    MMM-doomsDay - The countdown module,
    74 Posts 17 Posters 98.5k Views 16 Watching
      broberg Project Sponsor @bberg115
      @bberg115 Nice :D (easy to remember the anniversary then haha ;) )
      My username is my lastname, so it’s easy to remember hahaha
        bminer1
        Having an issue with the “toWhat” sticking.
        I can not get it to change from “Leaving for Paris!”. See my code below:
        module: ‘MMM-doomsDay’,
        position: ‘bottom_right’, // This can be any of the regions, best results in center regions
        doomsDay: “2017-05-07 24:00:00”, // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
        ToWhat: ‘Joeys Wedding in TN!’,
        updateInterval: 1 * 3600000,
        singular: ‘more day!’, // what it should say when it’s only one day left, default is Day Left
        plural: ‘more days’, // what it should say when it’s more days left, default is Days Left
        // See ‘Configuration options’ for more information.
        0_1490728574011_upload-95d70689-8dbe-4ab1-b9f6-447b6720a84c
          broberg Project Sponsor @bminer1
          @bminer1
          It’s case sensitive
          toWhat not ToWhat
            bminer1
            Thanks! It worked but that was copied and pasted from GitHub. May want to make the change.
            0_1490728928244_upload-91d7f2b1-ed96-4c2d-b3e8-04cca60299c2
              bminer1
              Also, is there a way to add multiple count downs to the one module or do you duplicate the module with every countdown?
                @bminer1 nice catch, the example was wrong, somehow I missed that!
                (it’s correct in the Configuration list however)
                Multiple instances in the config is the way to go at the moment,
                  mydiva
                  It is possible to make instead of just days, weeks and days left? Thanks guys
                    mydiva
                    I did it by myself, thank you anyway for the great module.
                    • N Offline
                      noelandrews
                      Hi all,
                      Bringing an old thread back up, just installed and got this module activated. I think I’ve done it correctly as per github but its not working. It just displays the ‘finished’ message the death and despair bit.
                      Can anyone tell me what silly obvious thing I’ve done wrong? Config in the pic below
                      justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
                      • justjim1220J Offline
                        justjim1220 Module Developer @noelandrews
                        @noelandrews
                        try removing the comma at the end of the ‘toWhat’ line
                        Jim Hallock - 1995
                          Mykle1 Project Sponsor Module Developer @noelandrews
                          @noelandrews said in MMM-doomsDay - The countdown module,:
                          Your config looks fine. I just installed and ran the module without a problem, duplicating your config entry. Are you sure you saved the config after having made the entry or that you are not working a second config? I’ve done that plenty of times.
                          Here is a screenshot of the module working with your config
                              module: 'MMM-doomsDay',
                              position: 'bottom_center', // This can be any of the regions, best results in center regions
                                  doomsDay: "2019-07-22 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                                  toWhat: "Leaving for the USA!",
                          If it continues to give you trouble, you could try https://github.com/mykle1/MMM-EventHorizon which does basically the same thing, with a few more options, as well as a working countdown timer.
                          • N Offline
                            noelandrews
                            Thanks guys, very weird. The config is exactly as you have copied straight from github. I’ll give Event Horizon a shot.
                            • zdenekZ Offline
                              zdenek
                              hi all
                              is there way how to countdown to repeating annivesary? smthg like
                                      doomsDay: "XXXX-12-24 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                                      toWhat: "X-MASS",
                              ? for x-mass (for kids), marriage anniversary, yearly TAX payment…
                              thanks,
                              Zdeněk
                                doubleT Module Developer
                                @zdenek Even though I think it’s possible with a few changes to the code, I don’t think this would fit the scope of this module, which is to manually set a countdown to one specific event (noteven a few, right?) but not for a whole list of calendar dates.
                                Even if the code ignores the year and just always shows the next event, does it make sense to have it display “364 days left” right the next day?
                                Anyway, if you want to do that, I’d suggest adding:
                                    doomsDay: "2018-12-24 24:00:00",
                                    yearlyEvent: true,
                                    toWhat: "X-Mass"
                                The most simple simple change to the code would be to add this at line 48:
                                if (this.config.yearlyEvent && daysLeft < = 0) {
                                    var diff = now.getFullYear() - doomsday.getFullYear();
                                    // update doomsday:
                                    doomsDay.setFullYear(d.getFullYear() + diff);
                                    // calculate again:
                                    timeparser = Date.parse(doomsDay) - Date.parse(now);
                                    daysLeft = Math.floor(timeparser/(1000*60*60*24));
                                (remove the space between “< =” … )
                                I didn’t test this, though, (and I don’t recommend it).
                                zdenekZ 1 Reply Last reply Reply Quote 0
                                • zdenekZ Offline
                                  zdenek @doubleT
                                  @doublet thanks, but this module seems to be easier way :-) anway, thanks a lot
                                  Zdeněk
                                    ChrizZz
                                    Is it possible to add more than 1 event and the module switches between the events with fade in and fade out?
                                      A Former User @ChrizZz
                                      @ChrizZz
                                      See https://github.com/eouia/MMM-CountEvents It could be done with group feature.
                                        MajorC Project Sponsor
                                        first of all thank you for the great modules. I am currently using it to display the time until my vacation.
                                        Since I speak German, I made a few changes in the code. But these are lost after an update and I copy & paste them back. Is there a better way to make these changes than fiddling around in the code?
                                        I change:
                                        ORIGINAL: headerD.innerHTML = this.config.toWhat + "</br>";
                                        MY:       headerD.innerHTML = this.config.toWhat;
                                        ORIGINAL: timeLeft.innerHTML = daysLeft + " " + this.config.singular;
                                        MY:       timeLeft.innerHTML = this.config.singular;
                                        ORIGINAL: timeLeft.innerHTML = daysLeft + " " + this.config.plural;
                                        MY:       timeLeft.innerHTML = " noch " + daysLeft + " " + this.config.plural;
                                        • 4 / 4
