    Weather forecast only displays 'invalid date'
    21 Posts 9 Posters 90.7k Views 8 Watching
      Canterrain
      Sure, I can post that. The config checker doesn’t find any issues. Any help appreciated.
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: 'en',
      	timeFormat: 12,
      	units: 'imperial',
      			module: 'alert',
      			module: 'MMM-Motion-Detection',
      			module: 'clock',
      			position: 'top_left'
      			module: 'MMM-Nest',
      			position: 'bottom_right',
      				token:"xxx"
      			module: 'calendar',
      			header: 'Calendar',
      			position: 'top_left',
      						symbol: 'calendar-check-o ',
      						url: 'xxx'
      			module: 'currentweather',
      			position: 'top_right',
      				locationID: 'xxx',  //ID from http://www.openweathermap.org
      				appid: 'xxx'
      			module: 'weatherforecast',
      			header: 'Weather Forecast',
      	            appid: 'xxx'
      			module: 'newsfeed',
      			position: 'bottom_bar',
      				feeds: [
      						title: "ArsTechnica",
      						url: "http://feeds.arstechnica.com/arstechnica/index/",
      						title: "NPR",
      						url: "http://www.npr.org/rss/rss.php?id=1001"
      				showSourceTitle: true,
      				showPublishDate: true
      • justjim1220J Offline
        justjim1220 Module Developer @Canterrain
        @canterrain
        2 things to try…
        try putting a comma after the motion detection module
        module: ‘MMM-Motion-Detection’,
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          Canterrain
          No luck adding the comma unfortunately.
          You mentioned 2 things to try, what was the second?
          Thanks for looking at this.
          • yawnsY Offline
            yawns Moderator
            appid in currentweather module is missing a ’
            Time and date on your raspberry are fine, right?
              @canterrain
              Not sure how I missed that… weird, I swear I put it in there…
              Check the time and date of your devices…
              Jim Hallock - 1995
                Canterrain
                Thanks for the helpful suggestions.
                Date and time are correct on my pi, and the mirror even shows the right date and time.
                The config did have the missing ’ in current weather, I apparently accidentally deleted it when I was removing personal info. I edited the above to reflect the current status of my config file.
                This was working fine before. About the time I updated the mirror to latest version and added the motion detection module. But it didn’t happen immediately after those events. It was a few days later. I did find a logged issue (that was closed) describing the same thing, after updating the mirror.
                  Bob
                  I’m having the same issue as @Canterrain
                  Snipp from Clock and Weather modules are below
                   // Clock
                  			module: "clock",
                  			position: "top_center",
                  				displayType: "digital",
                  				displaySeconds: false,
                  				showPeriod: true,
                  				showPeriodUpper: false,
                  				clockBold: false,
                  				showDate: true,
                  				showWeek: false,
                  				dateFormat : "dddd, MMMM Do YYYY",
                  // Calendar// Weather - ID from http://www.openweathermap.org/help/city_list.txt
                  			module: "weatherforecast",
                  			header: "7 Day Forecast for ",
                  				fade: false,
                  				maxNumberOfDays: 7,
                  				showRainAmount: true,
                  				colored: true,
                  				locationID: "2655603",
                  				appid: "xxx"
                  Issue only occurred once I did an update to the MM system to v.2.4.0
                    Richard238
                    Same issue here
                    • K Offline
                      killing joke
                      same here.
                      Is there a possibilty to erase the comma and country code behind the location in the header?!
                        AgP42 Project Sponsor Module Developer
                        same problem for me since the update in 2.4.0… So general update issue probably (looking forward for a solution !:slightly_smiling_face: )
                        To answer @killing-joke said in Weather forecast only displays ‘invalid date’:
                        same here.
                        I did change the following on the file “/MagicMirror/modules/default/weatherferecast/weatherforecast.js” :
                        // Override getHeader method.
                        getHeader: function() {
                        if (this.config.appendLocationNameToHeader) {
                        //line to change
                        //return this.data.header + " " + this.fetchedLocationName;
                        return "Prévisions Météo Nogent"; // write here what you want...
                        return this.data.header;
                        Here is the result :
                        20180702_220235_resized
                        You can of course change the line on the way you want to remove only the part you need.
