    [NEWBIE] Change In Clock Module Is giving error in config file
    19 Posts 6 Posters 10.6k Views 6 Watching
      postremalone
      Whenever i am changing the clock module to show my own timezone it gives error. Please Help.
      • Y
        yawns Moderator
        Please show, what kind of changes exactly you applied.
          postremalone
          @yawns
          I did this
            module: "clock",
              timezone: 'Etc/GMT+5.30'
          As my time zone is GMT+5.30
          but it returned error
            can u show the error?
              postremalone
              @yawns it is saying can’t read the config file. Every time i am saving this. and after changing it back to what it was the program start working.
                @postremalone said in [NEWBIE] Change In Clock Module Is giving error in config file:
                module: “clock”,
                position: “top_left”,
                timezone: ‘Etc/GMT+5.30’
                is that the LAST module in the list, or ???
                maybe u need a comma after the last }
                also, watch out on single quotes… sometimes you get the MS WORD format of the quote, which is NOT the right one…
                change those to double quotes
                  you can also use https://www.jslint.com/
                  to check the syntax of the config file…
                  copy/paste it in and at the bottom check boxes for
                  long lines
                  single quotes
                  whitepsace mess
                  the press jslint
                  u may have to remove the last ‘,’ (comma), before ]
                  • Mykle1M
                    module: “clock”,
                    @sdetweil is correct. You need the comma after the closing bracket, as such }, With that correction, the config syntax is satisfied and the module will run. However, it does generate this error in the dev console.
                    Moment Timezone has no data for Etc/GMT+5.30.
                    Please see this for for information.
                    https://momentjs.com/timezone/docs/#/data-formats/packed-format/
                    And this list. Perhaps you can find an appropriate timezone within this list.
                    https://github.com/moment/moment-timezone/blob/develop/data/packed/latest.json
                      postremalone @Mykle1
                      @mykle1 @sdetweil @yawns i did this.
                      alt text
                      And it returned this error.
                      alt text
                      Help Please.
                        postremalone
                        It will be better if someone can send me the config file with indian time zone and indian calendar with RSS feed for any Indian News site :) so that i can replace it and learn.
                        I am trying Indian News Feed thing. hope it works :)
                        *update… I did the news thing and its working for me :)
                        now need some help with weather module not showing up. on right side
                          sdetweil @postremalone
                          @postremalone ok, so you got rid of the config.js error, and the mirror is working, except for weather?
                          looking at the config.js screen shot there is no locationID value (last line) … got to have one
                            postremalone
                            @sdetweil hello
                            i got the weather, the news feed,
                            Now working on Clock… I did this…
                            alt text
                            Still Config File Giving error. can you guide me :)
                            And is there any other website which I can use for Calendar Holidays for India.
                            Mykle1M X 2 Replies Last reply Reply Quote 0
                              postremalone
                              Do i need to type this full “Asia/Kolkata|MMT IST +0630|-5l.a -5u -6u|012121|-2zOtl.a 1r2LP.a 1un0 HB0 7zX0|15e6” in the timezone column ?
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @postremalone
                                @postremalone
                                I can tell you that those screenshots are impossible for me to read. Please post your code in a code block, instead of a screenshot, so that it can be easily read by everyone.
                                https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                                • Y
                                  yawns Moderator
                                  There is a comma missing after your position line
                                  However you could also just set the timezone of your raspberry and ignore this timezone thing in clock module
                                    postremalone
                                    https://calendar.google.com/calendar/ical/en.indian%23holiday%40group.v.calendar.google.com/public/basic.ics
                                    i am using this link for calendar ical code is this fine.
                                    https://calendar.google.com/calendar/ical/mr.deep.rawat%40gmail.com/public/basic.ics
                                    • X
                                      xchribiza @postremalone
                                      @postremalone
                                      In the module clock you need to close one more bracket }
                                      module: “clock”
                                      timezone: “MMT IST +630”
                                      • justjim1220J
                                        justjim1220 Module Developer @postremalone
                                        @postremalone
                                        Missing a comma ‘,’ at the end or your position entry.
                                        Jim Hallock - 1995
                                          @postremalone no… the timezone is based ont he javascript moment…
                                          see here, you can use any/all of each line… yours I think could be
                                          “Indian/Maldives|MMT”,
