    690 Posts 77 Posters 3.3m Views 70 Watching
    • MrBorgM
      MrBorg @cowboysdude
      @cowboysdude Well it didn’t sovle my issue. Still having wrong Danish signs. Did this to install your update:
      1: cd ~/MagicMirror/modules/MMM-NOAA
      2: git pull
      3: git reset --hard
      When I get it to work I will send you an tranlation update for some of the Danish words
      • cowboysdudeC
        cowboysdude Module Developer @MrBorg
        @MrBorg THAT would be awesome!! Thank you
        MrBorgM 1 Reply Last reply
        • N
          nobita @cowboysdude
          @cowboysdude About Translate file
          at photo (at arrow sign) Why this current weather is not to chinese language?
          • cowboysdudeC
            cowboysdude Module Developer @nobita
            @nobita I will look at that when I get home from work :)
            Odd because I just tried it and this is what I got: {using zh_cn in my config.js}
            N 1 Reply Last reply
            • N
              nobita @cowboysdude
              @cowboysdude Thanks so much
              • N
                nobita @nobita
                @nobita said in MMM-NOAA - Another Weather Module:
                WSW : What does it means?
                ? 1 Reply Last reply
                  A Former User @nobita
                  @nobita West-South-West
                  • N
                    nobita @Guest
                    @Sean Thanks so much
                    • MrBorgM
                      MrBorg @cowboysdude
                      @cowboysdude Wow this one is difficult. I’m not sure where I can adjust this. You see my MMM-module part and my translation-files below (notice also “Lør” is correct but “Søn” is wrong).
                      • Mykle1M
                        You guys are certainly keeping him busy. :-)
                        tbbearT 1 Reply Last reply
                        Reply Quote 2
                        • tbbearT
                          tbbear Module Developer @Mykle1
                          @Mykle1 he might get bored … lol
                          Robert the Bear
                          Mykle1M 1 Reply Last reply
                          Reply Quote 2
                          • cowboysdudeC
                            Being bored…is not an issue :) My new board just came for my 3d printer sooooooo …
                            The last one caught on fire…yes caught on fire… so my new one and my mosfet is here and I’m gonna be playing with that tonight :)
                            Thanks @tbbear and @sean for giving a hand :)
                            As @tbbear pointed out there may be some issues with the translation files not working correctly… the pi is a funny beast to say the least :)
                            SO if you are having issues I would take your translation file and use your keyboard in your language and re-type it that seems to be solving a lot of problems :)
                            • MrBorgM
                              MrBorg @MrBorg
                              @MrBorg Well now it is solved (thanks to @tbbear) editing translation file in nano did the trick. So now it looks so fine (perfect from my OCD point of view)
                              And i have attached a new corrected da.json file with some minor improvements.
                              [0_1509744254495_da.json](Uploader 100%)
                              Reply Quote 3
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @tbbear
                                @tbbear said in MMM-NOAA - Another Weather Module:
                                Him? Not a chance! :-)
                                • cowboysdudeC
                                  @MrBorg Thank you!! @tbbear for solving this riddle! :)
                                  Your file didn’t upload but that’s okay just go to github and copy over the da.json file and do a pull request then I’ll approve it :)
                                  Now back to my 3d printer repairs :) LOL
                                  • MrBorgM
                                    MrBorg @cowboysdude
                                    @cowboysdude Hi Uploads are disabled.
                                    File uploads require push access to this repository.
                                    Mykle1M cowboysdudeC 2 Replies Last reply
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @MrBorg
                                      @MrBorg
                                      Fork the repo
                                      Make your changes
                                      Make a Pull Request
                                      • cowboysdudeC
                                        @MrBorg You can edit a file and do a pull request :)
                                        • N
                                          nobita @cowboysdude
                                          @cowboysdude, How to Convert name of month (in number) to short or long word like as
                                          1= Jan,2=Feb …
                                          Thanks for all your hints many time, because I’m beginer not expert in program
                                          • cowboysdudeC
                                            @nobita You’re welcome :)
                                            I would have to change the code to do that…That would take a bit of rewriting…
                                            • 10
                                            • 11
                                            • 12
                                            • 34
                                            • 35
                                            • 10 / 35
