      barnosch
      another fantastic update!
      Love the forecast!
        barnosch
        Just a little issue:
        Someone else facing this problem with the missing today highest temperature?
        Was in the old version the same.
        Makes no sense for me, since this runs in a loop, and the other stuff is showed correctly.
        Any ideas?
        B cowboysdudeC 2 Replies Last reply Reply Quote 0
        • tbbearT
          tbbear Module Developer
          looks good now only the wind is missing
          Robert the Bear
            barnosch @barnosch
            … the next day it was working correctly again… weird
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @barnosch
              @barnosch said in MMM-NOAA - Another Weather Module:
              It’s quite possible that the data from the API was missing yesterday. I’ve seen this a few times in other modules.
              tbbearT 1 Reply Last reply Reply Quote 1
              • tbbearT
                tbbear Module Developer @Mykle1
                @Mykle1 said in MMM-NOAA - Another Weather Module:
                was the same here
                Robert the Bear
                • cowboysdudeC
                  MAJOR UPDATE
                  1. Fixed ALL console errors.
                  2. Style enhancements
                  3. Weather ALERTS - it will show under the forecast if there’s a weather alert.
                  Download:
                  [card:cowboysdude/MMM-NOAA]
                  • cowboysdudeC
                    cowboysdude Module Developer @barnosch
                    @barnosch Yes that would be missing data from the api ;)
                      barnosch
                      holy crap.
                      Please stop the continous improvements!
                      just a little hint if you want to have the weather right on the border (only if it is located on top_right)
                      change the MMM-NOAA.css to this
                      .MMM-NOAA {
                      	width: 240px;  /* was 230px, but it breakes the line then */
                      	margin-right: 0px;
                      	margin-left: 60px; /* new */
                      then it should go to the most right.
                      @cowboysdude the blinking is too much for me (already commented out in the css), but the rest is nice as always
                      I guess you have found a new friend: … CSS ;) rofl
                      • cowboysdudeC
                        Thanks @barnosch … This one wasn’t an improvement as much as just fixing all the errors 3 to be exact…ALL FIXED :)
                        You don’t like the flashing? Come on mannnnnnnnn I think it’s cool but actually I only meant to use it in mine… but I was tired when I uploaded the files and used the wrong css file LOL
                        Thanks for the CSS tip but no… me and CSS are not friends hahahhahaha
                        • cowboysdudeC
                          PS changed the css file on github to take out the flashing stuff… :) Well really didn’t take it out… it’s just a config option… if you don’t want it then just leave out of the config because the default is set to false. :)
                          • cowboysdudeC
                            width: 240px; /* was 230px, but it breakes the line then /
                            margin-right: 0px;
                            new */
                            PERFECT!! Thank you! [on dev machine I had to set width at 290]
                            • cowboysdudeC
                              LANGUAGE UPDATE
                              Thank you to @kurtern84 for adding the Norwegian language!!!
                              ** Only need to update if you need!! **
                              Download:
                              N 2 Replies Last reply Reply Quote 2
                              • N
                                nobita @cowboysdude
                                @cowboysdude Problem after install this module
                                when finish install my display only show " GATHERING WEATHER STUFF" on monitor
                                What happen and How to solve it,Thanks for your kind
                                tbbearT 1 Reply Last reply Reply Quote 0
                                • tbbearT
                                  tbbear Module Developer @nobita
                                  @nobita said in MMM-NOAA - Another Weather Module:
                                  Please double check ur 2 diff. apikeys, this normaly happens when their is an error in the NOAA config
                                  Robert the Bear
                                  N 1 Reply Last reply Reply Quote 1
                                  • N
                                    nobita @tbbear
                                    @tbbear said in MMM-NOAA - Another Weather Module:
                                    What does it means ,I don’t understand. give me for detail,Thanks for your answer
                                    tbbearT Nystro0mN 2 Replies Last reply Reply Quote 0
                                    • tbbearT
                                      Ok, so u can enter 2 api keys one is the key from wundermap and the other is the airkey if u are using this so in read.me u can find where u can get the keys
                                      Robert the Bear
                                      • Nystro0mN
                                        Nystro0m @nobita
                                        @nobita As tbear said. Also make sure your PWK is set corect.
                                        This is the part of the config we are talking about:
                                        	apiKey: "YOUR API KEY",    // https://www.wunderground.com/weather/api  select the middle plan...
                                        	useAir: false,             // set to false if you do not want to use Air Quality Index
                                        	airKey: "YOUR API KEY",    // IF you want Air Quality Index
                                        	pws: "KNYELMIR13",         // go here to find your pws: https://www.wunderground.com/wundermap
                                        You dont need the airKey if you have it set to false. You only need this if you want the Air-data.
                                        • N
                                          nobita @Nystro0m
                                          @Nystro0m and @tbbear Thanks for your help,it work . I delete first line in config (disabled: false,)
                                          • N
                                            nobita @cowboysdude
                                            @cowboysdude I have three questions
                                            1. How to Adjust font size and color in this border photo
                                            2. If I would like don’t display or show some line such as hPa , Amount of Daylight
                                              how to do?
                                              3 What is hPa?
                                            Thanks for your all kind
                                            • 34
                                            • 35
                                            • 7 / 35
