    690 Posts 77 Posters 3.3m Views 70 Watching
    • tbbearT
      tbbear Module Developer
      @nobita i can answer ur questions:
      1. u can change font and color in a .css file, but this is own programming
      2. u can configure a lot of features (check read.me) but some makes the style of a module so its part of internal programming
      3. hPa = hectoPascal this is the normal european unit for Airpressure
      Robert the Bear
      • cowboysdudeC
        cowboysdude Module Developer @tbbear
        @tbbear Thank you!
        • cowboysdudeC
          cowboysdude Module Developer @nobita
          @nobita Would have to make them config options which I can do at some point just VERY busy so give me a few days…
            barnosch
            Would be nice. but no hurry.
            I uncommented the UV, Air , Wind and the Barometer thing aswell, because it is not mandatory for me. (and i need to save space ;) )
            but if then a update comes, i need to delete my changes to get the new updates.
            Then do it all over again. No big deal, bnut if it is not necessary anymore… the better.
            So it would be nice to have options for it.
            It’s not a big deal for you, i know, IF you have time.
            • N
              nobita @cowboysdude
              @cowboysdude About airvisual.com ,After register i will get airkey , have 2 question
              1. I would like to know airvisual how to know my location (no lat,long data in register)
              2. what is different US AQI vs China AQI
              Thanks for all help
              • cowboysdudeC
                @nobita said in MMM-NOAA - Another Weather Module:
                Thanks for all help
                1. It gets it from the weather api … I did that way so you didn’t have to put it in…easier
                2. I really have no idea what the difference is between US and China… that’s a question for Airvisual :)
                N 1 Reply Last reply
                  Reotch2
                  2 “hopefully” quick questions:
                  1. Is there any way to incorporate the AirVisual icons into this module? The colored text becomes harder to read during periods of “REALLY” bad air quality. (Like during the California fires last week)
                  2. My weather icon is showing above the temperature, but most of screenshots show it to the left. Is this a module width issue in my CSS? or something I have set in my config?
                  Thanks all.
                  • cowboysdudeC
                    cowboysdude Module Developer @Reotch2
                    @Reotch2
                    1. If you can find the icons I can see how it looks. The problem for most is lack of space :)
                    2. Not sure what has caused that for you… you are the 1st :) do you have the latest update?
                    R 1 Reply Last reply
                    • N
                      nobita @cowboysdude
                      @cowboysdude About Air Quality Index
                      when data (Air Quality Index) show is number
                      Normally general people not understand what does’t it means
                      If can convert number to easy wording description like as
                      0-50 convert to Good
                      51-100 convert to moderate
                      101-150 convert to Unhealthy
                      How to Convert in module?
                      Thanks for your help
                      • cowboysdudeC
                        @nobita That’s why the numbers are color coded ;) BUT can do what I did with the UV Index and use
                        Good
                        Moderate
                        Unhealthy
                        UNHEATHLY
                        VERY UNHEATHLY
                        Mykle1M 1 Reply Last reply
                        • Mykle1M
                          @cowboysdude said in MMM-NOAA - Another Weather Module:
                          Good
                          Moderate
                          Unhealthy
                          UNHEATHLY
                          VERY UNHEATHLY
                          And DEAD
                          • cowboysdudeC
                            @Mykle1 said in MMM-NOAA - Another Weather Module:
                            Good
                            Moderate
                            Unhealthy
                            UNHEATHLY
                            VERY UNHEATHLY
                            And DEAD
                            and The Walking Dead…
                              Reotch2
                              @cowboysdude
                              Thoughts? These are pulled directly off of the air visual site.
                              https://www.airvisual.com/images/aqi4.png (aq1-5)
                              alt text
                              alt text
                              alt text
                              alt text
                              alt text
                              • cowboysdudeC
                                Well depends on what you’re looking for… number and icon, just icon?
                                I would have to adjust the icons because the tab sticking out on the right would be a pain to deal with ;)0_1508811075014_aqi1.png
                                Not opposed to these but the numbers mean more to me because it tells me more… safe is 0 to 50… if the aqi is 49 the green picture really doesn’t tell me anything so let me see what I can do…
                                  Reotch2 @cowboysdude
                                  @cowboysdude Begging and choosing… I know… but maybe
                                  config:
                                  Air_qual: “icon”, // icon, text, or both
                                  Not many people will likely find themselves in my shoes… But once you get to an Air Quality >300, the dark text was impossible to read on the black background through the mirror.
                                  • cowboysdudeC
                                    @Reotch2 said in MMM-NOAA - Another Weather Module:
                                    config:
                                    YES that I know is a problem… for some reason those colors don’t do well on black… so like I said let me see what I can do :)
                                    • Mykle1M
                                      Reply Quote 2
                                      • cowboysdudeC
                                        LOL… FREAK
                                        • Mykle1M
                                          @cowboysdude
                                          That’s me after talking to my wife on the phone
                                          Reply Quote 2
                                            @Reotch2
                                            1. Not sure what has caused that for you… you are the 1st :) do you have the latest update?
                                            I did a clean install of the module but still have the same issue. Im running at 90% zoom, so think that’s probably my problem. I’ll tinker later.
                                            • 10
                                            • 34
                                            • 35
                                            • 8 / 35
