WiFi drops and reconnects regularly...
the only “original” RaspPi3 powersupply they sell has 5V/2.5A
But i guess a 2A is good to go.
If the old one has some problems or drops the voltage from time to time, the issues you have can happen easily.
Just try with the other one?
You are using the internal Wifi or with a external USB-Wlan Dongle? -
Mykle1 Project Sponsor Module Developerlast edited by Mykle1 Nov 8, 2017, 12:24 PM Nov 8, 2017, 12:22 PM
Have you?
Disable WiFi Power Save
Disable power saving
For Raspberry Pi 3
Edit /etc/network/interfacessudo nano /etc/network/interfaces
Add the following line under the wlan0 sectionwireless-power off
Reboot your PIsudo reboot
Honestly I think this happens when you update the Pi…I don’t believe it’s MM doing this.
Just a short information, after changing the powersupply to 5V/2A instead 5V/1,5A it now seems stable. I now only get a rekeying-message every 10mins in the syslog, which I suppose is my FritzBox. :)
I’m using the internal WiFi - apparently withou power saving off. But seems OK.
@binderth I found that 2A isn’t enough for the pi3, when under heavy load it would fail. The raspberry 2,5A power unit is highly recommended.
@barnosch
I am also having the same issue. I tried this method, But still i am facing this issue. Any other solutions.
