    I messed up
    5 Posts 3 Posters 2.3k Views 2 Watching
    • N
      navyvette87
      reloaded sd card, loaded MM, and clicked to use auto start during set up, now I cant get to pi gui to make any changes, it just starts mm full screen. How do I change it so I start it if i cant get behind it? only vnc is set on.
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @navyvette87
        @navyvette87
        Press your Alt key. This will drop a menu bar at the top. Minimize MM there and type pm2 stop mm in your terminal to stop the mirror. pm2 start mm will start your mirror when you are ready
        • cruunnerrC
          cruunnerr
          Please correct me if i am wrong.
          What Mykle1 said is right. Have u used the automatic installer and said “YES” when it asked u too start automatically i think the process of pm2 is called MagicMirror. So the commands should be:
          pm2 stop MagicMirror
          pm2 start MagicMirror
          pm2 save MagicMirror (to save the current status (on or off))
          N Mykle1M 2 Replies Last reply
          • N
            navyvette87 @cruunnerr
            @cruunnerr thanks that did what I wanted
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @cruunnerr
              @cruunnerr said in I messed up:
              Ahhh, thanks for putting me straight. I don’t do automatic installations anymore. I’ve only installed PM2 manually and use the commands that I stated. Good catch @cruunnerr! :-)
