    690 Posts 77 Posters 2.9m Views 70 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @barnosch
      @barnosch said in MMM-NOAA - Another Weather Module:
      width: 240px; /* was 230px, but it breakes the line then /
      margin-right: 0px;
      margin-left: 60px; /
      new */
      PERFECT!! Thank you! [on dev machine I had to set width at 290]
        LANGUAGE UPDATE
        Thank you to @kurtern84 for adding the Norwegian language!!!
        ** Only need to update if you need!! **
        Download:
        [card:cowboysdude/MMM-NOAA]
        N 2 Replies Last reply Reply Quote 2
        • N Offline
          nobita @cowboysdude
          @cowboysdude Problem after install this module
          when finish install my display only show " GATHERING WEATHER STUFF" on monitor
          What happen and How to solve it,Thanks for your kind
          tbbearT 1 Reply Last reply Reply Quote 0
          • tbbearT Offline
            tbbear Module Developer @nobita
            @nobita said in MMM-NOAA - Another Weather Module:
            Please double check ur 2 diff. apikeys, this normaly happens when their is an error in the NOAA config
            Robert the Bear
            N 1 Reply Last reply Reply Quote 1
            • N Offline
              nobita @tbbear
              @tbbear said in MMM-NOAA - Another Weather Module:
              What does it means ,I don’t understand. give me for detail,Thanks for your answer
              tbbearT Nystro0mN 2 Replies Last reply Reply Quote 0
              • tbbearT Offline
                Ok, so u can enter 2 api keys one is the key from wundermap and the other is the airkey if u are using this so in read.me u can find where u can get the keys
                Robert the Bear
                • Nystro0mN Offline
                  Nystro0m @nobita
                  @nobita As tbear said. Also make sure your PWK is set corect.
                  This is the part of the config we are talking about:
                  	apiKey: "YOUR API KEY",    // https://www.wunderground.com/weather/api  select the middle plan...
                  	useAir: false,             // set to false if you do not want to use Air Quality Index
                  	airKey: "YOUR API KEY",    // IF you want Air Quality Index
                  	pws: "KNYELMIR13",         // go here to find your pws: https://www.wunderground.com/wundermap
                  You dont need the airKey if you have it set to false. You only need this if you want the Air-data.
                  • N Offline
                    nobita @Nystro0m
                    @Nystro0m and @tbbear Thanks for your help,it work . I delete first line in config (disabled: false,)
                    • N Offline
                      nobita @cowboysdude
                      @cowboysdude I have three questions
                      1. How to Adjust font size and color in this border photo
                      2. If I would like don’t display or show some line such as hPa , Amount of Daylight
                        how to do?
                        3 What is hPa?
                      Thanks for your all kind
                      • tbbearT Offline
                        @nobita i can answer ur questions:
                        1. u can change font and color in a .css file, but this is own programming
                        2. u can configure a lot of features (check read.me) but some makes the style of a module so its part of internal programming
                        3. hPa = hectoPascal this is the normal european unit for Airpressure
                        Robert the Bear
                        • 11
                        • 12
                        • 13
                        • 14
                        • 15
                        • 68
                        • 69
                        • 13 / 69
