    Button
    23 Posts 9 Posters 23.2k Views 5 Watching
      dicker182
      Im running MMM-Button Modul und GPIO PIN 9. Everything is working fine. But sometimes my Tagesschauvideo starts without my hand. I did nothing and “pm2 logs mm” sad to me: button pressed. Any idea why this happens?
        dicker182
        Here a picture of my pm2 logs over the night:
        I never pressed the button :(
        • KirAsh4K Offline
          KirAsh4 Moderator
          What’s listening for the button? How is it configured? How is the GPIO pin configured?
          Two possibilities:
          a) the button is faulty
          b) the button is left FLOATING
          A bit of lesson here:
          In order for a button to get registered, the controller needs to be able to detect a voltage differential. Whether that’s 0V to 3.3V, or -5V to 0V. This means that the button needs to be at a known level compared to what the controller is set to register a trigger. If the controller is meant to detect a HIGH, or 1, then the button must be referenced to ground, or 0V. If the controller is set to detect a LOW, or 0, then the button must be referenced to the pin’s high voltage, 3.3V or 5V. This is called pulling the button UP or DOWN. When the button is pushed, it will then register the voltage difference that the controller will recognize.
          A button that has no reference to either a LOW or HIGH is called a FLOATING button. This is bad! A floating button will randomly trigger and the controller will “see” random triggers from it.
          So, how is the button set up, how is the GPIO set up, what’s the code that’s attempting to read the button?
            CGabo @dicker182
            @dicker182
            And to complement @KirAsh4 comment: probably the cause is some voltage / EMI feedback, likely due to the wires and switches.
            From what I see, the Pi does not have protective diodes on the inputs like the AVR chips (and Arduino) do. As a result, feedback to the Pi can probably cause the behaviour which you experienced. Try to switch on/off some lights and electrical devices and see the result.
            To correct this condition, use a combination of current limiting, filtering and shielding.
            You could use for current limiting, a 1K resistor in line with the switch, installed on a PCB inches from the Pi. Also use a low-pass filter made up of another pull-up / pull-down resistor and a capacitor alternatively to the build in PULL-UP and PULL-DOWN resistors of the PI.
            Here are some additional links:
            https://www.raspberrypi.org/forums/viewtopic.php?t=53548
            http://www.digikey.com/en/articles/techzone/2012/apr/protecting-inputs-in-digital-electronics
              dicker182
              Both, thank you for your answer. I will try to give you more informations. The following button from Ebay are used:
              http://www.ebay.de/itm/272129888717?_trksid=p2060353.m2749.l2649&var=570940259633&ssPageName=STRK%3AMEBIDX%3AIT
              Art-Nr. 041
              At first, I tryed the configuration from PtrBld´s howto:
              0_1469563372766_upload-9e2a744a-191c-4bc0-a573-f60bb97298ea
              0_1469563330027_upload-82d3e24f-3dc3-445c-b383-2bfbd97945fd
              https://developer.microsoft.com/de-de/windows/iot/win10/samples/PushButton.htm
              After the false positiv pressed buttons, I tryed the actually config:
              0_1469563460478_upload-01973e92-35f2-4c6e-a8f0-54d28cd740ee https://dracarysdiy.files.wordpress.com/2016/03/button.jpg?w=474
              But the problem is always the same.
              @CGabo, I will have a look to your links tomorrow. But I am not an electrican, so I hope to understand.
              Thank you in advance!
              • KirAsh4K Offline
                KirAsh4 Moderator
                Yeah, that’s a floating button. You need a pull-down on it, a known state, so the rpi can detect a change. You can either do that in software with RPi.GPIO and configuring it as such:
                GPIO.setup(PIN, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
                Or through hardware:
                https://www.cl.cam.ac.uk/projects/raspberrypi/tutorials/robot/buttons_and_switches/
                  dicker182
                  Okay, now I have a script button.py which starts with rc.local after boot.
                  import RPi.GPIO as GPIO
                  import time
                  GPIO.setmode(GPIO.BCM)
                  GPIO.setup(9, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
                  GPIO.cleanup()           # clean up GPIO on normal exit
                  But it´s also not working. Did I miss something?
                  • KirAsh4K Offline
                    KirAsh4 Moderator
                    Different permissions. Your rc.local runs with system privileges, however the MM² task runs as the pi user. You need to have those GPIO setting in the script that the pi user runs.
                      dicker182
                      Okay thanks, the script now starting as user pi.
                      Other question, has my button.py script to run in a loop?
                      EDIT: Okay the message “button pressed” are coming when I turn the floor lights on 0o?
                      • KirAsh4K Offline
                        KirAsh4 Moderator
                        1. Take out that 'GPIO.cleanup()' call that you have. That resets everything you just did above it.
                        2. Button getting triggered because you turning on the floor (?) lights is because that button is still floating, see #1 above.
                        3. I’m assuming the rpi isn’t on the same circuit as the floor (??) lights, a voltage difference could also falsely trigger the button.
