    Electron CPU usage
    247 Posts 46 Posters 639.2k Views 42 Watching
      Mykle1 Project Sponsor Module Developer @rovarma
      @rovarma said in Electron CPU usage:
      The solution is to use Raspbian Jessie for now and ignore Stretch until this is fixed in Electron.
      This has already been determined in the contents of this topic. The combination of Pi, OS and Electron versions for best performance is clearly stated above and has solved the CPU issue for many users since this topic started 3 months ago. :-)
      • T Offline
        TheBogueRat
        I gave up on MM2 last year because of how bad the transitions looked. Recently I had need of something like MM and decided to try again and had the same CPU load and terrible transitions until I found this thread.
        With the latest Raspbian Stretch, MM2, and a downgrade of electron to 1.4.15 it works far better. Barely a spike on the CPU meter.
        This thread is far too long. Considering the impact of this solution, it really should be in the FAQ on github. The only reason I even noticed this thread is due to the weekly Email summary.
        Mykle1M 1 Reply Last reply Reply Quote 3
          Mykle1 Project Sponsor Module Developer @TheBogueRat
          @TheBogueRat said in Electron CPU usage:
          If it were shorter then the results may never have come to light and many other users like yourself may have given up due to the CPU issue
          Perhaps, but I have nothing to do with such things. I’m just an old dude that wanted to know what was causing the issue and with the help of some fine people I think we did just that. However, I do appreciate the recognition and thank you on behalf of everyone that participated in the testing.
          • MichMichM Offline
            MichMich
            For anyone running into this issue, run the following command from your MagicMirror folder:
             npm install electron@1.4.15
            S 1 Reply Last reply Reply Quote 4
              bhepler Module Developer
              One more data point: The Pi behind my office mirror was doing okay, until I enabled the MMM-Snow module. Short version is that I had to downgrade Electron to 1.4.15 but now it’s running pretty well with 50 snowflakes.
                schlachtkreuzer6 @MichMich
                @MichMich
                > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
                > node install.js
                magicmirror@2.1.3 /home/pi/MagicMirror
                ├── electron@1.4.15  invalid
                └── UNMET PEER DEPENDENCY stylelint@7.13.0 invalid
                npm WARN grunt-stylelint@0.9.0 requires a peer of stylelint@^8.0.0 but none was installed.
                npm WARN stylelint-config-recommended@1.0.0 requires a peer of stylelint@^8.0.0 but none was installed.
                npm WARN stylelint-config-standard@17.0.0 requires a peer of stylelint@^8.0.0 but none was installed.
                B T 2 Replies Last reply Reply Quote 0
                  bhepler Module Developer @schlachtkreuzer6
                  @schlachtkreuzer6 I had the same error when I downgraded. However, it did install and I am able to run the Magic Mirror process. I am getting a temperature warning. I’ll experiment a bit to see if I can narrow that down.
                    schlachtkreuzer6 @bhepler
                    @bhepler Yeah funny!
                    But you´re right. It install electron and the temperature sinks from 82-85°C to 52-55°C and the animations are smooth. Only the error massage is strange!
                      @schlachtkreuzer6 Technically, they’re not error messages. They’re warnings. If they become serious, then they will be promoted to errors.
                      • T Offline
                        Tourpe @schlachtkreuzer6
                        @MichMich Got a similar issue as reported by @schlachtkreuzer6, unfortunately I now have a black screen when starting. Logs show “WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 54”. Any suggest on how to revert?
                        Update: Managed to successfully revert back but doing a " npm install electron".
                        • Sandy2503S Offline
                          Sandy2503
                          i have a problem at downgrading:
                          pi@magicmirror:~ $ cd ~/MagicMirror
                          pi@magicmirror:~/MagicMirror $  npm install electron@1.4.15
                          > node install.js
                          - @types/node@7.0.43 node_modules/@types/node
                          └── electron@1.4.15  invalid
                          How can i fix that ?
                          Sandy2503
                          • cruunnerrC Offline
                            cruunnerr
                            Hey guys,
                            (first, sorry for my english. i hope you understand what i am trying to tell^^)
                            i have got the same problem as u all.
                            So i tried to fix it with using MagicMirror 2.1.0 and electron 1.4.15
                            Unfortunately i am not the best programer, so sometimes i don’t know if i’m doing anything right.
                            Well, i tried the option as shown in this thread on page 18 (https://forum.magicmirror.builders/post/28875)
                            That gave me some npm errors when i type “npm start”.
                            So i tried to use this guide: https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
                            But it gave me the same errors.
                            Step by step i did:
                            1. rename the original MM-Folder to “MagicMirror_OLD”
                            2. Downloaded this https://github.com/MichMich/MagicMirror/archive/v2.1.0.zip
                            3. extract it and rename it to “MagicMirror”
                            4. cd in this folder and type “npm install”
                            5. after installing was done i typed “npm start” and got this:
                            pi@MagicMirror:~ $ cd ~/MagicMirror/
                            pi@MagicMirror:~/MagicMirror $ npm start
                            > magicmirror@2.1.0 start /home/pi/MagicMirror
                            > electron js/electron.js
                            npm ERR! Linux 4.9.59-v7+
                            npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                            npm ERR! node v6.12.2
                            npm ERR! npm  v3.10.10
                            npm ERR! code ELIFECYCLE
                            npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
                            npm ERR! Exit status 1
                            npm ERR!
                            npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
                            npm ERR! If you do, this is most likely a problem with the magicmirror package,
                            npm ERR! not with npm itself.
                            npm ERR!     electron js/electron.js
                            npm ERR!     npm bugs magicmirror
                            npm ERR! Or if that isn't available, you can get their info via:
                            npm ERR!     npm owner ls magicmirror
                            npm ERR!     /home/pi/MagicMirror/npm-debug.log
                            Another time i tried as shown on page 18. it was showing me, that i was using electron 1.4.15, but when i typed the “npm start” it shows me the same message as above.
                            i don’t know what to do :( would be quite nice, if u guys could invest some time to solve my problem together. thank you very much :)
                            edit:
                            the “npm-debug.log” is here:
                            1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
                            2 info using npm@3.10.10
                            3 info using node@v6.12.2
                            4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                            5 info lifecycle magicmirror@2.1.0~prestart: magicmirror@2.1.0
                            6 silly lifecycle magicmirror@2.1.0~prestart: no script for prestart, continuing
                            7 info lifecycle magicmirror@2.1.0~start: magicmirror@2.1.0
                            8 verbose lifecycle magicmirror@2.1.0~start: unsafe-perm in lifecycle true
                            9 verbose lifecycle magicmirror@2.1.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                            10 verbose lifecycle magicmirror@2.1.0~start: CWD: /home/pi/MagicMirror
                            11 silly lifecycle magicmirror@2.1.0~start: Args: [ ‘-c’, ‘electron js/electron.js’ ]
                            12 silly lifecycle magicmirror@2.1.0~start: Returned: code: 1 signal: null
                            13 info lifecycle magicmirror@2.1.0~start: Failed to exec start script
                            14 verbose stack Error: magicmirror@2.1.0 start: electron js/electron.js
                            14 verbose stack Exit status 1
                            14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                            14 verbose stack at emitTwo (events.js:106:13)
                            14 verbose stack at EventEmitter.emit (events.js:191:7)
                            14 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                            14 verbose stack at ChildProcess.emit (events.js:191:7)
                            14 verbose stack at maybeClose (internal/child_process.js:920:16)
                            14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
                            15 verbose pkgid magicmirror@2.1.0
                            16 verbose cwd /home/pi/MagicMirror
                            17 error Linux 4.9.59-v7+
                            18 error argv “/usr/bin/node” “/usr/bin/npm” “start”
                            19 error node v6.12.2
                            20 error npm v3.10.10
                            21 error code ELIFECYCLE
                            22 error magicmirror@2.1.0 start: electron js/electron.js
                            22 error Exit status 1
                            23 error Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.
                            23 error Make sure you have the latest version of node.js and npm installed.
                            23 error If you do, this is most likely a problem with the magicmirror package,
                            23 error not with npm itself.
                            23 error Tell the author that this fails on your system:
                            23 error electron js/electron.js
                            23 error You can get information on how to open an issue for this project with:
                            23 error npm bugs magicmirror
                            23 error Or if that isn’t available, you can get their info via:
                            23 error npm owner ls magicmirror
                            23 error There is likely additional logging output above.
                            24 verbose exit [ 1, true ]
                              Sandy2503
                              @cruunnerr - I `ve done it !
                              without previous Unistall
                              i have downgraded with:
                              sudo npm install -g electron@1.4.15
                              Sandy2503
                                cruunnerr
                                Well,
                                i had MM 2.1.2 installed, so i needed to use the 2.1.0 way…
                                but i actually got it running with “DISPLAY=:0 npm start”
                                then i just copied the installed modules folders to the new directory and copied my “old” config.js but that didn’t work.
                                i actually install the 3rd party modules manual. hopefully my old config.js will work then.
                                But thank you anyway
                                edit:
                                so,
                                i got MM2.1.0 running with electron 1.4.15
                                have had a few problems, but now all works great.
                                • K Offline
                                  knubbl
                                  Bad issue with electron. When i downgrade to 1.4.15 the default calender module does not work
                                  ok…calendar works fine
                                    cruunnerr
                                    Cause i didn’t want to run 2.1.0 and also got many errors every time i looked in the logs, i decided to do a fresh install and try again.
                                    So i just installed a fresh Raspbian stretch lite and followed this guide: https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
                                    after the first start i got 80-85% cpu usage just playing the default modules.
                                    so i went into my MagicMirror folder and just typed “npm install electron@1.4.15”.
                                    It said that the version seems to be invalid, but after a reboot i tooled a look in the
                                    “/home/pi/MagicMirror/node_modules/electron/dist/version”
                                    and saw a 1.4.15 shown.
                                    thats all.
                                    so in my experience its just the electron version needed to downgrade. Neither the OS nor the MagicMirror Version needs to be downgraded.
                                    Loaded up a video: https://youtu.be/ak_mEMuLpYc
                                    shows “nmon-stats” while adding Traffic- and News-Module via Remote Control
                                    Still shows peaks when animation comes, but its fluety anyway
                                    • WeatherGeekW Offline
                                      WeatherGeek
                                      I have been having the issue, thanks so much for all the detailed information! I am going to do a fresh install with Jessy and downgrade Electron and MM2.
                                        mattn
                                        First off, apologies for the necro! But I had to reinstall MM this weekend and came across this same issue. After a fair bit of time reinstalling/googling, I managed to resolve it by adding the following to /etc/environment
                                        ELECTRON_FORCE_WINDOW_MENU_BAR=1
                                        So thought I’d post it here in case anyone else experiences this.
                                        I’ve had the default install running for a while since adding the fix and my load avg has dropped from 6+ to “0.00, 0.02, 0.02” and electron seems to peak at around 7% every ~30s for about 2s. The rest of the time it isn’t even visible in top’s list.
                                        credit to reddit: https://www.reddit.com/r/kde/comments/5x9t7j/electron_app_high_cpu_usage/
                                        Edit: After adding my usual modules, electron’s CPU usage has gone up to a fairly constant ~9% across 3 processes.
                                        top - 00:04:33 up 25 min,  3 users,  load average: 0.06, 0.13, 0.13
                                        Tasks: 156 total,   2 running, 154 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  2.0 us,  0.4 sy,  0.0 ni, 97.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        KiB Mem:    947732 total,   486072 used,   461660 free,    26476 buffers
                                        KiB Swap:   102396 total,        0 used,   102396 free.   240288 cached Mem
                                          PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
                                         1387 pi        20   0  300260  98384  55840 S   4.9 10.4   0:45.48 electron
                                         1394 pi        20   0  286500  68700  49420 S   2.0  7.2   0:23.08 electron
                                         1358 pi        20   0  436408  78528  57656 S   1.0  8.3   0:19.25 electron
                                        Edit2: Left it running over night, and it’s stable:
                                        top - 07:51:22 up  8:12,  3 users,  load average: 0.24, 0.23, 0.17
                                        Tasks: 153 total,   1 running, 152 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  2.1 us,  0.3 sy,  0.0 ni, 97.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        KiB Mem:    947732 total,   543280 used,   404452 free,    34664 buffers
                                        KiB Swap:   102396 total,        0 used,   102396 free.   271040 cached Mem
                                         1798 pi        20   0  301180  99652  56580 S   5.3 10.5  22:54.84 electron
                                         1805 pi        20   0  321060  79368  50868 S   2.6  8.4  11:36.49 electron
                                         1770 pi        20   0  480972  82744  58648 S   1.0  8.7   7:20.91 electron
                                        D M 2 Replies Last reply Reply Quote 3
                                          Doum @mattn
                                          @mattn I am pretty new to linux/raspbian… I do not have any file/folder under /etc with the name environment?
                                          Should i create a file and add this line in? add it somewhere else?
                                          • N Offline
                                            nparab
                                            Thanks v.much to everyone on this forum. I just downgraded Electron to 1.4.15, without downgrading either MagicMirror2 or my OS, and my CPU usage and temperature are significantly down. But I’m facing yet another problem because of this downgrading of Electron. My MMM-PIR-Sensor module is giving this error:
                                            App threw an error during load
                                            Error: Module version mismatch. Expected 50, got 54.
                                                at Error (native)
                                                at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
                                                at Object.Module._extensions..node (module.js:583:18)
                                                at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
                                                at Module.load (module.js:473:32)
                                                at tryModuleLoad (module.js:432:12)
                                                at Function.Module._load (module.js:424:3)
                                                at Module.require (module.js:483:17)
                                                at require (internal/module.js:20:19)
                                                at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:81:44)
                                                at Error (native)
                                            Any help on fixing this would be appreciated.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
