    • cowboysdudeC
      cowboysdude Module Developer @mecomex
      @mecomex I will certainly help you… let me know what questions you have and I’ll do my best to answer them! :)
      N 1 Reply Last reply
      • N
        nobita @cowboysdude
        @cowboysdude , ask weather description such as clear,cloudy,mostlycloudy, rain,sunny etc …
        how can i translate weather description in local language ,Thanks so much
        • cowboysdudeC
          cowboysdude Module Developer @nobita
          @nobita It should be doing it via your language config…what is your language?
          • N
            nobita @cowboysdude
            @cowboysdude Thai Language
            • cowboysdudeC
              @nobita said in MMM-NOAA - Another Weather Module:
              Thai Language
              Please post your entire config.js minus any apikeys…just xxxxxxxxxxx in place instead of key numbers…
              • cowboysdudeC
                Mykle1M 1 Reply Last reply
                • Mykle1M
                  @cowboysdude
                  Dude, WTF? What is that module above NOAA??? Looks amazing!
                    jeffreyking
                    Hello every one I like this module and it works great, but I would like to know how to change the temp from F to C thank you keep up the good work.
                    Mykle1M cowboysdudeC 2 Replies Last reply
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @jeffreyking
                      @jeffreyking
                      I could be mistaken but I think this module reads your config.units: "imperial" or config.units: "metric" and displays accordingly.
                        jeffreyking
                        Where in the module will I find that config.units: “imperial” or config.units: “metric”
                        • Mykle1M
                          @jeffreyking
                          Not in the module. At the very beginning of your config.js file.
                          var config = {
                              address: "0.0.0.0",
                              port: 8080,
                              ipWhitelist: [], // Set [] to allow all IP addresses
                              language: "en",
                              timeFormat: 12,
                              units: "imperial",
                            jeffreyking
                            Thank you I will change units to imperial and see.
                            • Mykle1M
                              @jeffreyking
                              imperial = F
                              metric = C
                                jeffreyking
                                Thanks got that I am getting the wrong temp tell me 65 when it should be 27
                                • Mykle1M
                                  @jeffreyking
                                  NOAA3?
                                  It works for me. I just tried it. Went right to C when I changed to metric. Have you changed anything in any of the module files?
                                    jeffreyking
                                    No the default weather module works fine I am using yahoo as provider.
                                    • Mykle1M
                                      @jeffreyking
                                      Well, if you haven’t changed any of the NOAA3 files then you’ll have to wait for the author to take a look at it for you.
                                      • cowboysdudeC
                                        cowboysdude Module Developer @jeffreyking
                                        @jeffreyking said in MMM-NOAA - Another Weather Module:
                                        The temp will change depending on your setting in your config.js
                                        Example = Imperial shows F
                                        Metric shows C
                                          jeffreyking
                                          Got it up and running it was yahoo weather that was the problem. thank you
                                            Smotx
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 34
                                            • 35
                                            • 25 / 35
