    Prepping my first build. Care to check my work?
    26 Posts 6 Posters 17.1k Views 4 Watching
      3DPrintedWaffles @Mykle1
      @Mykle1 Awesome, thanks for your thorough response!
      I’ve hit a snag with the monitor, I don’t know how to get the bezel off. Videos online for this same model (but apparently different sub-model) have screws and clips in places where mine does not. I’ve got the Acer AL2216W sd. Would it be ideal to just use brute force on it? Hell no! There’s gotta be a better way, but I haven’t found it. I ordered a jimmy and may just wait for it to arrive to try and crank that thing open. Any advice would be much appreciated :-)
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @3DPrintedWaffles
        @3DPrintedWaffles said in Prepping my first build. Care to check my work?:
        Ha ha! :-)
        I’ve never encountered a bezel that didn’t just snap off so be as careful as you can be. I know someone that cracked a 32 monitor while removing it from the casing. :-(
        3 1 Reply Last reply
          3DPrintedWaffles @cruunnerr
          @cruunnerr said in Prepping my first build. Care to check my work?:
          @bhepler said in Prepping my first build. Care to check my work?:
          • Give a thought to power. Are you routing the power through the wall? Through a hole in your internal framework? Consider that at the moment, you have to power the Pi and the monitor, so that’s two cords.
          That is a good keyword. If u just want one cord u can think about using a step-down converter.
          Don’t know what Voltage your monitor will be using. In my case my monitor needs 12V and the RPi 5V as normal.
          So i choosed a big 12V power supply (5A or 60W) to power both.
          Then i ordered a DC-DC Step Down converter: https://www.amazon.com/DROK-Converter-Step-down-Regulator-Stabilizer/dp/B019RKVMKU/ref=sr_1_5?ie=UTF8&qid=1516968110&sr=8-5&keywords=lm2596&th=1
          connect the 12V output of the power supply to the converter input and parallel to your monitor.
          adjust the converter output to 5 - 5.1V and connect it with your Pi :)
          You can see an example here: https://forum.magicmirror.builders/topic/6048/my-first-mirror-until-now/12
          This looks like the way to go, though perhaps a bit more advanced than I am. I think I’ll give this a go when I build my second mirror :-)
          • cruunnerrC
            cruunnerr
            a last hint, which is more software suggest:
            https://github.com/gilyes/pi-shutdown
            order one push button more (if u tough about before), so this is nice to shutdown and boot up your Pi safely :)
              @Mykle1 Could you show me how this mirror looks from the front? Do you have it vertical or horizontal?
              • Mykle1M
                0_1517173573119_2.JPG 0_1517173584148_3.JPG 0_1517173595582_1.JPG 0_1517173605101_4.JPG
                3 2 Replies Last reply
                  @Mykle1 Dang, that’s pretty good lookin’. I especially like your frame. I think in some ways the frame makes or breaks it. With a poor/ugly frame it loses it’s “future tech” feel and instead looks tacky. But what you’ve done with a high quality frame keeps the mirror crisp and communicates that it’s not some poorly thrown together novelty/oddity. I think it’s similar to when you see what was once a very nice car that’s been beaten up and not lookin’ good.
                  I’m probably not going to try to go bezel free for my first build, but as it happens my next door neighbor is a big wood working guy. I’m gonna ask for his help with that part of this. I just gotta think of some kind of gift I can give him in return…
                  Mykle1M 2 Replies Last reply
                  • Mykle1M
                    @3DPrintedWaffles
                    Thanks for your kind words. Really, I made that frame from a $12 piece of molding from the local Home Depot. Hell, you could buy a $6 miter box and do the same thing yourself.
                    You can see the whole build here
                    https://forum.magicmirror.builders/topic/1678/1-old-noob-1-rpi-i-can-t-believe-i-did-it-revisited
                    And you can see my use of a cheap miter box here.
                    https://forum.magicmirror.builders/topic/4930/vanity-mirror-thy-name-is-woman-using-laptop
                    • Mykle1M
                      Get him a six-pack of beer. It will take him less than five minutes to miter a frame. Or. get yourself the beer and make the frame yourself. Then you get all the glory. :-)
                        @Mykle1
                        Also you may have mentioned this earlier and I’ve forgotten, but what size is your monitor? I’m considering upping my size… =-/
                          @Mykle1 Heh I might do the woodwork on my next one. I plan to make at least a few of these.
                          He’s a very talented woodworker, he could make it look better than I ever could. Worth a few beers at the very least. I need both the rear frame and bezel cut, so maybe a 24 pack is in order :-)
                          • Mykle1M
                            @3DPrintedWaffles
                            That particular monitor is 22" diagonal. Sure, get him a case. Just don’t let him drink it until he is finished with your frame. ;-)
                              @Mykle1
                              The Jimmy arrives today and unless I can come up with a better idea I’ll just be trying to crack this thing open like a monkey with a rock.
                              I got it for just $25 and could probably find another use for it, so I’m half tempted to look for another cheapo that may be easier to open. I dunno man. I dunno.
                              • Mykle1M
                                @3DPrintedWaffles
                                Heh! Go easy broze, go easy! :-)
                                  @Mykle1 Is there a reason people seem to favor computer monitors for this project than TVs? There are some cheap flatscreens in my area for pretty cheap.
                                  Mykle1M Y 2 Replies Last reply
                                  • Mykle1M
                                    @3DPrintedWaffles
                                    I’m sure there are reasons but I don’t know what they are. Perhaps someone else will chime in here, or, you can search the forum. I think I remember some chatter about using TV displays.
                                    • Y
                                      yawns Moderator @3DPrintedWaffles
                                      @3DPrintedWaffles
                                      1. Most tv’s show stuff like “signal lost” on screen when you disable hdmi in raspberry to hide the screen, and in some tv’s you cannot disable that
                                      2. Cheap tv’s have a poor resolution. The 32" I bought for some bucks only runs 1366x768 and text on your mirror (calendar for example) looks blurry.
                                      But you can still live with it. I will use mine to see if we actually use the magic mirror at all. Then I can still invest money in a better display add replace it
                                      Reply Quote 2
                                        3DPrintedWaffles
                                        Think this is too old/bad to be a good fit for such a project?
                                        https://bellingham.craigslist.org/sys/d/excellent-condition-samsung/6476424727.html
                                          @mykle1 @yawns @bhepler @ninjabreadman @cruunnerr
                                          After a bit of a hiatus due to other projects, I’m back at it. Think I should open a new post as the site suggested?
                                          I got two cheap ~20" monitors and cut two panes of glass to size. I figure the first one I do will be kinda an MVP (minimum viable product) approach, and with the second I’ll customize it more to my preferences.
                                          My main question is how to securely attach the wood rear frame to the monitor. This isn’t a glue situation is it? I’ve got few heavy duty glues but that still doesn’t “feel” secure.
                                          The guides I’ve seen seem to gloss over like it’s obvious. To me at least, it’s not.
                                          Remaining little questions:
                                          How thick should/must the wood for the frame be? How much heft does it need to properly support the monitor/mirror? How much space can I safely save by cutting it down to get it closer to flush with the wall?
                                          At least in my mind, the back frame shouldn’t encompass the entire perimeter but be strategically located on the back of the monitor. But maybe I’m wrong here, as I suppose it serves the purpose of blocking the view of the inner workings.
                                          Thanks for all your help along the way. I’m looking forward to sharing pics of the completed beta build as soon as I can!
