    690 Posts 77 Posters 3.3m Views 70 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @tbbear
      @tbbear said in MMM-NOAA - Another Weather Module:
      by the way i think u should be the new default weather app im MM
      Oh snap! Drinks all around! :^)
        barnosch
        another fantastic update!
        Love the forecast!
          barnosch
          Just a little issue:
          Someone else facing this problem with the missing today highest temperature?
          Was in the old version the same.
          Makes no sense for me, since this runs in a loop, and the other stuff is showed correctly.
          Any ideas?
          B cowboysdudeC 2 Replies Last reply
          • tbbearT
            tbbear Module Developer
            looks good now only the wind is missing
            Robert the Bear
              barnosch @barnosch
              … the next day it was working correctly again… weird
              Mykle1M 1 Reply Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @barnosch
                @barnosch said in MMM-NOAA - Another Weather Module:
                It’s quite possible that the data from the API was missing yesterday. I’ve seen this a few times in other modules.
                tbbearT 1 Reply Last reply
                • tbbearT
                  tbbear Module Developer @Mykle1
                  @Mykle1 said in MMM-NOAA - Another Weather Module:
                  was the same here
                  Robert the Bear
                  • cowboysdudeC
                    MAJOR UPDATE
                    1. Fixed ALL console errors.
                    2. Style enhancements
                    3. Weather ALERTS - it will show under the forecast if there’s a weather alert.
                    Download:
                    [card:cowboysdude/MMM-NOAA]
                    Reply Quote 2
                    • cowboysdudeC
                      cowboysdude Module Developer @barnosch
                      @barnosch Yes that would be missing data from the api ;)
                        barnosch
                        holy crap.
                        Please stop the continous improvements!
                        just a little hint if you want to have the weather right on the border (only if it is located on top_right)
                        change the MMM-NOAA.css to this
                        .MMM-NOAA {
                        	width: 240px;  /* was 230px, but it breakes the line then */
                        	margin-right: 0px;
                        	margin-left: 60px; /* new */
                        then it should go to the most right.
                        @cowboysdude the blinking is too much for me (already commented out in the css), but the rest is nice as always
                        I guess you have found a new friend: … CSS ;) rofl
                        • cowboysdudeC
                          Thanks @barnosch … This one wasn’t an improvement as much as just fixing all the errors 3 to be exact…ALL FIXED :)
                          You don’t like the flashing? Come on mannnnnnnnn I think it’s cool but actually I only meant to use it in mine… but I was tired when I uploaded the files and used the wrong css file LOL
                          Thanks for the CSS tip but no… me and CSS are not friends hahahhahaha
                          • cowboysdudeC
                            PS changed the css file on github to take out the flashing stuff… :) Well really didn’t take it out… it’s just a config option… if you don’t want it then just leave out of the config because the default is set to false. :)
                            • cowboysdudeC
                              width: 240px; /* was 230px, but it breakes the line then /
                              margin-right: 0px;
                              new */
                              PERFECT!! Thank you! [on dev machine I had to set width at 290]
                              • cowboysdudeC
                                LANGUAGE UPDATE
                                Thank you to @kurtern84 for adding the Norwegian language!!!
                                ** Only need to update if you need!! **
                                Download:
                                N 2 Replies Last reply
                                Reply Quote 2
                                • N
                                  nobita @cowboysdude
                                  @cowboysdude Problem after install this module
                                  when finish install my display only show " GATHERING WEATHER STUFF" on monitor
                                  What happen and How to solve it,Thanks for your kind
                                  • tbbearT
                                    tbbear Module Developer @nobita
                                    @nobita said in MMM-NOAA - Another Weather Module:
                                    Please double check ur 2 diff. apikeys, this normaly happens when their is an error in the NOAA config
                                    Robert the Bear
                                    N 1 Reply Last reply
                                    • N
                                      nobita @tbbear
                                      What does it means ,I don’t understand. give me for detail,Thanks for your answer
                                      tbbearT Nystro0mN 2 Replies Last reply
                                      • tbbearT
                                        Ok, so u can enter 2 api keys one is the key from wundermap and the other is the airkey if u are using this so in read.me u can find where u can get the keys
                                        Robert the Bear
                                        • Nystro0mN
                                          Nystro0m @nobita
                                          @nobita As tbear said. Also make sure your PWK is set corect.
                                          This is the part of the config we are talking about:
                                          	apiKey: "YOUR API KEY",    // https://www.wunderground.com/weather/api  select the middle plan...
                                          	useAir: false,             // set to false if you do not want to use Air Quality Index
                                          	airKey: "YOUR API KEY",    // IF you want Air Quality Index
                                          	pws: "KNYELMIR13",         // go here to find your pws: https://www.wunderground.com/wundermap
                                          You dont need the airKey if you have it set to false. You only need this if you want the Air-data.
                                          • N
                                            nobita @Nystro0m
                                            @Nystro0m and @tbbear Thanks for your help,it work . I delete first line in config (disabled: false,)
                                            • 34
                                            • 35
                                            • 7 / 35
