    [NEWBIE] Change In Clock Module Is giving error in config file
    19 Posts 6 Posters 10.6k Views 6 Watching
      @postremalone said in [NEWBIE] Change In Clock Module Is giving error in config file:
      module: “clock”,
      position: “top_left”,
      timezone: ‘Etc/GMT+5.30’
      is that the LAST module in the list, or ???
      maybe u need a comma after the last }
      also, watch out on single quotes… sometimes you get the MS WORD format of the quote, which is NOT the right one…
      change those to double quotes
        you can also use https://www.jslint.com/
        to check the syntax of the config file…
        copy/paste it in and at the bottom check boxes for
        long lines
        single quotes
        whitepsace mess
        the press jslint
        u may have to remove the last ‘,’ (comma), before ]
        • Mykle1M
          module: “clock”,
          @sdetweil is correct. You need the comma after the closing bracket, as such }, With that correction, the config syntax is satisfied and the module will run. However, it does generate this error in the dev console.
          Moment Timezone has no data for Etc/GMT+5.30.
          Please see this for for information.
          https://momentjs.com/timezone/docs/#/data-formats/packed-format/
          And this list. Perhaps you can find an appropriate timezone within this list.
          https://github.com/moment/moment-timezone/blob/develop/data/packed/latest.json
          P 1 Reply Last reply
            postremalone @Mykle1
            @mykle1 @sdetweil @yawns i did this.
            alt text
            And it returned this error.
            alt text
            Help Please.
            justjim1220J 1 Reply Last reply
              postremalone
              It will be better if someone can send me the config file with indian time zone and indian calendar with RSS feed for any Indian News site :) so that i can replace it and learn.
              I am trying Indian News Feed thing. hope it works :)
              *update… I did the news thing and its working for me :)
              now need some help with weather module not showing up. on right side
                sdetweil @postremalone
                @postremalone ok, so you got rid of the config.js error, and the mirror is working, except for weather?
                looking at the config.js screen shot there is no locationID value (last line) … got to have one
                  postremalone
                  @sdetweil hello
                  i got the weather, the news feed,
                  Now working on Clock… I did this…
                  alt text
                  Still Config File Giving error. can you guide me :)
                  And is there any other website which I can use for Calendar Holidays for India.
                  Mykle1M X 2 Replies Last reply
                    postremalone
                    Do i need to type this full “Asia/Kolkata|MMT IST +0630|-5l.a -5u -6u|012121|-2zOtl.a 1r2LP.a 1un0 HB0 7zX0|15e6” in the timezone column ?
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @postremalone
                      @postremalone
                      I can tell you that those screenshots are impossible for me to read. Please post your code in a code block, instead of a screenshot, so that it can be easily read by everyone.
                      https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                      • Y
                        yawns Moderator
                        There is a comma missing after your position line
                        However you could also just set the timezone of your raspberry and ignore this timezone thing in clock module
                          postremalone
                          https://calendar.google.com/calendar/ical/en.indian%23holiday%40group.v.calendar.google.com/public/basic.ics
                          i am using this link for calendar ical code is this fine.
                          https://calendar.google.com/calendar/ical/mr.deep.rawat%40gmail.com/public/basic.ics
                          • X
                            xchribiza @postremalone
                            @postremalone
                            In the module clock you need to close one more bracket }
                            module: “clock”
                            timezone: “MMT IST +630”
                            • justjim1220J
                              justjim1220 Module Developer @postremalone
                              @postremalone
                              Missing a comma ‘,’ at the end or your position entry.
                              Jim Hallock - 1995
                                @postremalone no… the timezone is based ont he javascript moment…
                                see here, you can use any/all of each line… yours I think could be
                                “Indian/Maldives|MMT”,
