    MMM-EARTH
    Scheduled Pinned Locked Moved Education
    34 Posts 7 Posters 26.3k Views 7 Watching
    • Mykle1M
      @cowboysdude said in MMM-EARTH (Watch the sunlit side of Earth as it rotates):
      Really awesome job!!!
      Now I would consider it awesome. Why? Well, it captured a unique perspective of the recent Total Solar Eclipse and I could not be more pleased. We’ve all seen the pictures of the sun eclipsed by the moon’s transit. A truly awe inspiring event. But who has seen the shadow that passed over the earth? MMM-EARTH, that’s who.
      Ok, so I’m bragging a little, but come on! It’s friggin cool!
      0_1503533429323_a.JPG 0_1503533439650_bb.JPG 0_1503533457418_cc.JPG 0_1503533463388_dd.JPG 0_1503533470807_ee.JPG 0_1503533477603_ff.JPG 0_1503533485825_gg.JPG 0_1503533492020_hh.JPG
      • cowboysdudeC
        @Mykle1 That is really cool!
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @cowboysdude said in MMM-EARTH (Captured unique perspective of Solar Eclipse August 21, 2017):
          Thank you!
          Again, I would like to thank you @cowboysdude and @strawberry-3-141 for your assistance when I was stuck developing this module.
          • Mykle1M
            Download:
            [card:mykle1/MMM-EARTH]
            Update Version 1.0.1
            NASA changed their data without consulting me first. :^)
            Thanks to JohnB7777 for creating the issue and bringing it to my attention.
            And a tremendous Thank You to @cowboysdude for the fix and the pull request.
            So, a git pull in your MMM-EARTH directory will correct the problem.
            • Mykle1M
              In light of the recent hurricane activity plaguing the Caribbean and the Eastern United States, I did a quick check of conditions using MMM-EARTH. You can see the storm paths and their development.
              • Mykle1M
                Download:
                Update Version 1.0.2
                NASA changed their data AGAIN without consulting me AGAIN.
                The nerve!
                So, once again, a git pull in your MMM-EARTH directory should set things to right, AGAIN. :^)
                  Peter
                  Another old Noob trying to learn …
                  I just started RPI and MM last week, changed some basic things in my config file.
                  But EARTH will not turn (it is static).
                  Can somebody have a look?
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	language: "nl",
                  	timeFormat: 24,
                  	units: "metric",
                      			module: "MMM-EARTH",
                      			position: "top_center",
                          		mode: "Natural",
                          		rotateInterval: 15000,
                          		MaxWidth: "20%",
                          		MaxHeight: "20%",
                  			module: "updatenotification",
                  			position: "top_bar"
                  			module: "clock",
                  			position: "top_left"
                  			header: "Feestdagen",
                  						symbol: "calendar-check-o ",
                  						url: "https://www.mozilla.org/media/caldata/DutchHolidays.ics"
                  			module: "",
                  			position: "lower_third"
                  			module: "currentweather",
                  				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                  				appid: "Xxxxxxxxxx"
                  			module: "weatherforecast",
                  			header: "Weersvoorspelling",
                  				appid: "Xxxxxxxx"
                  			module: "newsfeed",
                  			position: "bottom_bar",
                  				feeds: [
                  						title: "Nu.nl",
                  						url: "http://www.nu.nl/rss/Algemeen"
                  				showSourceTitle: true,
                  				showPublishDate: true
                  Thanks!
                  Peter
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @Peter
                    @Peter
                    Hello Peter. It is not your config that is causing the EARTH not to spin. I just loaded your config and it rotates the EARTH every 15 seconds as per rotateInterval: 15000,. Have you waited 15 seconds?
                    Are you expecting it to rotate more quickly? Or is it not updating at all?
                    One thing I did notice about your config:
                    			module: "",
                    An empty module name
                    Also, you should remove your API keys before you post on the forum. You can remove yours from here by clicking the three dots at the bottom right of your post and choose EDIT.
                    Lastly, I see you are using 20% MaxWidth and MaxHeight in MMM-EARTH, and that’s just fine, but you can also choose mode: "naturalThumb", at 100% to achieve the same thing with less system load on your Pi. But let’s get you fixed up first. :-)
                    P 1 Reply Last reply
                      Peter @Mykle1
                      @Mykle1 thanks!
                      It does not look like rotating.
                      It goes black (fades to black) and comes back again.
                      I will look at the other things you mention.
                      Peter
                      • Mykle1M
                        @Peter
                        Pay close attention. When it fades and comes back, is the picture different? It should be. Watch a few times to see please. If you do not want the fade in/ fade out then you can add this to your config entry for EARTH
                        animationSpeed: 0,
                          Peter @Mykle1
                          @Mykle1 I removed the empty module name and the ID.
                          Earth is turning, but I will take your advice to turn off the fading!
                          I am learning every minute!
                          Great!
                          Peter
                          • Mykle1M
                            @Peter
                            Yes, keep your API keys private. Use the config options to your liking. If you like the fade, keep it. It’s up to you.
                            We’re all learning, Peter. At least, I hope so. I’m glad it’s working for you now. Peace! :-)
                            • Mykle1M
                              I think this is amazing. MMM-EARTH has captured Hurricane Florence as moves across the Caribbean, taking aim at the Carolinas.
                              • Mykle1M
                                Announcement
                                Anyone that experienced problems with MMM-EARTH yesterday can breathe a sigh of relief. It was not the module that was at fault. It was the API. Whatever problems they were having seem to be over. The module is now working as intended.
                                justjim1220J 1 Reply Last reply
                                • justjim1220J
                                  justjim1220 Module Developer @Mykle1
                                  @mykle1
                                  YAY!!! :face_with_tears_of_joy: :face_with_tears_of_joy:
                                  Jim Hallock - 1995
                                  • F
                                    fulmik Project Sponsor
                                    Is anyone else having a loading issue today with this module? I just put it on the other day and today after a reboot it stopped loading, all i see is hello mother earth.
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @fulmik
                                      @fulmik said in MMM-EARTH:
                                      This same thing happened 4 days ago and was resolved at the API source. Obviously, they are having some troubles on their end. I’m sorry about that. I will make another announcement when the API corrects the issue.
                                      • F
                                        Thank you very much , love the module.
                                        Mykle1M 2 Replies Last reply
                                        • Mykle1M
                                          Thanks dude. I love it as well. Been on my mirror since it was born. I’ll keep you posted
                                          • Mykle1M
                                            @fulmik
                                            I looked into the data coming from the API. You can tell by the abundance of “null” responses that something is amiss with their data. The image: key shows an image name but the date: key is null, making it impossible to retrieve the image as the module code is written. Hopefully, they will fix the data as quickly as they did last week.
