWhitelist: [], // Set [] to allow all IP addresses.
                                    K 1 Reply Last reply Reply Quote 2
                                    • K Offline
                                      kurt @Mykle1
                                      @Mykle1
                                      Sorry for feeling presure, but you made it again! Works like a charm!
                                      Once again Thank you!
                                      Kurt
                                        No worries mate. I’m glad you’re up and running again!
