    • cowboysdudeC
      cowboysdude Module Developer @nobita
      @nobita Would have to make them config options which I can do at some point just VERY busy so give me a few days…
        barnosch
        Would be nice. but no hurry.
        I uncommented the UV, Air , Wind and the Barometer thing aswell, because it is not mandatory for me. (and i need to save space ;) )
        but if then a update comes, i need to delete my changes to get the new updates.
        Then do it all over again. No big deal, bnut if it is not necessary anymore… the better.
        So it would be nice to have options for it.
        It’s not a big deal for you, i know, IF you have time.
        • N
          nobita @cowboysdude
          @cowboysdude About airvisual.com ,After register i will get airkey , have 2 question
          1. I would like to know airvisual how to know my location (no lat,long data in register)
          2. what is different US AQI vs China AQI
          Thanks for all help
          • cowboysdudeC
            @nobita said in MMM-NOAA - Another Weather Module:
            Thanks for all help
            1. It gets it from the weather api … I did that way so you didn’t have to put it in…easier
            2. I really have no idea what the difference is between US and China… that’s a question for Airvisual :)
              Reotch2
              2 “hopefully” quick questions:
              1. Is there any way to incorporate the AirVisual icons into this module? The colored text becomes harder to read during periods of “REALLY” bad air quality. (Like during the California fires last week)
              2. My weather icon is showing above the temperature, but most of screenshots show it to the left. Is this a module width issue in my CSS? or something I have set in my config?
              Thanks all.
              • cowboysdudeC
                cowboysdude Module Developer @Reotch2
                @Reotch2
                1. If you can find the icons I can see how it looks. The problem for most is lack of space :)
                2. Not sure what has caused that for you… you are the 1st :) do you have the latest update?
                • N
                  nobita @cowboysdude
                  @cowboysdude About Air Quality Index
                  when data (Air Quality Index) show is number
                  Normally general people not understand what does’t it means
                  If can convert number to easy wording description like as
                  0-50 convert to Good
                  51-100 convert to moderate
                  101-150 convert to Unhealthy
                  How to Convert in module?
                  Thanks for your help
                  • cowboysdudeC
                    @nobita That’s why the numbers are color coded ;) BUT can do what I did with the UV Index and use
                    Good
                    Moderate
                    Unhealthy
                    UNHEATHLY
                    VERY UNHEATHLY
                    • Mykle1M
                      @cowboysdude said in MMM-NOAA - Another Weather Module:
                      Good
                      Moderate
                      Unhealthy
                      UNHEATHLY
                      VERY UNHEATHLY
                      And DEAD
                      • cowboysdudeC
                        @Mykle1 said in MMM-NOAA - Another Weather Module:
                        Good
                        Moderate
                        Unhealthy
                        UNHEATHLY
                        VERY UNHEATHLY
                        And DEAD
                        and The Walking Dead…
                          Reotch2
                          @cowboysdude
                          Thoughts? These are pulled directly off of the air visual site.
                          https://www.airvisual.com/images/aqi4.png (aq1-5)
                          alt text
                          alt text
                          alt text
                          alt text
                          alt text
                          • cowboysdudeC
                            Well depends on what you’re looking for… number and icon, just icon?
                            I would have to adjust the icons because the tab sticking out on the right would be a pain to deal with ;)0_1508811075014_aqi1.png
                            Not opposed to these but the numbers mean more to me because it tells me more… safe is 0 to 50… if the aqi is 49 the green picture really doesn’t tell me anything so let me see what I can do…
                              Reotch2 @cowboysdude
                              @cowboysdude Begging and choosing… I know… but maybe
                              config:
                              Air_qual: “icon”, // icon, text, or both
                              Not many people will likely find themselves in my shoes… But once you get to an Air Quality >300, the dark text was impossible to read on the black background through the mirror.
                              • cowboysdudeC
                                @Reotch2 said in MMM-NOAA - Another Weather Module:
                                config:
                                YES that I know is a problem… for some reason those colors don’t do well on black… so like I said let me see what I can do :)
                                • Mykle1M
                                  • cowboysdudeC
                                    LOL… FREAK
                                    • Mykle1M
                                      @cowboysdude
                                      That’s me after talking to my wife on the phone
                                        @Reotch2
                                        1. Not sure what has caused that for you… you are the 1st :) do you have the latest update?
                                        I did a clean install of the module but still have the same issue. Im running at 90% zoom, so think that’s probably my problem. I’ll tinker later.
                                        • cowboysdudeC
                                          Just a thought… I prefer the numbers… the icons don’t really tell me anything…
                                          Mykle1M R 2 Replies Last reply Reply Quote 2
                                          • Mykle1M
                                            Editorial
                                            It dawned on me, after reading through the 154 posts in this topic, that people may not know what they are asking of a developer. Yes, this is an open format, and you’re supposed ask for a module, ask for features, voice your opinion (that’s what I’m doing) etc… But think about it. What seems like a simple request might mean hours (or more) of work for someone who does this for the fun of it. Someone who worked all day and came home to a list of requests. It’s like being married twice. Now, who the hell wants that? :^)
                                            The beauty of this format is this. You can fork any repo of any module. Now it’s yours! You can make, or attempt to make, any modifications you like. After all, all the work is already done, right?
                                            I think at this point, if you became stuck with a modification, you could ask for help on how to proceed. I did just that the other day. I worked for 4 days on a problem and could not solve it. It was only then that I asked for help and I felt rewarded knowing that I did all of the work. I was also deeply appreciative of help that was given me.
                                            Where am I going with this?
                                            The hell if I know!
                                            Peace!
                                            • 10
                                            • 34
                                            • 35
                                            • 8 / 35
