    690 Posts 77 Posters 3.3m Views 70 Watching
    • tbbearT
      tbbear Module Developer @nobita
      @nobita said in MMM-NOAA - Another Weather Module:
      @cowboysdude Problem after install this module
      when finish install my display only show " GATHERING WEATHER STUFF" on monitor
      What happen and How to solve it,Thanks for your kind
      Please double check ur 2 diff. apikeys, this normaly happens when their is an error in the NOAA config
      Robert the Bear
      N 1 Reply Last reply
      • N
        nobita @tbbear
        @tbbear said in MMM-NOAA - Another Weather Module:
        What does it means ,I don’t understand. give me for detail,Thanks for your answer
        tbbearT Nystro0mN 2 Replies Last reply
        • tbbearT
          Ok, so u can enter 2 api keys one is the key from wundermap and the other is the airkey if u are using this so in read.me u can find where u can get the keys
          Robert the Bear
          • Nystro0mN
            Nystro0m @nobita
            @nobita As tbear said. Also make sure your PWK is set corect.
            This is the part of the config we are talking about:
            	apiKey: "YOUR API KEY",    // https://www.wunderground.com/weather/api  select the middle plan...
            	useAir: false,             // set to false if you do not want to use Air Quality Index
            	airKey: "YOUR API KEY",    // IF you want Air Quality Index
            	pws: "KNYELMIR13",         // go here to find your pws: https://www.wunderground.com/wundermap
            You dont need the airKey if you have it set to false. You only need this if you want the Air-data.
            • N
              nobita @Nystro0m
              @Nystro0m and @tbbear Thanks for your help,it work . I delete first line in config (disabled: false,)
              • N
                nobita @cowboysdude
                @cowboysdude I have three questions
                1. How to Adjust font size and color in this border photo
                2. If I would like don’t display or show some line such as hPa , Amount of Daylight
                  how to do?
                  3 What is hPa?
                Thanks for your all kind
                • tbbearT
                  @nobita i can answer ur questions:
                  1. u can change font and color in a .css file, but this is own programming
                  2. u can configure a lot of features (check read.me) but some makes the style of a module so its part of internal programming
                  3. hPa = hectoPascal this is the normal european unit for Airpressure
                  Robert the Bear
                  • cowboysdudeC
                    cowboysdude Module Developer @tbbear
                    @tbbear Thank you!
                    • cowboysdudeC
                      cowboysdude Module Developer @nobita
                      @nobita Would have to make them config options which I can do at some point just VERY busy so give me a few days…
                        barnosch
                        Would be nice. but no hurry.
                        I uncommented the UV, Air , Wind and the Barometer thing aswell, because it is not mandatory for me. (and i need to save space ;) )
                        but if then a update comes, i need to delete my changes to get the new updates.
                        Then do it all over again. No big deal, bnut if it is not necessary anymore… the better.
                        So it would be nice to have options for it.
                        It’s not a big deal for you, i know, IF you have time.
                        • N
                          nobita @cowboysdude
                          @cowboysdude About airvisual.com ,After register i will get airkey , have 2 question
                          1. I would like to know airvisual how to know my location (no lat,long data in register)
                          2. what is different US AQI vs China AQI
                          Thanks for all help
                          • cowboysdudeC
                            Thanks for all help
                            1. It gets it from the weather api … I did that way so you didn’t have to put it in…easier
                            2. I really have no idea what the difference is between US and China… that’s a question for Airvisual :)
                              Reotch2
                              2 “hopefully” quick questions:
                              1. Is there any way to incorporate the AirVisual icons into this module? The colored text becomes harder to read during periods of “REALLY” bad air quality. (Like during the California fires last week)
                              2. My weather icon is showing above the temperature, but most of screenshots show it to the left. Is this a module width issue in my CSS? or something I have set in my config?
                              Thanks all.
                              • cowboysdudeC
                                cowboysdude Module Developer @Reotch2
                                @Reotch2
                                1. If you can find the icons I can see how it looks. The problem for most is lack of space :)
                                2. Not sure what has caused that for you… you are the 1st :) do you have the latest update?
                                R 1 Reply Last reply
                                • N
                                  nobita @cowboysdude
                                  @cowboysdude About Air Quality Index
                                  when data (Air Quality Index) show is number
                                  Normally general people not understand what does’t it means
                                  If can convert number to easy wording description like as
                                  0-50 convert to Good
                                  51-100 convert to moderate
                                  101-150 convert to Unhealthy
                                  How to Convert in module?
                                  • cowboysdudeC
                                    @nobita That’s why the numbers are color coded ;) BUT can do what I did with the UV Index and use
                                    Good
                                    Moderate
                                    Unhealthy
                                    UNHEATHLY
                                    VERY UNHEATHLY
                                    Mykle1M 1 Reply Last reply
                                    • Mykle1M
                                      @cowboysdude said in MMM-NOAA - Another Weather Module:
                                      Good
                                      Moderate
                                      Unhealthy
                                      UNHEATHLY
                                      VERY UNHEATHLY
                                      And DEAD
                                      • cowboysdudeC
                                        @Mykle1 said in MMM-NOAA - Another Weather Module:
                                        Good
                                        Moderate
                                        Unhealthy
                                        UNHEATHLY
                                        VERY UNHEATHLY
                                        And DEAD
                                        and The Walking Dead…
                                          Reotch2
                                          @cowboysdude
                                          Thoughts? These are pulled directly off of the air visual site.
                                          https://www.airvisual.com/images/aqi4.png (aq1-5)
                                          alt text
                                          alt text
                                          alt text
                                          alt text
                                          alt text
                                          • cowboysdudeC
                                            Well depends on what you’re looking for… number and icon, just icon?
                                            I would have to adjust the icons because the tab sticking out on the right would be a pain to deal with ;)0_1508811075014_aqi1.png
                                            Not opposed to these but the numbers mean more to me because it tells me more… safe is 0 to 50… if the aqi is 49 the green picture really doesn’t tell me anything so let me see what I can do…
                                            • 34
                                            • 35
                                            • 7 / 35
