    MMM-WeatherChart
    42 Posts 16 Posters 37.6k Views 15 Watching
    • paphkoP
      paphko
      I created a module that lists a nice weather chart from www.yr.no, optionally with or without border: mmm-weatherchart
      H 1 Reply Last reply
      Reply Quote 3
      • G
        gshimself
        Im trying this one out atm on my mirror. Seems to work pretty good.
        Nice work!
        • H
          hulkhaugen @paphko
          Cool, i will have a look at this. I was actually thinking of remaking the currentweather and weatherforecast with yr.no data as they are way more accurate for my location. I have very little knowledge of js-programming, but think this might be a place to start.
          • G
            gshimself
            @paphko I think I got a problem… The map/weatherchart/module doesn’t update itself untill i reboot the whole device. Is this something it’s known for?
            • strawberry 3.141S
              the module should update every hour automatically, for testing purpose you could try in the config.js
                      module: 'mmm-weatherchart',
                      position: 'bottom_left', // this can be any of the regions
                          country: 'Germany', // as determined above
                          area: 'North_Rhine-Westphalia', // as determined above
                          city: 'Duisburg', // as determined above
                          updateInterval: 15 * 1000,
                          hideBorder: true, // whether or not a border with city name should be shown
              this should update every 15 seconds then open the dev console (Command+Shift+I) and see in the network tab if the picture is getting reloaded all the time or you having any errors in the console
              G 1 Reply Last reply
              • G
                gshimself @strawberry 3.141
                @strawberry-3.141
                Im no expert on reading the dev console but it seems to just update from cache after a while?
                initalator: mmm-weatherchart
                Time: 0ms
                and it’s pileing up.
                On mmm-weatherchart.js it seems to update, every 15th secound but the chart does not.
                Im going to let it stay like this awhile and return.
                • G
                  gshimself
                  Yea, as I thought. The chart just piles up and doesn’t update. The script however does update.
                  paphkoP 1 Reply Last reply
                  • paphkoP
                    paphko @gshimself
                    @gshimself I added a dummy parameter (timestamp) to the image which should prevent caching. I’ll check that later today when I find some time.
                    • paphkoP
                      paphko
                      The module appends ‘#’ to the image so that the browser does not cache the image. This works on my old version of the mirror but not on the new version 2. Quite strange…
                      Fixed by replacing this part with ‘?’, at least for Chrome browser, the image is not cached any longer. @gshimself please pull changes and report wether it is also fixed for you.
                      G 2 Replies Last reply
                      • G
                        gshimself @paphko
                        @paphko ¨Perfect! Will pull the latest version when I get home. I’ll get back to you during the evening.
                        • A
                          amanzimdwini
                          I like it!
                          Request: can you add a SCALE factor? Right now the image is considerably larger than I can accommodate… (yes, minor problem, I know). Maybe I have to mess with the custom.css?
                          Anyway, apart from that small inconvenience, I like it.
                          • G
                            gshimself @paphko
                            @paphko Seems to be working fine now. Thank you for your help!
                            I guess that if I want 30min refreshrate it should be 60 * 30 * 1000,?
                            • paphkoP
                              paphko
                              @gshimself glad to hear that it’s fixed for you. Yes, because update interval must be specified in ms.
                              @amanzimdwini you could try to add a scale option, but I’m not sure how to properly implement it for both cases, with and without border. If you found a proper solution for it, tell me or create a pull request :-)
                                racampbellky
                                Great module! Is there anyway to present in Fahrenheit?
                                • paphkoP
                                  paphko @racampbellky
                                  @racampbellky I don’t think so. But you may check the website of yr.no, maybe you find a setting to use Fahrenheit in that diagram: http://www.yr.no/place/United_States/New_York/New_York/hour_by_hour.html
                                  If so, it should be possible.
                                  • A
                                    AxLed Module Developer
                                    i wanted to try the module today, but i dont work i get some error “del missing” or similar.
                                    Could it be that there is the file package.json missing on the github link, as there are some depencies in node_helper.js
                                    var http = require('http');
                                    var fs = require('fs');
                                    var del = require('del');
                                    var request = require('request');
                                    var NodeHelper = require("node_helper");
                                    Greets AxLED
                                    • A
                                      found a solution myself, there is a fork of this module: https://github.com/szech/mmm-weatherchart
                                      Installation:
                                      cd ~/MagicMirror/modules
                                      git clone https://github.com/szech/mmm-weatherchart.git
                                      cd mmm-weatherchart
                                      npm install
                                      Greets
                                      AxLED
                                      M 1 Reply Last reply
                                        Stellanova
                                        If you replace grayscale with hue-rotate(190deg) in the mmm-weatherchart.js. You get the colors partially back and still have whitelines.
                                        if (this.config.negativeImage) {
                                        img.style[“-webkit-filter”] = “invert(100%) hue-rotate(190deg)”;
                                        • V
                                          Vauxdvihl
                                          @Stellanova said in MMM-WeatherChart:
                                          is there a possibility to increase the size?
                                          Thanks a lot
                                          Regards
                                          • brobergB
                                            broberg Project Sponsor
                                            @Vauxdvihl
                                            Yes, But it will get fuzzy since the original image is only 828 × 272 pixels in size.
                                            increase by 25%
                                            .MMM-WeaterChart img{
                                            width: 1035px !important;
                                            height: 340px !important;
                                            (To be clear, this go in to the custom.css file, not changing the module files)
