    • Mykle1M
      Mykle1 Project Sponsor Module Developer @tbbear
      @tbbear said in MMM-NOAA - Another Weather Module:
      translation comes directly from wunderground
      Oh, this I did not know. Thanks for the info, Robert.
      @Peter I am sure he will correct it soon enough
      • N
        Nilnik Project Sponsor @tbbear
        @tbbear If you put lang: and your languagecode from Wunderground in MMM-NOAA:s config in my case SW for Sweden
        it works.
        tbbearT 1 Reply Last reply Reply Quote 0
        • tbbearT
          tbbear Module Developer @Nilnik
          @Nilnik Hi, the problem is only in the latest version.
          @ALL The problem is fixed , please do ur git pull in MMM-NOAA
          Robert the Bear
          • DesaydroneD
            Desaydrone
            I try to config this module, but i have some error when launching
            0|mm       | App threw an error during load
            0|mm       | Error: Cannot find module 'google-translate-api'
            0|mm       |     at Module._resolveFilename (module.js:455:15)
            0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
            0|mm       |     at Function.Module._load (module.js:403:25)
            0|mm       |     at Module.require (module.js:483:17)
            0|mm       |     at require (internal/module.js:20:19)
            0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:9:19)
            0|mm       |     at Module._compile (module.js:556:32)
            0|mm       |     at Object.Module._extensions..js (module.js:565:10)
            0|mm       |     at Module.load (module.js:473:32)
            0|mm       |     at tryModuleLoad (module.js:432:12)
            0|mm       | Whoops! There was an uncaught exception...
            0|mm       | { Error: Cannot find module 'google-translate-api'
            0|mm       |     at tryModuleLoad (module.js:432:12) code: 'MODULE_NOT_FOUND' }
            Di i made some mistake ? I never need google translate since now
            DesaydroneD 1 Reply Last reply Reply Quote 0
            • DesaydroneD
              Desaydrone @Desaydrone
              @Desaydrone said in MMM-NOAA - Another Weather Module:
              Sorry i found my mistake, i forgot “npm install” :( Sorry
                Johans
                Sorry for these stupid questions.
                1. How can I get the temperature with 1 or 2 decimals?
                2. I want to get data from 2 different locations (Home & Holiday home abroud)
                  Can I copy module & rename it MMM-NOAA2 or can I put 2 different API & PWS locations in?
                • tbbearT
                  tbbear Module Developer @Johans
                  @Johans Hi Johans, to ask is never stupid. So to your questions:
                  1. The module gets his data from Wunderground so it can only display what it gets.
                  2. Yes, this should be possible and u said how it can be done. U can copy it to a new name and
                    npm install their. Dont forget to add the renamed module in the config file
                  Robert the Bear
                    Johans @tbbear
                    @tbbear thanks for the quick answer.
                    I will copy & rename & add into config file.
                    About temp with decimals, I installed also MMM-MyWeather which takes the data from wunderground (just to compare both weather modules) - in fact It uses same API & PWS as NOAA, but here i’m getting the temperature with 1 decimal. (not 7°, but 7.4°).
                    Anyhow, no big deal, I can live with it. I just asked, maybe there was a setting for the temp decimals which wasn’t yet communicated or so.
                    • tbbearT
                      @Johans OK, so let me check what is possible
                      (by the way u must have a very sensible skin to feel decimals … only joking)
                      Robert the Bear
                      • Y
                        yawns Moderator @tbbear
                        MMM-NOAA.js starting line 310. Math.round() is used which rounds up or down and eliminates decimals.
                        Maybe you could add a config option to specify number of decimals?
                        • cowboysdudeC
                          Working on re-formatting this to have a smaller foot print…as I know space is a premium!
                          Stay tuned…
                          • cowboysdudeC
                            Just a sneak peek…
                            • Mykle1M
                              @cowboysdude
                              Damn you! :-)
                              • cowboysdudeC
                                Much slimmer so it takes up less space :) ONLY issue is that as of right now it only works in English…
                                • tbbearT
                                  tbbear Module Developer @cowboysdude
                                  @cowboysdude I like this new style… for german translation, of course i can help and im sure other users would love to help too
                                  Robert the Bear
                                  Mykle1M A 2 Replies Last reply Reply Quote 3
                                  • Mykle1M
                                    I don’t want to help him. I’m just jealous! :-)
                                    tbbearT 1 Reply Last reply Reply Quote 1
                                    • tbbearT
                                      tbbear Module Developer @Mykle1
                                      @Mykle1 LOL ha ha ha u are still the champion
                                      Robert the Bear
                                      • cowboysdudeC
                                        Well through determination I figured out the issue :)
                                        There will be 2 branches of this module…the original and the one I call NOAA2
                                        Here’s a screenshot [NOAA2] take up less space, almost ready!!
                                        cowboysdudeC 1 Reply Last reply Reply Quote 4
                                        • cowboysdudeC
                                          cowboysdude Module Developer @cowboysdude
                                          German translation is done :) [The current weather at top is also in German, just didn’t take a new picture ;)]
                                          • Y
                                            yawns Moderator
                                            I did not like the old look, but the new one is very nice. Well done!
                                            Mykle1M 1 Reply Last reply Reply Quote 3
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 34
                                            • 35
                                            • 14 / 35
