    690 Posts 77 Posters 3.1m Views 70 Watching
      mecomex @cowboysdude
      @cowboysdude thanks, i will try it today, could you make me understand? I’m trying to learn, kinda newbie right now :)
        @cowboysdude and what’s strange is that it worked when i am accesing it from mobile phone at http://myraspip:8080 …
          @cowboysdude this is what i can see in a web page (everything ok) 0_1532865890377_lan.jpg
          this is what i can see on the main display where the raspberry is connected (no module)…
          • cowboysdudeC Offline
            cowboysdude Module Developer @mecomex
            @mecomex I will certainly help you… let me know what questions you have and I’ll do my best to answer them! :)
            • N Offline
              nobita @cowboysdude
              @cowboysdude , ask weather description such as clear,cloudy,mostlycloudy, rain,sunny etc …
              how can i translate weather description in local language ,Thanks so much
                cowboysdude Module Developer @nobita
                @nobita It should be doing it via your language config…what is your language?
                • N Offline
                  nobita @cowboysdude
                  @cowboysdude Thai Language
                    @nobita said in MMM-NOAA - Another Weather Module:
                    Thai Language
                    Please post your entire config.js minus any apikeys…just xxxxxxxxxxx in place instead of key numbers…
                        @cowboysdude
                        Dude, WTF? What is that module above NOAA??? Looks amazing!
                          jeffreyking
                          Hello every one I like this module and it works great, but I would like to know how to change the temp from F to C thank you keep up the good work.
                          Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
                            Mykle1 Project Sponsor Module Developer @jeffreyking
                            @jeffreyking
                            I could be mistaken but I think this module reads your config.units: "imperial" or config.units: "metric" and displays accordingly.
                              jeffreyking
                              Where in the module will I find that config.units: “imperial” or config.units: “metric”
                                @jeffreyking
                                Not in the module. At the very beginning of your config.js file.
                                var config = {
                                    address: "0.0.0.0",
                                    port: 8080,
                                    ipWhitelist: [], // Set [] to allow all IP addresses
                                    language: "en",
                                    timeFormat: 12,
                                    units: "imperial",
                                  jeffreyking
                                  Thank you I will change units to imperial and see.
                                    @jeffreyking
                                    imperial = F
                                    metric = C
                                      jeffreyking
                                      Thanks got that I am getting the wrong temp tell me 65 when it should be 27
                                        @jeffreyking
                                        NOAA3?
                                        It works for me. I just tried it. Went right to C when I changed to metric. Have you changed anything in any of the module files?
                                          jeffreyking
                                          No the default weather module works fine I am using yahoo as provider.
                                            @jeffreyking
                                            Well, if you haven’t changed any of the NOAA3 files then you’ll have to wait for the author to take a look at it for you.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 34
                                            • 35
                                            • 24 / 35
