    I cant load 3rd party modules to my smart mirror.
    codingmodulemodulessmart mirrormagicmirrormagic mirror
    8 Posts 5 Posters 3.6k Views 4 Watching
      Brenj @yawns
      @yawns thanks so much for responding. I copied exactly what you said but it still wont work UGH.
      I think it has something to do with the ending of the coding.
                          module: 'MMM-NFL',
                          header: 'NFL Scores',
                          position: 'bottom_right',
                                  colored true,
                                  reloadInterval 1800000
      if (typeof module !== “undefined”) {module.exports = config;)
      I literally dont know whats wrong with this, I may just have to start the whole thing over.
      Thanks again,
      Brenj
      • brobergB Offline
        broberg Project Sponsor @Brenj
        @Brenj you are missing a :
        between colored and true
        And between
        Reloadinterval and 18000000
          Brenj
          I did that and still nothing. I’ve been trying to figure out this for the past few days this is making me mad, lol. But thanks for your guys’ help. I might just start over, it would probably make it easier. Do you guys by chance know how to start the coding over? Again thanks for your help, I feel like im asking too much, sorry.
          • yawnsY Offline
            yawns Moderator
            Download the sample config file: https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample
            Save it to your pi into the config folder, delete/rename the existing config.js and rename the downloaded file to config.js
            Then start over again and try adding the new module. Do not delete the rest of the content
              You would probably benefit from reading this:
              https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
              • V Offline
                videogame95
                If you have config file copy config.sample
                Start again copy the sample file to your documents and downloads.
                Remove sample from the configuration file
                Start again
                Remember start with {
                Code
                Ends in },
                It’s not always easy to see what’s wrong as the code you are using could be wrong .
                as l’ve not used this module l cannot say
                Keep trying your get their in the end
                If it go wrong it’s easy to start again.
