    WiFi drops and reconnects regularly...
    9 Posts 6 Posters 4.2k Views 3 Watching
      binderth
      Hi there,
      I happen to find some strange entries in my logs. I’m not sure, if they are MM2 related, but perhaps someone can Point me in the right direction.
      I’m running MM2 (latest) on a raspberry Pi 3 model B (Hardware BCM2835, Revision a02082) and seemingly the WiFi disconnects on a regular base (sometimes around an hour, sometimes 20min) and at times won’t reconnect:
      /var/log/messages
      Nov  8 07:39:09 MagicMirror2 kernel: [ 3490.304393] usb 1-1: USB disconnect, device number 6
      Nov  8 07:39:09 MagicMirror2 kernel: [ 3490.304419] usb 1-1.1: USB disconnect, device number 7
      Nov  8 07:39:09 MagicMirror2 kernel: [ 3490.304833] smsc95xx 1-1.1:1.0 enxb827eb395566: unregister 'smsc95xx' usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet
      Nov  8 07:39:09 MagicMirror2 kernel: [ 3490.304927] smsc95xx 1-1.1:1.0 enxb827eb395566: hardware isn't capable of remote wakeup
      Nov  8 07:39:09 MagicMirror2 kernel: [ 3490.554214] Indeed it is in host mode hprt0 = 00021501
      Nov  8 07:39:10 MagicMirror2 kernel: [ 3490.754068] usb 1-1: new high-speed USB device number 8 using dwc_otg
      Nov  8 07:39:10 MagicMirror2 kernel: [ 3490.754318] Indeed it is in host mode hprt0 = 00001101
      Nov  8 07:39:10 MagicMirror2 kernel: [ 3490.984336] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
      Nov  8 07:39:10 MagicMirror2 kernel: [ 3490.984355] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      Nov  8 07:39:10 MagicMirror2 kernel: [ 3490.985385] hub 1-1:1.0: USB hub found
      Nov  8 07:39:10 MagicMirror2 kernel: [ 3490.985487] hub 1-1:1.0: 5 ports detected
      Nov  8 07:39:10 MagicMirror2 kernel: [ 3491.324025] usb 1-1.1: new high-speed USB device number 9 using dwc_otg
      Nov  8 07:39:10 MagicMirror2 kernel: [ 3491.465152] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
      Nov  8 07:39:10 MagicMirror2 kernel: [ 3491.465186] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      Nov  8 07:39:10 MagicMirror2 kernel: [ 3491.469158] smsc95xx v1.0.5
      Nov  8 07:39:10 MagicMirror2 mtp-probe: checking bus 1, device 9: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
      Nov  8 07:39:10 MagicMirror2 mtp-probe: bus: 1, device: 9 was not an MTP device
      Nov  8 07:39:10 MagicMirror2 kernel: [ 3491.568590] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:39:55:66
      Nov  8 07:39:10 MagicMirror2 kernel: [ 3491.600462] smsc95xx 1-1.1:1.0 enxb827eb395566: renamed from eth0
      Nov  8 07:39:11 MagicMirror2 kernel: [ 3491.976302] smsc95xx 1-1.1:1.0 enxb827eb395566: hardware isn't capable of remote wakeup
      Nov  8 07:39:11 MagicMirror2 kernel: [ 3491.976719] IPv6: ADDRCONF(NETDEV_UP): enxb827eb395566: link is not ready
      Nov  8 08:33:09 MagicMirror2 kernel: [ 6730.310923] usb 1-1: USB disconnect, device number 8
      Nov  8 08:33:09 MagicMirror2 kernel: [ 6730.310952] usb 1-1.1: USB disconnect, device number 9
      Nov  8 08:33:09 MagicMirror2 kernel: [ 6730.311373] smsc95xx 1-1.1:1.0 enxb827eb395566: unregister 'smsc95xx' usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet
      Nov  8 08:33:09 MagicMirror2 kernel: [ 6730.311472] smsc95xx 1-1.1:1.0 enxb827eb395566: hardware isn't capable of remote wakeup
      Nov  8 08:33:09 MagicMirror2 kernel: [ 6730.580643] Indeed it is in host mode hprt0 = 00021501
      Nov  8 08:33:10 MagicMirror2 kernel: [ 6730.790635] usb 1-1: new high-speed USB device number 10 using dwc_otg
      Nov  8 08:33:10 MagicMirror2 kernel: [ 6730.790867] Indeed it is in host mode hprt0 = 00001101
      Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.021176] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
      Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.021204] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.022487] hub 1-1:1.0: USB hub found
      Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.022594] hub 1-1:1.0: 5 ports detected
      Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.340631] usb 1-1.1: new high-speed USB device number 11 using dwc_otg
      Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.470918] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
      Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.470937] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.474357] smsc95xx v1.0.5
      Nov  8 08:33:10 MagicMirror2 mtp-probe: checking bus 1, device 11: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
      Nov  8 08:33:10 MagicMirror2 mtp-probe: bus: 1, device: 11 was not an MTP device
      Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.565397] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:39:55:66
      Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.595975] smsc95xx 1-1.1:1.0 enxb827eb395566: renamed from eth0
      Nov  8 08:33:11 MagicMirror2 kernel: [ 6731.864586] smsc95xx 1-1.1:1.0 enxb827eb395566: hardware isn't capable of remote wakeup
      Nov  8 08:33:11 MagicMirror2 kernel: [ 6731.865091] IPv6: ADDRCONF(NETDEV_UP): enxb827eb395566: link is not ready
      /var/log/syslog
      Nov  8 07:39:09 MagicMirror2 dhcpcd[384]: enxb827eb395566: removing interface
      Nov  8 07:39:11 MagicMirror2 dhcpcd[384]: enxb827eb395566: waiting for carrier
      Somebody got the same errors?
        binderth @barnosch
        @barnosch hmmm… Thanks! I just replaced the 1,5A with a 2A one as I lack a 2,5A one. I’ll Keep that in mind, though!
          barnosch
          First step i would do, is a replacement with another power supply.
          Does it have enough power. At least 2.5A is recommened i guess!?
          I guess it is not related to the MM itself, its a Pi problem.
          B M 2 Replies Last reply Reply Quote 1
            binderth @barnosch
              barnosch
              the only “original” RaspPi3 powersupply they sell has 5V/2.5A
              But i guess a 2A is good to go.
              If the old one has some problems or drops the voltage from time to time, the issues you have can happen easily.
              Just try with the other one?
              You are using the internal Wifi or with a external USB-Wlan Dongle?
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @binderth
                @binderth
                Have you?
                Disable WiFi Power Save
                Disable power saving
                For Raspberry Pi 3
                Edit /etc/network/interfaces
                sudo nano /etc/network/interfaces
                Add the following line under the wlan0 section
                wireless-power off
                Reboot your PI
                sudo reboot
                • cowboysdudeC
                  Honestly I think this happens when you update the Pi…I don’t believe it’s MM doing this.
                    binderth
                    Just a short information, after changing the powersupply to 5V/2A instead 5V/1,5A it now seems stable. I now only get a rekeying-message every 10mins in the syslog, which I suppose is my FritzBox. :)
                    I’m using the internal WiFi - apparently withou power saving off. But seems OK.
                    B 1 Reply Last reply Reply Quote 2
                      broberg Project Sponsor @binderth
                      @binderth I found that 2A isn’t enough for the pi3, when under heavy load it would fail. The raspberry 2,5A power unit is highly recommended.
                        mukulb @barnosch
                        @barnosch
                        I am also having the same issue. I tried this method, But still i am facing this issue. Any other solutions.
