    • cowboysdudeC
      UPDATE
      1. No longer need to add lat or lon to the config.js
      2. put bottom forecast into table format
        3 weather comes in default language flavors now …it’s automatic!
        4 config option - showForecast: true or false to show or hide bottom forecast
      [Thanks to @Mykle1 for fixing my css!! and @tbbear for fixing my German]
      Tested and Runs on MM 2.1.3!
      See the README on Github
      Download:
      [card:cowboysdude/MMM-NOAA]
      • Mykle1M
        @cowboysdude said in MMM-NOAA - Another Weather Module:
        You’re most welcome bro! :^)
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @tbbear
          @tbbear said in MMM-NOAA - Another Weather Module:
          by the way i think u should be the new default weather app im MM
          Oh snap! Drinks all around! :^)
            barnosch
            another fantastic update!
            Love the forecast!
              barnosch
              Just a little issue:
              Someone else facing this problem with the missing today highest temperature?
              Was in the old version the same.
              Makes no sense for me, since this runs in a loop, and the other stuff is showed correctly.
              Any ideas?
              B cowboysdudeC 2 Replies Last reply Reply Quote 0
              • tbbearT
                tbbear Module Developer
                looks good now only the wind is missing
                Robert the Bear
                  barnosch @barnosch
                  … the next day it was working correctly again… weird
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @barnosch
                    @barnosch said in MMM-NOAA - Another Weather Module:
                    It’s quite possible that the data from the API was missing yesterday. I’ve seen this a few times in other modules.
                    tbbearT 1 Reply Last reply Reply Quote 1
                    • tbbearT
                      tbbear Module Developer @Mykle1
                      @Mykle1 said in MMM-NOAA - Another Weather Module:
                      was the same here
                      Robert the Bear
                      • cowboysdudeC
                        MAJOR UPDATE
                        1. Fixed ALL console errors.
                        2. Style enhancements
                        3. Weather ALERTS - it will show under the forecast if there’s a weather alert.
                        Download:
                        • cowboysdudeC
                          cowboysdude Module Developer @barnosch
                          @barnosch Yes that would be missing data from the api ;)
                            barnosch
                            holy crap.
                            Please stop the continous improvements!
                            just a little hint if you want to have the weather right on the border (only if it is located on top_right)
                            change the MMM-NOAA.css to this
                            .MMM-NOAA {
                            	width: 240px;  /* was 230px, but it breakes the line then */
                            	margin-right: 0px;
                            	margin-left: 60px; /* new */
                            then it should go to the most right.
                            @cowboysdude the blinking is too much for me (already commented out in the css), but the rest is nice as always
                            I guess you have found a new friend: … CSS ;) rofl
                            • cowboysdudeC
                              Thanks @barnosch … This one wasn’t an improvement as much as just fixing all the errors 3 to be exact…ALL FIXED :)
                              You don’t like the flashing? Come on mannnnnnnnn I think it’s cool but actually I only meant to use it in mine… but I was tired when I uploaded the files and used the wrong css file LOL
                              Thanks for the CSS tip but no… me and CSS are not friends hahahhahaha
                              • cowboysdudeC
                                PS changed the css file on github to take out the flashing stuff… :) Well really didn’t take it out… it’s just a config option… if you don’t want it then just leave out of the config because the default is set to false. :)
                                • cowboysdudeC
                                  width: 240px; /* was 230px, but it breakes the line then /
                                  margin-right: 0px;
                                  new */
                                  PERFECT!! Thank you! [on dev machine I had to set width at 290]
                                  • cowboysdudeC
                                    LANGUAGE UPDATE
                                    Thank you to @kurtern84 for adding the Norwegian language!!!
                                    ** Only need to update if you need!! **
                                    Download:
                                    N 2 Replies Last reply Reply Quote 2
                                    • N
                                      nobita @cowboysdude
                                      @cowboysdude Problem after install this module
                                      when finish install my display only show " GATHERING WEATHER STUFF" on monitor
                                      What happen and How to solve it,Thanks for your kind
                                      tbbearT 1 Reply Last reply Reply Quote 0
                                      • tbbearT
                                        tbbear Module Developer @nobita
                                        @nobita said in MMM-NOAA - Another Weather Module:
                                        Please double check ur 2 diff. apikeys, this normaly happens when their is an error in the NOAA config
                                        Robert the Bear
                                        N 1 Reply Last reply Reply Quote 1
                                        • N
                                          nobita @tbbear
                                          What does it means ,I don’t understand. give me for detail,Thanks for your answer
                                          tbbearT Nystro0mN 2 Replies Last reply Reply Quote 0
                                          • tbbearT
                                            Ok, so u can enter 2 api keys one is the key from wundermap and the other is the airkey if u are using this so in read.me u can find where u can get the keys
                                            Robert the Bear
                                            • 34
                                            • 35
                                            • 7 / 35
