    pm2 doesn't start after mm update
    18 Posts 4 Posters 11.2k Views 3 Watching
    • K Offline
      kurt
      Hi forum members
      this is what I get after updating the mirror, also after rebooting and restarting.
      Before I upgraded and updated the rpi sucessfully.
      Thank you for your help in advance
      kurt
      pi@raspberrypi:~ $ pm2 start mm
      [PM2] Applying action restartProcessId on app [mm](ids: 0)
      [PM2] [mm](0) ✓
      [PM2] Process successfully started
      │ Name │ mode │ status │ ↺  │ cpu │ memory   │
      │ mm   │ fork │ online │ 29 │ 0%  │ 2.3 MB   │
       Use `pm2 show ` to get more details about an app
      pi@raspberrypi:~ $
      ? K 2 Replies Last reply Reply Quote 0
        A Former User @kurt
        @kurt
        try pm2 log mm
        and
        npm start dev
        What can you see in terminal and browser (and additional dev console window)?
        K 1 Reply Last reply Reply Quote 1
        • K Offline
          kurt @Guest
          @Sean
          hi Sean thank you for your quick response
          this is what I get
          0|mm       |  Please include the following file with any support request:
          0|mm       | npm ERR!     /home/pi/MagicMirror/npm-debug.log
          npm ERR! Linux 4.9.53-v7+
          npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
          npm ERR! node v6.11.4
          npm ERR! npm  v3.10.10
          npm ERR! code ELIFECYCLE
          npm ERR! magicmirror@2.1.3 start: `sh run-start.sh "dev"`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh "dev"'.
          npm ERR! If you do, this is most likely a problem with the magicmirror package,
          npm ERR! not with npm itself.
          npm ERR!     sh run-start.sh "dev"
          npm ERR!     npm bugs magicmirror
          npm ERR! Or if that isn't available, you can get their info via:
          npm ERR!     npm owner ls magicmirror
          pi@raspberrypi:~/MagicMirror $
            A Former User
            https://forum.magicmirror.builders/topic/636/npm-start-dev?page=1
            I think this could be help.
            • K Offline
              kurt @Guest
              @Sean
              well thank you for the link, but I could’t find a simple solution for my problem. The mirror doesn’t start also if I do the
              DISPLAY=:0 npm start
              by VNC
                A Former User @kurt
                • K Offline
                  kurt @kurt
                  @kurt
                  Hi memebers
                  anyone else has an idea to get my mirror back on the screen again?
                  It’s frustrating for me, because the mirror with all the modules was running like a charm, but after that update …
                  Thank you
                    Mykle1 Project Sponsor Module Developer @kurt
                    @kurt said in pm2 doesn’t start after mm update:
                    Until you can fix your updated installation, you can rename your MagicMirror folder and manually install the version of MM that was working for you. At least you’ll have your mirror back
                    • K Offline
                      kurt @Mykle1
                      @Mykle1
                      thank you Mykle1, sounds for me as it is a weekend job.
                      To get things right: first thing is to rename the MagicMirror folder.
                      Second step is to go thru the install routine https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                      Is it than possible to copy/paste the modul-folders from the renamed (old)MMfolder into the new one and and the old config.file?
                      I read your help in https://forum.magicmirror.builders/topic/5081/mm-wont-start-after-install/2
                      but I guess this is a different problem.
                      Thank you
                      • lavolp3L Offline
                        lavolp3 Module Developer
                        Hi Kurt,
                        if I understand correctly your mirror doesn’t show up despite your pm2 “starting” it successfully!?
                        the run-start.sh shell script seems to be the problem.
                        This is the content:
                        if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                        	export DISPLAY=:0 # Set by defaul display
                        fi
                        electron js/electron.js $1
                        I would assume electron has some problem starting…
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
