    mm-system-temperature
    13 Posts 5 Posters 8.5k Views 4 Watching
    • K Offline
      kckndrgn
      The module worked for me, running on RPi 3. The plugin is just executing a script, then stripping off extra data.
      What system are you running the module on?
        PointPubMedia
        It’s always “System temperature: fetching…”
        MichMichM 1 Reply Last reply Reply Quote 0
        • MichMichM Offline
          MichMich @PointPubMedia
          @PointPubMedia I’m the autor of that module (and the MagicMirror² system), so I might be able to help.
          On what Raspberry Pi version are you running the module? What version of Node.js are you running? What version of the OS are you running?
          I personally use the celsius temp as well, so that shouldn’t be the issue.
            PointPubMedia
            guys… don’t know why… but it’s working AFTER a reboot… sorry to wasting your time ;)
              PointPubMedia
              @MichMich Would need some help about CSS with your module…
              I would like to use it at bottom_bar
              with
              div.mmm-systemtemperature div.module-content {
              text-align: right;
              And also change the fontsize and dimmed to false… like I did with the MMM-ip module
                PointPubMedia
                Can we change the prepend string without touching the code directly ?
                • K Offline
                  kckndrgn @PointPubMedia
                  @PointPubMedia Yes, the prepend string is in the config
                          module: 'mmm-systemtemperature',
                          position: 'top_center', // This can be any of the regions.
                          classes: 'small dimmed', // Add your own styling. Optional.
                             **prepend: 'your string'**
                    PointPubMedia
                    prepend in the config is not working. That change nothing…
                    • K Offline
                      @PointPubMedia
                      Sorry,
                      the correct syntax is prependString per the documentation:
                      prependString: 'Pi 3 Temp: '
                      worked on my system.
                        Peter
                        Please, can somebody tell me where I can find this module?
                        I have been searching …
                        Peter
                          Mykle1 Project Sponsor Module Developer @Peter
                          @Peter
                          https://github.com/MichMich/mmm-systemtemperature
                            Peter
                            Thanks!
                            Why could I not find it?
                            Peter
