    690 Posts 77 Posters 3.3m Views 70 Watching
    • Nystro0mN
      Nystro0m @nobita
      @nobita As tbear said. Also make sure your PWK is set corect.
      This is the part of the config we are talking about:
      	apiKey: "YOUR API KEY",    // https://www.wunderground.com/weather/api  select the middle plan...
      	useAir: false,             // set to false if you do not want to use Air Quality Index
      	airKey: "YOUR API KEY",    // IF you want Air Quality Index
      	pws: "KNYELMIR13",         // go here to find your pws: https://www.wunderground.com/wundermap
      You dont need the airKey if you have it set to false. You only need this if you want the Air-data.
      N 1 Reply Last reply
      • N
        nobita @Nystro0m
        @Nystro0m and @tbbear Thanks for your help,it work . I delete first line in config (disabled: false,)
        • N
          nobita @cowboysdude
          @cowboysdude I have three questions
          1. How to Adjust font size and color in this border photo
          2. If I would like don’t display or show some line such as hPa , Amount of Daylight
            how to do?
            3 What is hPa?
          Thanks for your all kind
          • tbbearT
            tbbear Module Developer
            @nobita i can answer ur questions:
            1. u can change font and color in a .css file, but this is own programming
            2. u can configure a lot of features (check read.me) but some makes the style of a module so its part of internal programming
            3. hPa = hectoPascal this is the normal european unit for Airpressure
            Robert the Bear
            • cowboysdudeC
              cowboysdude Module Developer @tbbear
              @tbbear Thank you!
              • cowboysdudeC
                cowboysdude Module Developer @nobita
                @nobita Would have to make them config options which I can do at some point just VERY busy so give me a few days…
                  barnosch
                  Would be nice. but no hurry.
                  I uncommented the UV, Air , Wind and the Barometer thing aswell, because it is not mandatory for me. (and i need to save space ;) )
                  but if then a update comes, i need to delete my changes to get the new updates.
                  Then do it all over again. No big deal, bnut if it is not necessary anymore… the better.
                  So it would be nice to have options for it.
                  It’s not a big deal for you, i know, IF you have time.
                  • N
                    nobita @cowboysdude
                    @cowboysdude About airvisual.com ,After register i will get airkey , have 2 question
                    1. I would like to know airvisual how to know my location (no lat,long data in register)
                    2. what is different US AQI vs China AQI
                    Thanks for all help
                    • cowboysdudeC
                      @nobita said in MMM-NOAA - Another Weather Module:
                      Thanks for all help
                      1. It gets it from the weather api … I did that way so you didn’t have to put it in…easier
                      2. I really have no idea what the difference is between US and China… that’s a question for Airvisual :)
                        Reotch2
                        2 “hopefully” quick questions:
                        1. Is there any way to incorporate the AirVisual icons into this module? The colored text becomes harder to read during periods of “REALLY” bad air quality. (Like during the California fires last week)
                        2. My weather icon is showing above the temperature, but most of screenshots show it to the left. Is this a module width issue in my CSS? or something I have set in my config?
                        Thanks all.
                        • cowboysdudeC
                          cowboysdude Module Developer @Reotch2
                          @Reotch2
                          1. If you can find the icons I can see how it looks. The problem for most is lack of space :)
                          2. Not sure what has caused that for you… you are the 1st :) do you have the latest update?
                          R 1 Reply Last reply
                          • N
                            nobita @cowboysdude
                            @cowboysdude About Air Quality Index
                            when data (Air Quality Index) show is number
                            Normally general people not understand what does’t it means
                            If can convert number to easy wording description like as
                            0-50 convert to Good
                            51-100 convert to moderate
                            101-150 convert to Unhealthy
                            How to Convert in module?
                            • cowboysdudeC
                              @nobita That’s why the numbers are color coded ;) BUT can do what I did with the UV Index and use
                              Good
                              Moderate
                              Unhealthy
                              UNHEATHLY
                              VERY UNHEATHLY
                              Mykle1M 1 Reply Last reply
                              • Mykle1M
                                @cowboysdude said in MMM-NOAA - Another Weather Module:
                                Good
                                Moderate
                                Unhealthy
                                UNHEATHLY
                                VERY UNHEATHLY
                                And DEAD
                                • cowboysdudeC
                                  @Mykle1 said in MMM-NOAA - Another Weather Module:
                                  Good
                                  Moderate
                                  Unhealthy
                                  UNHEATHLY
                                  VERY UNHEATHLY
                                  And DEAD
                                  and The Walking Dead…
                                    Reotch2
                                    @cowboysdude
                                    Thoughts? These are pulled directly off of the air visual site.
                                    https://www.airvisual.com/images/aqi4.png (aq1-5)
                                    alt text
                                    alt text
                                    alt text
                                    alt text
                                    alt text
                                    • cowboysdudeC
                                      Well depends on what you’re looking for… number and icon, just icon?
                                      I would have to adjust the icons because the tab sticking out on the right would be a pain to deal with ;)0_1508811075014_aqi1.png
                                      Not opposed to these but the numbers mean more to me because it tells me more… safe is 0 to 50… if the aqi is 49 the green picture really doesn’t tell me anything so let me see what I can do…
                                        Reotch2 @cowboysdude
                                        @cowboysdude Begging and choosing… I know… but maybe
                                        config:
                                        Air_qual: “icon”, // icon, text, or both
                                        Not many people will likely find themselves in my shoes… But once you get to an Air Quality >300, the dark text was impossible to read on the black background through the mirror.
                                        • cowboysdudeC
                                          @Reotch2 said in MMM-NOAA - Another Weather Module:
                                          config:
                                          YES that I know is a problem… for some reason those colors don’t do well on black… so like I said let me see what I can do :)
                                          • Mykle1M
                                            Reply Quote 2
                                            • 10
                                            • 34
                                            • 35
                                            • 8 / 35
