    pm2 doesn't start after mm update
    18 Posts 4 Posters 12.2k Views 3 Watching
      [[global:former-user]]
      https://forum.magicmirror.builders/topic/636/npm-start-dev?page=1
      I think this could be help.
      • K Offline
        kurt @Guest
        @Sean
        well thank you for the link, but I could’t find a simple solution for my problem. The mirror doesn’t start also if I do the
        DISPLAY=:0 npm start
        by VNC
          [[global:former-user]] @kurt
          • K Offline
            kurt @kurt
            @kurt
            Hi memebers
            anyone else has an idea to get my mirror back on the screen again?
            It’s frustrating for me, because the mirror with all the modules was running like a charm, but after that update …
            Thank you
              Mykle1 Project Sponsor Module Developer @kurt
              @kurt said in pm2 doesn’t start after mm update:
              Until you can fix your updated installation, you can rename your MagicMirror folder and manually install the version of MM that was working for you. At least you’ll have your mirror back
              K 1 Reply Last reply Reply Quote 1
              • K Offline
                kurt @Mykle1
                @Mykle1
                thank you Mykle1, sounds for me as it is a weekend job.
                To get things right: first thing is to rename the MagicMirror folder.
                Second step is to go thru the install routine https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                Is it than possible to copy/paste the modul-folders from the renamed (old)MMfolder into the new one and and the old config.file?
                I read your help in https://forum.magicmirror.builders/topic/5081/mm-wont-start-after-install/2
                but I guess this is a different problem.
                Thank you
                • lavolp3L Offline
                  lavolp3 Module Developer
                  Hi Kurt,
                  if I understand correctly your mirror doesn’t show up despite your pm2 “starting” it successfully!?
                  the run-start.sh shell script seems to be the problem.
                  This is the content:
                  if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                  	export DISPLAY=:0 # Set by defaul display
                  fi
                  electron js/electron.js $1
                  I would assume electron has some problem starting…
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                  • K Offline
                    kurt @lavolp3
                    @lavolp3
                    Hi lavolp3
                    Bevor the update, pm2 startet the mirror, by now nothing happens at all, even no black screen etc.
                    do you know a way to heal the mirror?
                      Yes, but then I suggest you do a manual installation. If you run the automatic installer script you may run into trouble again.
                      Rename your MagicMirror folder. Go to https://github.com/MichMich/MagicMirror and click on the green Clone or download button on the right
                      side of the window, then click on Download ZIP. Now you have a MagicMirror-master.zip file. Double Click the file. Inside is the MagicMirror-master folder. Move that file to your /home/pi folder. Rename that folder to MagicMirror. Then in your terminal, cd into the MagicMirror directory and run npm install. When that finishes, run npm start, also in the MagicMirror directory.
                      At this point the mirror should run but you’ll likely get a “Create a config” message displayed. At which point you should do this.
                      https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                      Then back to your terminal, in the MagicMirror directory, run npm start. That should get your mirror running.
                      Then you can copy your modules, 1 by 1 into the new MagicMirror/modules folder and the entries into your new config.js file.
                      That should do it.
                      • K Offline
                        kurt @Mykle1
                        @Mykle1
                        Hi Mykle1 and Thank you for your help so much!
                        After I followed your help step by step the mirror appeared again, but I was suprised when I put all my modul folder into the “new mm”, that together with the old config. file everything worked out fine. Could’t believe that it was that easy.
                        But still I have two more things where I could’t get a for me clear solution in the forum:
                        DeprecationWarning: sys is deprecated. Use util instead.
                        and the second thing is, that I can`t find the Remote control funktion on my mobile phone, as I found it bevor. Here is the part of my config.
                        Is there the “0.0.0.0” in ipWhitelist missing, and if yes, where to put it?
                        Kurt
                        var config =
                        	electronOptions: {
                        	  ipWhitelist: [
                        		"::fff:0.0.0.0/1",
                        		"::fff:128.0.0.0/2",
                        		"::fff:192.0.0.0/3",
                        		"::fff:224.0.0.0/4",
                        		"127.0.0.1",
                        		"::ffff:127.0.0.1",
                        		"::1"
                          You got lucky. The step by step says one at a time. I’m just saying. :^)
                          Probably, one of the modules you are using has a dependency that is outdated or no longer supported. It has nothing to do with the MM software. You can ignore that warning.
                          This has been discussed lately on the forum. Do a search by clicking the little magnifying glass, top right of the forum window. If you can’t find an answer, come back here and tell me.
                          • K Offline
                            kurt @Mykle1
                            @Mykle1
                            I tried several changes to my ipWhitelist after I read the posts in https://forum.magicmirror.builders/topic/5015/after-update-to-mirror-to-2-1-3-no-working-whitlist
                            but I couldn’t get it right. So I hope you can.
                            Thank you in advance
                            Kurt
                              That’s a lot of pressure. :^)
                              Try this at the very beginning of your config.js file, so it looks like this:
                              var config = {
                              	port: 8080,
                                      address: "0.0.0.0",
                              	ipWhitelist: [], // Set [] to allow all IP addresses.
                              K 1 Reply Last reply Reply Quote 2
                              • K Offline
                                kurt @Mykle1
                                @Mykle1
                                Sorry for feeling presure, but you made it again! Works like a charm!
                                Once again Thank you!
                                Kurt
                                  No worries mate. I’m glad you’re up and running again!
