    Magic Mirror with AI
    64 Posts 14 Posters 83.4k Views 18 Watching
    • cowboysdudeC
      THAT. IS. AWESOME!
      Looking forward to the code :)
      akshaybahadur21A 1 Reply Last reply
        17saiiqb
        WOW, that is incredible! How did you get uber and youtube to work at all? And is the AI based on google assistant? Or Alexa? Or anything at all?
        Anyways I can’t wait for the code
        • akshaybahadur21A
          akshaybahadur21 @17saiiqb
          @17saiiqb This isn’t based on Google Assistant or Alexa. Although we have used google’s text to speech library. Will be posting the code soon.
          • F
            fischi87
            thats really awesome!!! im also interested on your code. i would like to see it soon!!!
            greet job!!
            • cruunnerrC
              cruunnerr
              o.0
              dammit… Congrats man. Very very well done.
              akshaybahadur21A 2 Replies Last reply
                cyberphox
                wow…following…and looking forward to code too!! might have to re-do my mirror for this!
                • cowboysdudeC
                  Would be really nice to see it…but I don’t see it happening… I think this was just a setup.
                  Reply Quote 2
                  • akshaybahadur21A
                    akshaybahadur21 @cowboysdude
                    @cowboysdude Hi thanks for the skepticism. We are used to it. The code and the final video shall be uploaded soon. Check the link for documentation
                    https://github.com/akshaybahadur21/Smart_Mirror
                    cowboysdudeC Mykle1M 2 Replies Last reply
                    Reply Quote 2
                    • akshaybahadur21A
                      akshaybahadur21 @cruunnerr
                      @cruunnerr @cyberphox - Thanks for the encouragement and support. We won’t let you down.
                      • cowboysdudeC
                        cowboysdude Module Developer @akshaybahadur21
                        @akshaybahadur21 Too many have come through with empty promises of ‘things that are’…so I’m hoping you prove me wrong :)
                        Will users be able to add other modules as is the case now?
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @akshaybahadur21
                          @akshaybahadur21 said in Magic Mirror with AI:
                          This will run on a Pi?
                          • akshaybahadur21A
                            akshaybahadur21 @Mykle1
                            @Mykle1 - It won’t be able to run on a pi with the current configurations. Although we are looking for a less heavy design which can run smoothly on a pi. All the computation is done in the cloud to make it as lightweight as possible. But still I wont recommend it running on pi
                            • akshaybahadur21A
                              @cowboysdude - Thanks. Yes, the users can add all the existing modules with this one. And a simple voice command will activate or deactivate them. We have used an existing email module to appear and disappear with voice command.
                              • akshaybahadur21A
                                akshaybahadur21 @cyberphox
                                @cyberphox - We can redo your mirror for you… :D
                                cowboysdudeC C 2 Replies Last reply
                                • cowboysdudeC
                                  @akshaybahadur21 well that certainly would be very interesting…
                                  • ChrisC
                                    Chris
                                    it is true that it is really impressive.
                                    What is the current minimum hardware configuration to make this system work?
                                    Regards,
                                    • akshaybahadur21A
                                      akshaybahadur21 @Chris
                                      @Chris For now, I am running it on a VM. What I would suggest that you could do the same. Or as my friend @cowboysdude you could use a Mini ITX board if you want to go for full home automation. That is a bit costly ofcourse
                                        cyberphox @akshaybahadur21
                                        @akshaybahadur21 don’t tease me! But I’m interested in what specs i will need to run this. I’m working on a 50" touchscreen mirror right now so might as well as add a new cpu to the mix!
                                        • akshaybahadur21A
                                          @cyberphox you could use Mini ITX board and go for full home automation. That sounds a lot of fun. Although I haven’t tried that. I think I might.
                                          C 1 Reply Last reply
                                            @akshaybahadur21 got an Asrock Z87E-ITX and i3 processor to play around with…and lots of Z-wave devices
                                            akshaybahadur21A cowboysdudeC 2 Replies Last reply
                                            • 1 / 4
