    Weather forecast only displays 'invalid date'
    21 Posts 9 Posters 93.2k Views 8 Watching
      Canterrain
      No luck adding the comma unfortunately.
      You mentioned 2 things to try, what was the second?
      Thanks for looking at this.
      justjim1220J 1 Reply Last reply
      • Y
        yawns Moderator
        appid in currentweather module is missing a ’
        Time and date on your raspberry are fine, right?
        • justjim1220J
          justjim1220 Module Developer @Canterrain
          @canterrain
          Not sure how I missed that… weird, I swear I put it in there…
          Check the time and date of your devices…
          Jim Hallock - 1995
            Canterrain
            Thanks for the helpful suggestions.
            Date and time are correct on my pi, and the mirror even shows the right date and time.
            The config did have the missing ’ in current weather, I apparently accidentally deleted it when I was removing personal info. I edited the above to reflect the current status of my config file.
            This was working fine before. About the time I updated the mirror to latest version and added the motion detection module. But it didn’t happen immediately after those events. It was a few days later. I did find a logged issue (that was closed) describing the same thing, after updating the mirror.
              Bob
              I’m having the same issue as @Canterrain
              Snipp from Clock and Weather modules are below
               // Clock
              			module: "clock",
              			position: "top_center",
              				displayType: "digital",
              				displaySeconds: false,
              				showPeriod: true,
              				showPeriodUpper: false,
              				clockBold: false,
              				showDate: true,
              				showWeek: false,
              				dateFormat : "dddd, MMMM Do YYYY",
              // Calendar// Weather - ID from http://www.openweathermap.org/help/city_list.txt
              			module: "weatherforecast",
              			header: "7 Day Forecast for ",
              				fade: false,
              				maxNumberOfDays: 7,
              				showRainAmount: true,
              				colored: true,
              				locationID: "2655603",
              				appid: "xxx"
              Issue only occurred once I did an update to the MM system to v.2.4.0
                Richard238
                Same issue here
                • K
                  killing joke
                  same here.
                  Is there a possibilty to erase the comma and country code behind the location in the header?!
                  • A
                    AgP42 Project Sponsor Module Developer
                    same problem for me since the update in 2.4.0… So general update issue probably (looking forward for a solution !:slightly_smiling_face: )
                    To answer @killing-joke said in Weather forecast only displays ‘invalid date’:
                    same here.
                    I did change the following on the file “/MagicMirror/modules/default/weatherferecast/weatherforecast.js” :
                    // Override getHeader method.
                    getHeader: function() {
                    if (this.config.appendLocationNameToHeader) {
                    //line to change
                    //return this.data.header + " " + this.fetchedLocationName;
                    return "Prévisions Météo Nogent"; // write here what you want...
                    return this.data.header;
                    Here is the result :
                    20180702_220235_resized
                    You can of course change the line on the way you want to remove only the part you need.
                    K 1 Reply Last reply
                    • K
                      killing joke @AgP42
                      @agp42 said in Weather forecast only displays ‘invalid date’:
                      Thanks a lot. I got it.
                      I found a solution on https://github.com/MichMich/MagicMirror/commit/0e2e8d2e2aca2f8d0f1f2eb7b213577fcc4f623a
                      But I had to change the lines 338 and 339 instead of 336 and 337
                      var day = moment(forecast.dt_txt, "YYYY-MM-DD hh:mm:ss").format("ddd");
                      var hour = moment(forecast.dt_txt, "YYYY-MM-DD hh:mm:ss").format("H");
                      into
                      var day;
                      var hour;
                      if(!!forecast.dt_txt) {
                      } else {
                      	day = moment(forecast.dt, "X").format("ddd");
                      	hour = moment(forecast.dt, "X").format("H");
                      It works for my MM.
                      A 1 Reply Last reply
                        Canterrain
                        Looks like the recent changes here are the culprit. They already figured out what needs to be changed, fixed in an upcoming update. Pull request is in. Get ready to update your mirrors.
                          SoleLo @Bob
                          @bob how did you get you icons to change color as well as your text?
                          • A
                            AgP42 Project Sponsor Module Developer @killing joke
                            into
                            var day;
                            var hour;
                            } else {
                            It works for my MM.
                            Works fine, thank you for the advice !
                            • MichMichM
                              MichMich
                              Ive just merged the fix by @jannekalliola into the develop branch which should solve this issue: https://github.com/MichMich/MagicMirror/pull/1341
                              Can you guys please test this develop branch? If this solves the issue, I’ll release an intermediate 2.4.1 release.
                              To tryout the develop branch, use the following git command on your terminal (from within the MagicMirror folder):
                              git checkout develop
                              git pull
                              Thanks for testing!
                                SoleLo
                                I edited the code snippet and now my time is stuck on 8:01 on the current forecast…
                                  Richard238
                                  Stuck time might be the sunset time. Mine is 21:17, so not stuck al all.
                                    SoleLo @Richard238
                                    @richard238 hahaha you are right, I’m a imbecile.
                                      Bob
                                      Awesome, v2.4.1 fixed it
                                      Thanks @MichMich :)
