    MMM-WeatherChart
    42 Posts 16 Posters 31.1k Views 15 Watching
    • paphkoP Offline
      paphko
      I created a module that lists a nice weather chart from www.yr.no, optionally with or without border: mmm-weatherchart
      H 1 Reply Last reply Reply Quote 3
      • G Offline
        gshimself
        Im trying this one out atm on my mirror. Seems to work pretty good.
        Nice work!
        • H Offline
          hulkhaugen @paphko
          Cool, i will have a look at this. I was actually thinking of remaking the currentweather and weatherforecast with yr.no data as they are way more accurate for my location. I have very little knowledge of js-programming, but think this might be a place to start.
          • G Offline
            gshimself
            @paphko I think I got a problem… The map/weatherchart/module doesn’t update itself untill i reboot the whole device. Is this something it’s known for?
            • strawberry 3.141S Offline
              the module should update every hour automatically, for testing purpose you could try in the config.js
                      module: 'mmm-weatherchart',
                      position: 'bottom_left', // this can be any of the regions
                          country: 'Germany', // as determined above
                          area: 'North_Rhine-Westphalia', // as determined above
                          city: 'Duisburg', // as determined above
                          updateInterval: 15 * 1000,
                          hideBorder: true, // whether or not a border with city name should be shown
              this should update every 15 seconds then open the dev console (Command+Shift+I) and see in the network tab if the picture is getting reloaded all the time or you having any errors in the console
              • G Offline
                gshimself @strawberry 3.141
                @strawberry-3.141
                Im no expert on reading the dev console but it seems to just update from cache after a while?
                initalator: mmm-weatherchart
                Time: 0ms
                and it’s pileing up.
                On mmm-weatherchart.js it seems to update, every 15th secound but the chart does not.
                Im going to let it stay like this awhile and return.
                • G Offline
                  gshimself
                  Yea, as I thought. The chart just piles up and doesn’t update. The script however does update.
                  paphkoP 1 Reply Last reply Reply Quote 0
                  • paphkoP Offline
                    paphko @gshimself
                    @gshimself I added a dummy parameter (timestamp) to the image which should prevent caching. I’ll check that later today when I find some time.
                    • paphkoP Offline
                      paphko
                      The module appends ‘#’ to the image so that the browser does not cache the image. This works on my old version of the mirror but not on the new version 2. Quite strange…
                      Fixed by replacing this part with ‘?’, at least for Chrome browser, the image is not cached any longer. @gshimself please pull changes and report wether it is also fixed for you.
                      G 2 Replies Last reply Reply Quote 0
                      • G Offline
                        gshimself @paphko
                        @paphko ¨Perfect! Will pull the latest version when I get home. I’ll get back to you during the evening.
                        • 1 / 5
