    Magic Mirror with AI
    64 Posts 14 Posters 80.6k Views 18 Watching
    • cruunnerrC Offline
      cruunnerr
      o.0
      dammit… Congrats man. Very very well done.
      akshaybahadur21A 2 Replies Last reply Reply Quote 0
        cyberphox
        wow…following…and looking forward to code too!! might have to re-do my mirror for this!
        akshaybahadur21A 1 Reply Last reply Reply Quote 0
        • cowboysdudeC Offline
          Would be really nice to see it…but I don’t see it happening… I think this was just a setup.
          akshaybahadur21A 1 Reply Last reply Reply Quote 2
          • akshaybahadur21A Offline
            akshaybahadur21 @cowboysdude
            @cowboysdude Hi thanks for the skepticism. We are used to it. The code and the final video shall be uploaded soon. Check the link for documentation
            https://github.com/akshaybahadur21/Smart_Mirror
            cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 2
              akshaybahadur21 @cruunnerr
              @cruunnerr @cyberphox - Thanks for the encouragement and support. We won’t let you down.
                cowboysdude Module Developer @akshaybahadur21
                @akshaybahadur21 Too many have come through with empty promises of ‘things that are’…so I’m hoping you prove me wrong :)
                Will users be able to add other modules as is the case now?
                  Mykle1 Project Sponsor Module Developer @akshaybahadur21
                  @akshaybahadur21 said in Magic Mirror with AI:
                  This will run on a Pi?
                    akshaybahadur21 @Mykle1
                    @Mykle1 - It won’t be able to run on a pi with the current configurations. Although we are looking for a less heavy design which can run smoothly on a pi. All the computation is done in the cloud to make it as lightweight as possible. But still I wont recommend it running on pi
                      @cowboysdude - Thanks. Yes, the users can add all the existing modules with this one. And a simple voice command will activate or deactivate them. We have used an existing email module to appear and disappear with voice command.
                        akshaybahadur21 @cyberphox
                        @cyberphox - We can redo your mirror for you… :D
                        cowboysdudeC C 2 Replies Last reply Reply Quote 0
                          @akshaybahadur21 well that certainly would be very interesting…
                          • ChrisC Offline
                            Chris
                            it is true that it is really impressive.
                            What is the current minimum hardware configuration to make this system work?
                            Regards,
                              akshaybahadur21 @Chris
                              @Chris For now, I am running it on a VM. What I would suggest that you could do the same. Or as my friend @cowboysdude you could use a Mini ITX board if you want to go for full home automation. That is a bit costly ofcourse
                                cyberphox @akshaybahadur21
                                @akshaybahadur21 don’t tease me! But I’m interested in what specs i will need to run this. I’m working on a 50" touchscreen mirror right now so might as well as add a new cpu to the mix!
                                  @cyberphox you could use Mini ITX board and go for full home automation. That sounds a lot of fun. Although I haven’t tried that. I think I might.
                                    @akshaybahadur21 got an Asrock Z87E-ITX and i3 processor to play around with…and lots of Z-wave devices
                                    akshaybahadur21A cowboysdudeC 2 Replies Last reply Reply Quote 1
                                      @cyberphox that would do the trick for you. Do reach out to me if you need some assistance as well as share your experience with me. Maybe we could collaborate in future.
                                        cyberphox
                                        I’ll be monitoring the GitHub for the code for sure!
                                        akshaybahadur21A 2 Replies Last reply Reply Quote 1
                                          @cyberphox - That would be uploaded soon
                                            cowboysdude Module Developer @cyberphox
                                            @cyberphox said in Magic Mirror with AI:
                                            BINGO…winner! :)
                                            I’m building a 32" with an ASUS H110T and I3 core processor…and it will run ANYTHING :)
                                            It’s like having a stick of dynamite!
                                            • 1 / 4
