    Electron CPU usage
    247 Posts 46 Posters 668.3k Views 42 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @schlachtkreuzer6
      @schlachtkreuzer6
      I’m not using the Pi anymore. The one Pi mirror I have will stay using Jessie, MM v2.1.0 and electron v1.4.15. It doesn’t make any sense to change it. It runs flawlessly.
      My other boards can handle the newest MM and electron so I use those there.
      schlachtkreuzer6S 1 Reply Last reply
      • schlachtkreuzer6S
        schlachtkreuzer6 @Mykle1
        @Mykle1 okay, which alternatives do you use? (:
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @schlachtkreuzer6 said in Electron CPU usage:
          Me, personally? I’ve taken to old laptop boards. Basically, a 10-12 year old laptop will outperform any Pi, in all categories. ubuntu installed turns a POS laptop into a killer MM macine and the laptops that old are as inexpensive as a new Pi, or free in some cases.
          Here are some things that others are using
          https://forum.magicmirror.builders/topic/4513/stronger-raspberry-pi-3-alternatives.
          Laptop mirror
          https://forum.magicmirror.builders/topic/4930/vanity-mirror-thy-name-is-woman-using-laptop
          • cowboysdudeC
            Just my two cents but as people want more from the mirror then “You look Good” compliments and here’s the weather the pi is going to fall further behind.
            Some of these modules are intensive and need the power to run…
            SO many are looking into small computer boards, like myself, mini-itx with a real processor and memory. Mine also uses an SSD… so power and speed are good :)
              rovarma
              After performing a clean install of the MagicMirror on Raspbian Stretch I was also running into this issue: high CPU usage, stuttering in the UI when animations are playing, etc. I didn’t really expect the MagicMirror to perform well in the first place (since it’s browser-based) but this was worse than I expected, so I did some investigation. The problem is twofold:
              • The version of Electron (1.6.2) does not work on Stretch. Many users (including me) work around this by manually installing Electron 1.7.9, which does support Stretch. After this, the MagicMirror can be installed as normal (aside from some bugs in the install script, which I fixed locally) and will appear to work.
              • However: Electron 1.7.9 does not have support for hardware acceleration on the Raspberry Pi (1.6.2) does. So normal rendering will appear to work fine, but anything to do with animation (and alpha blending in particular) will slow to a crawl.
              The solution is to use Raspbian Jessie for now and ignore Stretch until this is fixed in Electron.
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @rovarma
                @rovarma said in Electron CPU usage:
                This has already been determined in the contents of this topic. The combination of Pi, OS and Electron versions for best performance is clearly stated above and has solved the CPU issue for many users since this topic started 3 months ago. :-)
                • T
                  TheBogueRat
                  I gave up on MM2 last year because of how bad the transitions looked. Recently I had need of something like MM and decided to try again and had the same CPU load and terrible transitions until I found this thread.
                  With the latest Raspbian Stretch, MM2, and a downgrade of electron to 1.4.15 it works far better. Barely a spike on the CPU meter.
                  This thread is far too long. Considering the impact of this solution, it really should be in the FAQ on github. The only reason I even noticed this thread is due to the weekly Email summary.
                  Reply Quote 3
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @TheBogueRat
                    @TheBogueRat said in Electron CPU usage:
                    If it were shorter then the results may never have come to light and many other users like yourself may have given up due to the CPU issue
                    Perhaps, but I have nothing to do with such things. I’m just an old dude that wanted to know what was causing the issue and with the help of some fine people I think we did just that. However, I do appreciate the recognition and thank you on behalf of everyone that participated in the testing.
                    • MichMichM
                      MichMich
                      For anyone running into this issue, run the following command from your MagicMirror folder:
                       npm install electron@1.4.15
                      Reply Quote 4
                      • bheplerB
                        bhepler Module Developer
                        One more data point: The Pi behind my office mirror was doing okay, until I enabled the MMM-Snow module. Short version is that I had to downgrade Electron to 1.4.15 but now it’s running pretty well with 50 snowflakes.
                        • schlachtkreuzer6S
                          schlachtkreuzer6 @MichMich
                          @MichMich
                          > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
                          > node install.js
                          magicmirror@2.1.3 /home/pi/MagicMirror
                          ├── electron@1.4.15  invalid
                          └── UNMET PEER DEPENDENCY stylelint@7.13.0 invalid
                          npm WARN grunt-stylelint@0.9.0 requires a peer of stylelint@^8.0.0 but none was installed.
                          npm WARN stylelint-config-recommended@1.0.0 requires a peer of stylelint@^8.0.0 but none was installed.
                          npm WARN stylelint-config-standard@17.0.0 requires a peer of stylelint@^8.0.0 but none was installed.
                          bheplerB T 2 Replies Last reply
                          • bheplerB
                            bhepler Module Developer @schlachtkreuzer6
                            @schlachtkreuzer6 I had the same error when I downgraded. However, it did install and I am able to run the Magic Mirror process. I am getting a temperature warning. I’ll experiment a bit to see if I can narrow that down.
                            • schlachtkreuzer6S
                              schlachtkreuzer6 @bhepler
                              @bhepler Yeah funny!
                              But you´re right. It install electron and the temperature sinks from 82-85°C to 52-55°C and the animations are smooth. Only the error massage is strange!
                              bheplerB 1 Reply Last reply
                              • bheplerB
                                @schlachtkreuzer6 Technically, they’re not error messages. They’re warnings. If they become serious, then they will be promoted to errors.
                                • T
                                  Tourpe @schlachtkreuzer6
                                  @MichMich Got a similar issue as reported by @schlachtkreuzer6, unfortunately I now have a black screen when starting. Logs show “WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 54”. Any suggest on how to revert?
                                  Update: Managed to successfully revert back but doing a " npm install electron".
                                  • Sandy2503S
                                    Sandy2503
                                    i have a problem at downgrading:
                                    pi@magicmirror:~ $ cd ~/MagicMirror
                                    pi@magicmirror:~/MagicMirror $  npm install electron@1.4.15
                                    > node install.js
                                    - @types/node@7.0.43 node_modules/@types/node
                                    └── electron@1.4.15  invalid
                                    How can i fix that ?
                                    Sandy2503
                                    • cruunnerrC
                                      cruunnerr
                                      Hey guys,
                                      (first, sorry for my english. i hope you understand what i am trying to tell^^)
                                      i have got the same problem as u all.
                                      So i tried to fix it with using MagicMirror 2.1.0 and electron 1.4.15
                                      Unfortunately i am not the best programer, so sometimes i don’t know if i’m doing anything right.
                                      Well, i tried the option as shown in this thread on page 18 (https://forum.magicmirror.builders/post/28875)
                                      That gave me some npm errors when i type “npm start”.
                                      So i tried to use this guide: https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
                                      But it gave me the same errors.
                                      Step by step i did:
                                      1. rename the original MM-Folder to “MagicMirror_OLD”
                                      2. Downloaded this https://github.com/MichMich/MagicMirror/archive/v2.1.0.zip
                                      3. extract it and rename it to “MagicMirror”
                                      4. cd in this folder and type “npm install”
                                      5. after installing was done i typed “npm start” and got this:
                                      pi@MagicMirror:~ $ cd ~/MagicMirror/
                                      pi@MagicMirror:~/MagicMirror $ npm start
                                      > magicmirror@2.1.0 start /home/pi/MagicMirror
                                      > electron js/electron.js
                                      npm ERR! Linux 4.9.59-v7+
                                      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                                      npm ERR! node v6.12.2
                                      npm ERR! npm  v3.10.10
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
                                      npm ERR! Exit status 1
                                      npm ERR!
                                      npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
                                      npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                      npm ERR! not with npm itself.
                                      npm ERR!     electron js/electron.js
                                      npm ERR!     npm bugs magicmirror
                                      npm ERR! Or if that isn't available, you can get their info via:
                                      npm ERR!     npm owner ls magicmirror
                                      npm ERR!     /home/pi/MagicMirror/npm-debug.log
                                      Another time i tried as shown on page 18. it was showing me, that i was using electron 1.4.15, but when i typed the “npm start” it shows me the same message as above.
                                      i don’t know what to do :( would be quite nice, if u guys could invest some time to solve my problem together. thank you very much :)
                                      edit:
                                      the “npm-debug.log” is here:
                                      1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
                                      2 info using npm@3.10.10
                                      3 info using node@v6.12.2
                                      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                                      5 info lifecycle magicmirror@2.1.0~prestart: magicmirror@2.1.0
                                      6 silly lifecycle magicmirror@2.1.0~prestart: no script for prestart, continuing
                                      7 info lifecycle magicmirror@2.1.0~start: magicmirror@2.1.0
                                      8 verbose lifecycle magicmirror@2.1.0~start: unsafe-perm in lifecycle true
                                      9 verbose lifecycle magicmirror@2.1.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                      10 verbose lifecycle magicmirror@2.1.0~start: CWD: /home/pi/MagicMirror
                                      11 silly lifecycle magicmirror@2.1.0~start: Args: [ ‘-c’, ‘electron js/electron.js’ ]
                                      12 silly lifecycle magicmirror@2.1.0~start: Returned: code: 1 signal: null
                                      13 info lifecycle magicmirror@2.1.0~start: Failed to exec start script
                                      14 verbose stack Error: magicmirror@2.1.0 start: electron js/electron.js
                                      14 verbose stack Exit status 1
                                      14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                                      14 verbose stack at emitTwo (events.js:106:13)
                                      14 verbose stack at EventEmitter.emit (events.js:191:7)
                                      14 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                                      14 verbose stack at ChildProcess.emit (events.js:191:7)
                                      14 verbose stack at maybeClose (internal/child_process.js:920:16)
                                      14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
                                      15 verbose pkgid magicmirror@2.1.0
                                      16 verbose cwd /home/pi/MagicMirror
                                      17 error Linux 4.9.59-v7+
                                      18 error argv “/usr/bin/node” “/usr/bin/npm” “start”
                                      19 error node v6.12.2
                                      20 error npm v3.10.10
                                      21 error code ELIFECYCLE
                                      22 error magicmirror@2.1.0 start: electron js/electron.js
                                      22 error Exit status 1
                                      23 error Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.
                                      23 error Make sure you have the latest version of node.js and npm installed.
                                      23 error If you do, this is most likely a problem with the magicmirror package,
                                      23 error not with npm itself.
                                      23 error Tell the author that this fails on your system:
                                      23 error electron js/electron.js
                                      23 error You can get information on how to open an issue for this project with:
                                      23 error npm bugs magicmirror
                                      23 error Or if that isn’t available, you can get their info via:
                                      23 error npm owner ls magicmirror
                                      23 error There is likely additional logging output above.
                                      24 verbose exit [ 1, true ]
                                      • Sandy2503S
                                        Sandy2503
                                        @cruunnerr - I `ve done it !
                                        without previous Unistall
                                        i have downgraded with:
                                        sudo npm install -g electron@1.4.15
                                        Sandy2503
                                        • cruunnerrC
                                          cruunnerr
                                          Well,
                                          i had MM 2.1.2 installed, so i needed to use the 2.1.0 way…
                                          but i actually got it running with “DISPLAY=:0 npm start”
                                          then i just copied the installed modules folders to the new directory and copied my “old” config.js but that didn’t work.
                                          i actually install the 3rd party modules manual. hopefully my old config.js will work then.
                                          But thank you anyway
                                          edit:
                                          so,
                                          i got MM2.1.0 running with electron 1.4.15
                                          have had a few problems, but now all works great.
                                          • K
                                            knubbl
                                            Bad issue with electron. When i downgrade to 1.4.15 the default calender module does not work
                                            ok…calendar works fine
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
