    mm-system-temperature
    13 Posts 5 Posters 8.6k Views 4 Watching
      PointPubMedia
      I’m always having a fetching data… is it possible that the plugin can’t handle Celcius temperature from the system command ?
      • K Offline
        kckndrgn
        The module worked for me, running on RPi 3. The plugin is just executing a script, then stripping off extra data.
        What system are you running the module on?
          PointPubMedia
          It’s always “System temperature: fetching…”
          MichMichM 1 Reply Last reply Reply Quote 0
          • MichMichM Offline
            MichMich @PointPubMedia
            @PointPubMedia I’m the autor of that module (and the MagicMirror² system), so I might be able to help.
            On what Raspberry Pi version are you running the module? What version of Node.js are you running? What version of the OS are you running?
            I personally use the celsius temp as well, so that shouldn’t be the issue.
              PointPubMedia
              guys… don’t know why… but it’s working AFTER a reboot… sorry to wasting your time ;)
                PointPubMedia
                @MichMich Would need some help about CSS with your module…
                I would like to use it at bottom_bar
                with
                div.mmm-systemtemperature div.module-content {
                text-align: right;
                And also change the fontsize and dimmed to false… like I did with the MMM-ip module
                  PointPubMedia
                  Can we change the prepend string without touching the code directly ?
                  • K Offline
                    kckndrgn @PointPubMedia
                    @PointPubMedia Yes, the prepend string is in the config
                            module: 'mmm-systemtemperature',
                            position: 'top_center', // This can be any of the regions.
                            classes: 'small dimmed', // Add your own styling. Optional.
                               **prepend: 'your string'**
                      PointPubMedia
                      prepend in the config is not working. That change nothing…
                      • K Offline
                        @PointPubMedia
                        Sorry,
                        the correct syntax is prependString per the documentation:
                        prependString: 'Pi 3 Temp: '
                        worked on my system.
                          Peter
                          Please, can somebody tell me where I can find this module?
                          I have been searching …
                          Peter
                            Mykle1 Project Sponsor Module Developer @Peter
                            @Peter
                            https://github.com/MichMich/mmm-systemtemperature
                              Peter
                              Thanks!
                              Why could I not find it?
                              Peter
