mm-system-temperature
13 Posts 5 Posters 7.0k Views 4 Watching
    PointPubMedia
    I’m always having a fetching data… is it possible that the plugin can’t handle Celcius temperature from the system command ?
    • K Offline
      kckndrgn
      The module worked for me, running on RPi 3. The plugin is just executing a script, then stripping off extra data.
      What system are you running the module on?
        PointPubMedia
        It’s always “System temperature: fetching…”
        M 1 Reply Last reply Aug 1, 2016, 8:53 PM Reply Quote 0
          MichMich Admin @PointPubMedia
          @PointPubMedia I’m the autor of that module (and the MagicMirror² system), so I might be able to help.
          On what Raspberry Pi version are you running the module? What version of Node.js are you running? What version of the OS are you running?
          I personally use the celsius temp as well, so that shouldn’t be the issue.
            PointPubMedia
            guys… don’t know why… but it’s working AFTER a reboot… sorry to wasting your time ;)
              PointPubMedia
              @MichMich Would need some help about CSS with your module…
              I would like to use it at bottom_bar
              with
              div.mmm-systemtemperature div.module-content {
              text-align: right;
              And also change the fontsize and dimmed to false… like I did with the MMM-ip module
                PointPubMedia
                Can we change the prepend string without touching the code directly ?
                K 1 Reply Last reply Aug 1, 2016, 9:52 PM Reply Quote 0
                • K Offline
                  kckndrgn @PointPubMedia
                  @PointPubMedia Yes, the prepend string is in the config
                          module: 'mmm-systemtemperature',
                          position: 'top_center', // This can be any of the regions.
                          classes: 'small dimmed', // Add your own styling. Optional.
                             **prepend: 'your string'**
                    PointPubMedia
                    prepend in the config is not working. That change nothing…
                    K 1 Reply Last reply Aug 2, 2016, 12:58 AM Reply Quote 0
                    • K Offline
                      @PointPubMedia
                      Sorry,
                      the correct syntax is prependString per the documentation:
                      prependString: 'Pi 3 Temp: '
                      worked on my system.
