    My display so far...
    Scheduled Pinned Locked Moved Showcase
    66 Posts 18 Posters 106.9k Views 22 Watching
      j.e.f.f Project Sponsor Module Developer @pjkoeleman
      @pjkoeleman Let me look into this. Likely overlooked in the code.
      pjkoelemanP 1 Reply Last reply
      • pjkoelemanP
        pjkoeleman @j.e.f.f
        @j.e.f.f
        Thanks in advance
        J 1 Reply Last reply
          @pjkoeleman Try now. It’s a bit hacky… basically if your time format has a capital H in it, then it formats it in 24 hour time HH:mm, otherwise it will use 12 hour time h:mm a.
          I should probably make this a separate time format config parameter, but this should do for now.
          • pjkoelemanP
            pjkoeleman @j.e.f.f
            @j.e.f.f
            Thanks, is working now like it should be doing.
            So the module is not using ‘timeFormat’ as set in the main part of config.js
            I thought that it would look and use the settings of ‘language’ and ‘timeFormat’ in the global settings of config.js
              @pjkoeleman not directly, no, as it specifically comes down to how I have it configured. My time format for the forecast table is “h a” (e.g.: “9 pm”). This time format has no minutes, which is fine for the hourly forecast, but doesn’t work for sunrise/sunset. So when rendering the sunrise/sunset time it looks for the presence of a capital “H” in the time format config. If present, sunrise sunset is rendered as “HH:mm” (i.e.: 24 hour time format). Otherwise it is rendered as “h:mm a” (12 hour time format).
              The right thing to do is separate sunrise/sunset time format out to its own configuration parameter.
              • pjkoelemanP
                pjkoeleman @j.e.f.f
                @j.e.f.f
                Thanks for clearing us up.
                  brendyburgers
                  would it be possible to have a copy of your program have been trying for a while now to come up with something like this, and does it work with touch???
                    j.e.f.f Project Sponsor Module Developer @brendyburgers
                    @brendyburgers much of the above have now become modules. Which one were you interested in?
                    Sorry to say but none of my modules are touch enabled.
                      rrrene @j.e.f.f
                      @j.e.f.f
                      Hi Jeff, I just put your CSS code in my custom.css.
                      Unforunately for one Module the line below the header stays the „old“ grey color and won‘t change to your great blue.
                      What did I do wrong?
                      Best regards,
                      René
                        j.e.f.f Project Sponsor Module Developer @rrrene
                        @rrrene said in My display so far...:
                        Most likely nothing :)
                        If the issue is with just one module, then likely my custom CSS is being overridden with that module’s CSS. You need to inspect the markup to see what styles are being applied to that particular module and then write more specific CSS to override that.
                        You can access the inspector by starting MM in dev mode npm start dev.
                        R V 2 Replies Last reply
                          rrrene @j.e.f.f
                            Joshrobbs1
                            This is awesome! I would like your files could you PM them to me?
                            • justjim1220J
                              justjim1220 Module Developer
                              My display so far…
                              any questions, feel free to ask!
                              Very willing to share!
                              Platform: Windows 10 (Asus 15.6’ laptop)
                              Issues: Cannot get any type of voice control or interaction with it yet. NOT GIVING UP!!!
                              (but very willing to hear some ideas,)
                              Future Additions: >Google fit (already have it set up on one of my desktops
                              >change Selfie to a daily random pic (not from a website, from a file folder)
                              >get email to show different origins (Gmail, Yahoo, Hotmail, etc.)
                              >voice control/interaction/assistant (would like combo of Alexa, Google
                              Assistant, Watson, and Cortana)
                              >Interactive Avatar to utilize the previous idea
                              >want to know how to hide a module but it keep working in the background.
                              for example: have a music module or the YouTube module play without it
                              taking up space on the Mirror
                              >would also like to know how to change the code to give me 4 columns
                              (I’ve tried everything I could!!!)
                              >would also like to know how to get the email module to align left
                              >And, I eventually will 1 or more of the modules that would be changeable through
                              random display, voice control, or timed change.
                              If anyone out there would like to give me some hints, tips, pointers, code examples, or just collaborate on any or all of this, I would greatly appreciative!!!
                              Jim Hallock - 1995
                              • V
                                vincentveenman
                                • V
                                  vincentveenman @j.e.f.f
                                  @j-e-f-f
                                  Hi Jeff, amazing job on the css. Would you please share your files for me to learn? Thanks in advance.
                                  Vincent
                                  • 4 / 4
