    690 Posts 77 Posters 3.3m Views 70 Watching
    • Mykle1M
      @cowboysdude said in MMM-NOAA - Another Weather Module:
      Thanks to @Mykle1 for fixing my css!!
      You’re most welcome bro! :^)
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @tbbear
        @tbbear said in MMM-NOAA - Another Weather Module:
        by the way i think u should be the new default weather app im MM
        Oh snap! Drinks all around! :^)
          barnosch
          another fantastic update!
          Love the forecast!
            barnosch
            Just a little issue:
            Someone else facing this problem with the missing today highest temperature?
            Was in the old version the same.
            Makes no sense for me, since this runs in a loop, and the other stuff is showed correctly.
            Any ideas?
            B cowboysdudeC 2 Replies Last reply
            • tbbearT
              tbbear Module Developer
              looks good now only the wind is missing
              Robert the Bear
                barnosch @barnosch
                … the next day it was working correctly again… weird
                Mykle1M 1 Reply Last reply
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @barnosch
                  @barnosch said in MMM-NOAA - Another Weather Module:
                  It’s quite possible that the data from the API was missing yesterday. I’ve seen this a few times in other modules.
                  tbbearT 1 Reply Last reply
                  • tbbearT
                    tbbear Module Developer @Mykle1
                    @Mykle1 said in MMM-NOAA - Another Weather Module:
                    was the same here
                    Robert the Bear
                    • cowboysdudeC
                      MAJOR UPDATE
                      1. Fixed ALL console errors.
                      2. Style enhancements
                      3. Weather ALERTS - it will show under the forecast if there’s a weather alert.
                      Download:
                      [card:cowboysdude/MMM-NOAA]
                      Reply Quote 2
                      • cowboysdudeC
                        cowboysdude Module Developer @barnosch
                        @barnosch Yes that would be missing data from the api ;)
                          barnosch
                          holy crap.
                          Please stop the continous improvements!
                          just a little hint if you want to have the weather right on the border (only if it is located on top_right)
                          change the MMM-NOAA.css to this
                          .MMM-NOAA {
                          	width: 240px;  /* was 230px, but it breakes the line then */
                          	margin-right: 0px;
                          	margin-left: 60px; /* new */
                          then it should go to the most right.
                          @cowboysdude the blinking is too much for me (already commented out in the css), but the rest is nice as always
                          I guess you have found a new friend: … CSS ;) rofl
                          • cowboysdudeC
                            Thanks @barnosch … This one wasn’t an improvement as much as just fixing all the errors 3 to be exact…ALL FIXED :)
                            You don’t like the flashing? Come on mannnnnnnnn I think it’s cool but actually I only meant to use it in mine… but I was tired when I uploaded the files and used the wrong css file LOL
                            Thanks for the CSS tip but no… me and CSS are not friends hahahhahaha
                            • cowboysdudeC
                              PS changed the css file on github to take out the flashing stuff… :) Well really didn’t take it out… it’s just a config option… if you don’t want it then just leave out of the config because the default is set to false. :)
                              • cowboysdudeC
                                width: 240px; /* was 230px, but it breakes the line then /
                                margin-right: 0px;
                                new */
                                PERFECT!! Thank you! [on dev machine I had to set width at 290]
                                • cowboysdudeC
                                  LANGUAGE UPDATE
                                  Thank you to @kurtern84 for adding the Norwegian language!!!
                                  ** Only need to update if you need!! **
                                  Download:
                                  N 2 Replies Last reply
                                  Reply Quote 2
                                  • N
                                    nobita @cowboysdude
                                    @cowboysdude Problem after install this module
                                    when finish install my display only show " GATHERING WEATHER STUFF" on monitor
                                    What happen and How to solve it,Thanks for your kind
                                    • tbbearT
                                      tbbear Module Developer @nobita
                                      @nobita said in MMM-NOAA - Another Weather Module:
                                      Please double check ur 2 diff. apikeys, this normaly happens when their is an error in the NOAA config
                                      Robert the Bear
                                      N 1 Reply Last reply
                                      • N
                                        nobita @tbbear
                                        What does it means ,I don’t understand. give me for detail,Thanks for your answer
                                        tbbearT Nystro0mN 2 Replies Last reply
                                        • tbbearT
                                          Ok, so u can enter 2 api keys one is the key from wundermap and the other is the airkey if u are using this so in read.me u can find where u can get the keys
                                          Robert the Bear
                                          • Nystro0mN
                                            Nystro0m @nobita
                                            @nobita As tbear said. Also make sure your PWK is set corect.
                                            This is the part of the config we are talking about:
                                            	apiKey: "YOUR API KEY",    // https://www.wunderground.com/weather/api  select the middle plan...
                                            	useAir: false,             // set to false if you do not want to use Air Quality Index
                                            	airKey: "YOUR API KEY",    // IF you want Air Quality Index
                                            	pws: "KNYELMIR13",         // go here to find your pws: https://www.wunderground.com/wundermap
                                            You dont need the airKey if you have it set to false. You only need this if you want the Air-data.
                                            • 34
                                            • 35
                                            • 7 / 35
