    [NEWBIE] Change In Clock Module Is giving error in config file
    19 Posts 6 Posters 10.3k Views 6 Watching
      postremalone
      @yawns
      I did this
        module: "clock",
          timezone: 'Etc/GMT+5.30'
      As my time zone is GMT+5.30
      but it returned error
        can u show the error?
          postremalone
          @yawns it is saying can’t read the config file. Every time i am saving this. and after changing it back to what it was the program start working.
            @postremalone said in [NEWBIE] Change In Clock Module Is giving error in config file:
            module: “clock”,
            position: “top_left”,
            timezone: ‘Etc/GMT+5.30’
            is that the LAST module in the list, or ???
            maybe u need a comma after the last }
            also, watch out on single quotes… sometimes you get the MS WORD format of the quote, which is NOT the right one…
            change those to double quotes
              you can also use https://www.jslint.com/
              to check the syntax of the config file…
              copy/paste it in and at the bottom check boxes for
              long lines
              single quotes
              whitepsace mess
              the press jslint
              u may have to remove the last ‘,’ (comma), before ]
                module: “clock”,
                @sdetweil is correct. You need the comma after the closing bracket, as such }, With that correction, the config syntax is satisfied and the module will run. However, it does generate this error in the dev console.
                Moment Timezone has no data for Etc/GMT+5.30.
                Please see this for for information.
                https://momentjs.com/timezone/docs/#/data-formats/packed-format/
                And this list. Perhaps you can find an appropriate timezone within this list.
                https://github.com/moment/moment-timezone/blob/develop/data/packed/latest.json
                  postremalone @Mykle1
                  @mykle1 @sdetweil @yawns i did this.
                  alt text
                  And it returned this error.
                  alt text
                  Help Please.
                    postremalone
                    It will be better if someone can send me the config file with indian time zone and indian calendar with RSS feed for any Indian News site :) so that i can replace it and learn.
                    I am trying Indian News Feed thing. hope it works :)
                    *update… I did the news thing and its working for me :)
                    now need some help with weather module not showing up. on right side
                      sdetweil @postremalone
                      @postremalone ok, so you got rid of the config.js error, and the mirror is working, except for weather?
                      looking at the config.js screen shot there is no locationID value (last line) … got to have one
                        postremalone
                        @sdetweil hello
                        i got the weather, the news feed,
                        Now working on Clock… I did this…
                        alt text
                        Still Config File Giving error. can you guide me :)
                        And is there any other website which I can use for Calendar Holidays for India.
                        Mykle1M X 2 Replies Last reply Reply Quote 0
                          postremalone
                          Do i need to type this full “Asia/Kolkata|MMT IST +0630|-5l.a -5u -6u|012121|-2zOtl.a 1r2LP.a 1un0 HB0 7zX0|15e6” in the timezone column ?
                            Mykle1 Project Sponsor Module Developer @postremalone
                            @postremalone
                            I can tell you that those screenshots are impossible for me to read. Please post your code in a code block, instead of a screenshot, so that it can be easily read by everyone.
                            https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                            • Y Offline
                              yawns Moderator
                              There is a comma missing after your position line
                              However you could also just set the timezone of your raspberry and ignore this timezone thing in clock module
                                postremalone
                                https://calendar.google.com/calendar/ical/en.indian%23holiday%40group.v.calendar.google.com/public/basic.ics
                                i am using this link for calendar ical code is this fine.
                                https://calendar.google.com/calendar/ical/mr.deep.rawat%40gmail.com/public/basic.ics
                                • X Offline
                                  xchribiza @postremalone
                                  @postremalone
                                  In the module clock you need to close one more bracket }
                                  module: “clock”
                                  timezone: “MMT IST +630”
                                  • justjim1220J Offline
                                    justjim1220 Module Developer @postremalone
                                    @postremalone
                                    Missing a comma ‘,’ at the end or your position entry.
                                    Jim Hallock - 1995
                                      @postremalone no… the timezone is based ont he javascript moment…
                                      see here, you can use any/all of each line… yours I think could be
                                      “Indian/Maldives|MMT”,
